Moog springs came in today...
Old Jan 10, 2003 | 01:17 AM
aklaim's Avatar
I just got my front springs in from summit today. 5662 for the fronts and cc635 for the rears. These things are huge the fronts weigh in at 27 lbs. Hopefully I'll get these things in this weekend if i can get some help. Not counting on it but oh well......here they are
Old Jan 10, 2003 | 10:31 AM
B4C Hawaii's Avatar
I believe if not mistaken that the "CC" on the rears stand for cargo coils and will raise your car to high in the rear, I believe I had the same ones but cannot remember the number, but I do remember it started with CC, and it raised my car Approx. 3" in the rear and it seemed to high. Let us know . Benny
I have those same front ones and they fit excellent.
Old Jan 10, 2003 | 10:35 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
yeah, I am interested in these springs also. I would like to know how they fit.
Old Jan 10, 2003 | 11:33 AM
aklaim's Avatar
Here's a pic....
Old Jan 10, 2003 | 11:59 AM
B4C Hawaii's Avatar
Yep, those rears look like my old ones, get a before and after measurement on the rear, mine was very high after installation.
Old Jan 10, 2003 | 12:33 PM
aklaim's Avatar
Did you keep them on your rear or did you change them out for something else?
Old Jan 10, 2003 | 12:38 PM
aklaim's Avatar
Also, I'm adding a 4th gen rear end, so the extra height in the rear from the cargo coils might actually do me some good seeing how I dont plan on running 4th gen wheels anytime soon.
Old Jan 10, 2003 | 01:53 PM
B4C Hawaii's Avatar
We put a 4th gen rearend on a '90 IROC and the rearend is 3" wider than a 3rd gen rearend, we also used the stock 4th gen springs and they were to high. I changed the moog springs back to stock on my car. If you use the 4th gen wheels on the 4th gen rearend it might not stick out.
Old Jan 10, 2003 | 02:01 PM
aklaim's Avatar
I know. Im aware that they will stick out an extra 1.5" on each side. What I'm saying is that the added height of the cargo coils might help me because I plan on running my stock 92 wheels in the rear on a 4th gen rear end. That way I dont have to worry about the tires rubbing in the wells.
Old Jan 10, 2003 | 05:41 PM
B4C Hawaii's Avatar
I believe that will work, it just looked weird with the stock 3rd gen wheels on a 4th gen rearend with it that high, we were thinking off cutting one coil off to offset the height, but he sold the rearend and put a thirdgen back in.
Old Jan 10, 2003 | 11:36 PM
Project92's Avatar
Springs and ride height
I'm running Moog 5664's in front with 80 % of a coil cut off. In the rear I have the Cargo Coils. For now, it has a V6, and the interior is stripped of everything, except from the two front seats. The ride height is 27-RF; 27 1/8 LF; 30 1/4 RR; 30 LR. I'm leaving the rear springs alone for now. After I get Sub Frame connectors, and some other suspension parts, {as well as a new black interior put back in }I might cut some off of the rear. For now though, I dont' mind how it looks. {It's kind of growing on me}
Old Jan 11, 2003 | 12:34 AM
Benny's Avatar
Normal ride height for the rear should be the same as the front, those moog cargo coils simply raise the rear too high, I returned mine and got some IROC springs from the junkyard and it went back to normal height. Those cargo coils are made for hauling heavy stuff, however I believe those are the only kind of rear springs that MOOG makes for the 3rd gen.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
