New TPS for LT1 intake conversion
Old Mar 14, 2005 | 09:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I'm in the process of doing an LT1 intake along with an engine upgrade and ECM change on my brother's '91 Firebird (coming along quite nicely now as well).. As some of you with the LT1 intake may know, the standard TPI throttle position sensor interferes with the serpentine bracket on the passenger side... I have found a new sensor (available at Advance Auto under part # 779-3501) that bolts right in place of the old one, but has a vertical connector plug in.. Yahoo!! Here's the pics:
Old Mar 14, 2005 | 09:37 PM
thirdgen88's Avatar
Car: 1995 Corvette
Here it is on the throttle body:
Old Mar 14, 2005 | 09:39 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Damn, how much research did it take you to come across that sucker?
Old Mar 14, 2005 | 09:52 PM
thirdgen88's Avatar
Car: 1995 Corvette
Actually, its kind of a funny story... I was at work (at Advance) experimenting with a sensor tester I found sitting around, so I just went back and grabbed a throttle position sensor off the shelf at random... After playing around with the sensor tester for a while it suddenly clicked in my head on what I was holding.. I was like "Hey look at that"... Then I looked up and compared to a stock TPI TPS and whaddaya know..
Old Mar 15, 2005 | 03:58 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Cool! thanks for the info
Old Mar 16, 2005 | 10:25 AM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Glad to see you stuck with the lt1 intake. I don't care for it cosmetically, but that beats the heck out of grinding the bracket. I had to grind even more when I installed a BBK throttle body. If I'd do it all again I think I'd buy one of those.
Old Mar 16, 2005 | 02:28 PM
thirdgen88's Avatar
Car: 1995 Corvette
I think it'd look better if the sensor wasn't gray... With it being gray and the rest of my color scheme being black, it kind of sticks out..
After my die grinder and I got angry at some of the bolt holes that still didn't line up, all was well... Didn't have to take much off really, but had to remove some material in most of the holes..
Old Mar 16, 2005 | 02:36 PM
thirdgen88's Avatar
Car: 1995 Corvette
Here's a pic of the motor as of now... Next step is to do the rest of the wiring (extend the connectors from the TBI harness and add the multiport connectors).. After that I have to get creative with things like the cruise control servo, remote thermostat, and air filter ducting.. Hoping to be able to finish it up this weekend and start tuning with the Ostrich (thanks Craig!) next week!
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
