Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
welding braided steel line?
Old Nov 28, 2005 | 11:05 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I have a piece of 12an braided steel line for a turbo return line. The problem is that the hose end is too wide to fit between the compressor and turbine housings. However, the line itself fits in the gap.
I machined the oil return flange with a 3/4" hole. Is it possible to just weld the line to the flange? Or is there another solution?
Old Nov 28, 2005 | 11:09 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use a banjo fitting, or some tubing.
Old Nov 29, 2005 | 06:28 PM
Mathius's Avatar
I've never attempted anything like this, but I think if I understand the way braided steel line is constructed, it would just be too thin to weld unless you're _REALLY_ good.
I know a guy who claimed he could weld aluminum foil together with a TIG and had it passed via x-ray as a legit weld, but he's a total politician and he'll say anything he thinks you want to hear.
I really think if you tried to weld it, the individual strands would just burn up piece by piece.
I could be wrong.
You might be able to solder or braze it.
Mathius
Old Nov 29, 2005 | 06:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Considering the braid is just a protective covering over a rubber hose, even if you could get it to weld it wouldn't actually seal anything.
Old Nov 30, 2005 | 12:23 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
My thoughts exactly.
Old Dec 8, 2005 | 11:54 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
or try using a normal size piece of line, -12 for a turbo oil drain line? thats insane
Old Dec 9, 2005 | 12:21 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
It's probably overkill, but it's what I got. I'll probably take Apeiron's advise and get some tubing to weld to the flange, and then connect the line to the tubing.
Old Dec 31, 2005 | 09:41 AM
fitbmxseries1's Avatar
Car: 1988 trans am GTA
Engine: 350 tpi
silver soldering would work good, its alot stronger then soldering with lead and can handle some pretty high psi, and its not all that hard to do, all you need is a torch and use the smallest flame attatchment possible. im pretty sure welding would just melt right trough it..... get a small peice and test on it possibly?
Old Jan 1, 2006 | 07:13 PM
83 Crossfire TA's Avatar
WTF? Welding? Silver soldering? HAVE YOU GUYS EVER ACTUALLY LOOKED AT A PIECE OF BRAIDED HOSE???
It's RUBBER or teflon hose with a protective stainless braid on the outside of it, it's still the same rubber hose without the braid, if you take the rubber hose out of it you end up with a pile of useles crap.
No, you can’t weld, solder, braze, superglue, braid or macramé it to the flange. Get a proper hose end and thread it to a fitting or use a properly sized hose barb and a hose clamp.
And no, chewing gum won’t work either.
Duct tape might.
Old Jan 1, 2006 | 11:36 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Old Jan 2, 2006 | 03:29 PM
Engine: 350 tpi
Duct tape might.
LMAO now that i really think about it........ your right! i completely forgot about whats inside the metal
well you accualy could silversolder it.... not gunna hold any pressure or liquids though
Old Jan 3, 2006 | 06:46 AM
Dan W's Avatar
LOL, Thanks for the laugh. I just did a search and confirmed what I thought... thats the first time the word "macramé" has ever been used on Thirdgen.org.
Duct tape might.
Old Jan 3, 2006 | 11:31 AM
hey, I just tell it like it is...
Old Jan 3, 2006 | 11:44 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: welding braided steel line?
weld a tube to the flange to let it come out past the housings.
weld a AN fitting to the tube.
connect a normal AN fitting to the SS line
connect line to turbo drain tube via AN fitting..
although im curious to what the final outcome of this turbo setup will be, considering that the person fabricating it couldnt figure this out... lol
Old Jan 3, 2006 | 12:21 PM
well, to be politcally correct and a shiny happy 'net resident you can't really say what you want. On another board someone is asking about gearing for a car that will trap 170 and doesn't seem to understand that the combination has a lot of effect on the gearing.
Right now I'm thinking of strongly pushing people towards more and more dangerous things and let darwin take care of it.
You want 2000hp... sure, this is how you do it, you can't tell your right foot from your left... no problem, I'll draw pictures, just match them up. Naw, it doesn't need seatbelts...
Old Jan 5, 2006 | 02:07 PM
Ragtop89's Avatar
Just crimp the ends together and use chicken wire to hold it together.
Old Jan 16, 2006 | 10:50 AM
b_the_j's Avatar
Car: 92 RS
LMMFAO, you guys are gonna send me to the hospital!!!
I agree with 83 CROSSFIRE.... duct tape is definately the answer
Old Jan 16, 2006 | 10:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
is this before or after their car slams into you when the "welded SS brake lines" fail?
if someones ever actually tried that, i really do want to see pics! lol
Old Jan 16, 2006 | 01:11 PM
Ratchet's Avatar
Yuh can sew
yu cn welder that ther braided steel together plenty. I got tons of ere under my hood all welded up. Soonas Igets the rest ah the rivets in my new body kit I'll post yaaalls some pics
Old Jan 16, 2006 | 01:31 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
I followed Apeiron's advice to use some tubing.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Sep 14, 2015 07:16 PM
TBRays98
Sep 6, 2015 05:05 PM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
