Picture of the underside subframes
Old Dec 20, 2005 | 11:40 AM
jjcirocz's Avatar
I was looking at the thread "make your own sub frame connectors" and I was looking at the picture that 89_ho_rs posted and was woundering if someone could post a simular picture or the same picture without the drawings and notes. I plan to make my own subframes and swap a ford 9". I would like this picture so I can look over the underside and draw stuff out. Has anyone ever used a rear end out of a 71 to a 74 mustang in there camaro. I found that this rear end is really close to the same size as the third gen rear end. Thank you and If anyone has pictures of tieing in the front subframe with the rocker over the cat, please post.
Jesse
Old Dec 20, 2005 | 09:48 PM
Merlin's Avatar
Sorry - About the best I can do:
Old Dec 24, 2005 | 05:30 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
why was this car on its side?
Old Dec 24, 2005 | 05:38 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Maybe it can't sleep on it's stomach......
Old Dec 28, 2005 | 12:17 AM
Kwik89GTA's Avatar
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Yeah, why is that car in a showroom on its side?
Old Dec 28, 2005 | 10:27 AM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
It is a mattress showroom. What better way to prove the durability of your serta??
I have a better solution picture of that and a better picture of the subframe on a jiglift. I'll post them when I get home.
Old Dec 28, 2005 | 05:36 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
its a TTA, look at the tranny pan. some dealer did that back in the day for some reason. pretty sure ive seen that pic before and that was the story
Old Dec 28, 2005 | 07:22 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Also note the torque arm mount
Old Dec 29, 2005 | 07:57 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
i have seen this picture in many old post.. Just cant figer out why someone put it on it side... Probley some werd sales gimic. Good way to dent a door panel... with or without mattres.
Old Jan 6, 2006 | 10:57 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Here is the best I have.
Old Jan 9, 2006 | 01:07 PM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
What size material did you use for those subframes? The Work looks good
Old Jan 9, 2006 | 05:23 PM
SinCity's Avatar
Car: 1988 Chevrolet Camaro SPL
Engine: 350 Modified
Transmission: T-5 manual
Axle/Gears: Ford 9in - 3.50
Do you have specifications for building the subframes you have? Those look pretty sharp! I'm building a cheap Hobby Stock 3rd-gen dirt racer and I'm gathering up SFC info before I design the roll cage..
Old Jan 16, 2006 | 09:07 AM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Sorry guys, that's not my car, just a pic I saved from the boards a while back. Mine is stripped down the same, just sans the SFCs and not on a jig lift.
Linson
Sep 21, 2015 01:08 PM
Nick McCardle
Sep 10, 2015 08:36 PM
snakeshooter
Sep 7, 2015 11:15 AM
Strick1
Sep 6, 2015 02:21 PM
