Parts for Sale 2006 Keep it Third Gen related please!
tpi 1986 z28 other parts too
Old Dec 26, 2005 | 12:07 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
Axle/Gears: 3.73 moser 12 bolt true trac
I have removed the engine (305) and tpi from my 86 iroc. I am doing a new engine with carb swap and dont need these extra items around. What I have is everthing computer to engine bay complete wiring harness that has not been cut. Tpi base, runners, fuel rail, injectors 19lbs, throttle body, upper plenum, most if not all sensors, distributor, evap canister, bolts for intake and all runners ect. dual air snorkle with mass air sensor too. I have a 206-212 duration 112 lsa comp cam too from the 305 that i put in about 500 miles ago. I took it back out if someone is interested. I also have the stock cam that came out of the 305 if someones wants that too (i dont know why you would). The prom has been programmed to work with out the cold start valve and the runners and fuel rail have been pluged to work without the cold start valve. (89 prom is what is in the memcal) no air injection has been added to that prom too. All programing done by tpiparts.net. I also have all the air conditioning stuff and cruise control parts too. Air pump and valves for air injection sytem are also kicking around that i dont need. the 305 will be parted out too any questions please email me at rtninja02@yahoo.com I will email you back....Ryan
Old Dec 26, 2005 | 06:54 PM
gonzo1028's Avatar
shoot me some prices
I am pretty much intrested in the whole set up. how much for everything. looking to deal asap. please respond.
brandykay04@yahoo.com
Old Dec 30, 2005 | 04:34 PM
rjt76's Avatar
Car: 1986 iroc z
Engine: vortec 383
Transmission: th350
add a complete 10 bolt rear and 700r4 to the mix too. I just bought a 12 bolt setup along with a new 700r4. I am willing to deal on these parts make offers guys. rtninja02@yahoo.com
Steven 86IROC-Z
Mar 28, 2026 06:42 PM
1992rs/ss
Jan 31, 2025 05:10 PM
jaridjohn
Jul 8, 2024 03:49 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
