Did your stock injectors look like this?
Old Sep 24, 2002 | 10:27 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Mine are black on top and gray/silver on the bottom half??
All the pics of injectors for 90-92 5.7 TPIs I saw for sale on eBay were all black with a light green stripe?
Anybody else have these black and gray injectors, now I have no idea what size they are, I thought they were 22#.
Old Sep 24, 2002 | 10:47 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
They might have looked green, but they are all grey with a silver stripe.
Old Sep 25, 2002 | 11:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mine were black and silver/gray 22# out of my 92 350.
Old Sep 29, 2002 | 12:22 AM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Mine are black with green stripe.
Old Sep 29, 2002 | 02:12 AM
vortechLT1's Avatar
the only injectors I have ever seen on a 3rd gen with a green stripe were tomco rotary disk injectors
maybe they have been replaced once? (just making a suggestion)
and as far as I know they are big distributors of replacement injectors
Old Sep 29, 2002 | 11:57 AM
2QUIK6's Avatar
What I have discovered is the the 90-92 TPI 5.7s used Multec injectors, the black/gray ones. According to Rich at Cruizinperformance, these aren't worth cleaning and rebuilding as they are not worth it and are very unreliable injectors. But the injectors that can stock with the pre-90 TPI where very good and durable, they are Bosch sytl made by Rochester and are black with green stripe, so maybe thats why there are differing responses. So it appears that I do have the factory originals.
Old Sep 29, 2002 | 11:36 PM
88blackgta's Avatar
Car: 88 GTA Notchback
The black injectors with the green stripe that you are referring to are manufactured by Lucas. They are a "disc" type injector and were installed on some F-bodies and also some Corvettes in late 1986 thru 1988. There were also sold by ADS and also Tomco as aftermarket replacement injectors. They will normally have the letters CAV on them but not always. The earlier Rochester injectors that were installed from the factory have the letters "RP" on them and are all black with no silver band or green stripe.
I've heard the same thing from other sources that the Multecs from 1989 thru 1992 aren't worth having serviced.
Hope this helps straighten out the confusion.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
z28_AJ
Aug 27, 2015 08:59 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
