__Strut tower brace??__
Just wanted to find out where you guys purchased your strut tower brace. How much did it cost? Does it mount in pre-existing holes or do you have to drill new ones? Post pics if you have some....thanks
> 1990 IROC-Z (black)
> one of 3000 IROCs with a 305 made in 1990
> flowmaster exhaust
system with mufler bypass
> z-28 spoiler
> blue under car neon kit
> check out my site at: http://geocities.com/thickfacek/IROC-Z.html
> email me at thickfacek@nc.rr.com
> 1990 IROC-Z (black)
> flowmaster exhaust
> z-28 spoiler
i would get an edlebrock one personally. its a 3pt and handles better!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 9 Bolt Borg-Warner 3.27gears
Bright Red Hardtop/ Grey Interior
NEW RED PAINT
WELD PROSTARS.
Hopeing for 13.6s with new mods!
DAILY DRIVER: 1991 GREY S10 2.5L/5SPD -FOR SALE.
Jarrad
TH-700R4
NEW RED PAINT
WELD PROSTARS.
Don't strut tower braces get in the way of the engine? What if you needed to work on your engine for some reason? I was just curious.
Drew Veeneman
87' Camaro
Jasper Class II 350 (.3 over)
World Products S/R iron cast heads
Stock auto 700r4
Snail like 2.73 gears
3" roundd K+N Air Filter
Road Demon 625cfm
Edlebrock Performer Intake
Edlebrock Headers
3" Cat+Flowmaster
Ugly olive drab camoflauge paint job
Check Out Sharky at https://www.thirdgen.org/rides/index...ew&rideid=3002
Drew Veeneman
87' Camaro
Stock auto 700r4
Road Demon 625cfm
Edlebrock Headers
3" Cat+Flowmaster
<font face="Verdana, Arial" size="2">Originally posted by Sharky:
</font>
</font>
i have the hotchkis and like it. its simple to get on and off if you need to.
I've got a STB from a company called MAC. It's no where near as good as the Hotchkis unit but no drilling is required, it just goes over the existing bolts for the struts. It does make a difference with the car's handling though. I think I paid $200 CAD for mine and well worth it.
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, modified MAF, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for LCA and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, STB, JET low temp stat, CarSound Hi-flow Cat, DynoMax 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, T-tops, and White exterior with red leather interior.
2001 Sunfire GT
Bone stock 2.4L, 5-speed, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
1987 Camaro IROC-Z
2001 Sunfire GT
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have the Edelbrock on my car...It made a very noticable improvement in the handling of my car. I like it because it not only ties the strut towers together. It also ties into the cowl. The tower to tower braces will keep the towers from flexing. But they can still bend towards the cowl in a very hard turn. The tower to cowl brace keeps this to a minimum. Either is diffently an improvement over stock.
They dont really get in the way of changing plugs and tuneup things. But if you need to remove the plenum or something you would want to remove it. I can take mine off in five minutes.
I bought mine used for 75.00! Summit, jegs has them.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
I made one for my Camaro, it looks just like the Edelbrock, I work at a machine shop so I just used leftover tubing and steel plate we had laying around and sawed it out and welded it together, works and looks great and didn't cost me anything but my time.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
Car: 90 IROC
Engine: 406
Intense92....I worked in a sheetmetal shop for 6 years. I really miss working there, I had everything I needed to build whatever. Plasma cutters, metal breaks, welders, ect. You can never have enough toys to play with.
Engine: turbocharged 4 cyl Dohc
Transmission: 5 spd sentronic
i went to HP motorsports and bought the 3-point for my bird this one bolts in to the fender wells just forward of the strut mount and you would need to bolt it to the fire wall
1991 ASC conversion
Pontiac Firebird convertible
305 cid V8
700-R4 O/D trans
K&N 14" open air cleaner
Hp motorsports STB Performance Suspension springs
kyb shocks/struts
Vortec exhaust
16" RS wheel--245/50 A540 Yokomama
Alpine cd/JL audio sub combo w/12 cd changer
headers coming soon!
<br>THIS IS MY SITE -- CLICK HERE!!!
"I always breathe normally in a 600 mph uncontrolled vertical dive...........I also sh*t normally,
..RIGHT IN MY PANTS ! !"----George Carlin-----
1991 ASC conversion
305 cid V8
700-R4 O/D trans
kyb shocks/struts
Vortec exhaust
Get a BMR brace. They are the cheapest, good looking, good quality, and you can get them in a variety of colors. I think they have them on Group Purchase for $75 dollars right now. Check out www.bmrfabircation.com
Founder of the Greater Cincinnati F-Body Association
1988 Yellow Trans Am GTA
Click here for photos
