Different spin on using the LT4 hot cam, come inside
ok, i have a stock LTR setup and i know that the hot cam is a bit much.
Has anyone advanced the cam while installing it to bring down more power down low where the TPI needs it?
just curious....i think that maybe i should do tests of straight up and advanced because retarding it would obviously put the powerband up too high.
any opinions?
any opinions?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yah, I put in a 4º cam key when I installed my LT4 HOT cam. However when I degreed it, the cam came out to 3º retarded, meaning its only 1º advanced. I dunno whats up with that...
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
I installed mine straight up, with bone stock intake and heads. Yes, the cam is a bit too much, but with the proper mods, you can get it to run just right. I however didn't degree the cam, I just lined up the marks on the timing chain set.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
L98 TPI 350 (5.7L)
1988iroc350tpi
Aug 14, 2015 07:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
