TPI Injector part numbers.
Old Mar 29, 2003 | 01:21 PM
RBelflower's Avatar
I just purchased my soon to be TPI for my 305. I need help making sure that I have the right injectors. The part number on the injectors is 17086544.
Thanks to all.
Rob
Old Mar 29, 2003 | 02:12 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Do you know the year of TPI set-up????? GM p/n for 87-88
19# injectors is 17111960
Old Mar 29, 2003 | 02:49 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
I think the injectors are GM multec injecotors. They will be the grey type and were introduced in 1989. They are a 22lb injector (stock for 5.7) and will require an injector constant change in your chip as well. Without seeing a pic I assume the info should apply and if it does those injectors are notorious for breaking down internally and can't be repaired. Many places won't even try to service this type of injector because of its design flaw. Not trying to discourage ya, just giving you a heads up. I had a set factory on my 89 GTA that I am using as paperweights in my garage .......
Old Mar 29, 2003 | 09:42 PM
RBelflower's Avatar
The unit cam off of a 91 Z 350. I was hoping that they were 19lbs so I could use them on my 305 until I change it to a 350.
Rob
Old Mar 30, 2003 | 06:44 AM
DJP87Z28's Avatar
All stock 350 TPI had 22# FI. And the latest P/N for them is GM 17111961
Steve78LT
Feb 24, 2016 12:15 AM
Brcharrelson
Aug 26, 2015 07:47 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
Sanjay
Aug 12, 2015 03:41 PM
1nastygta
Aug 8, 2015 07:38 PM
