polished factory wheels
Old Feb 27, 2003 | 10:17 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
hey everyone,
ive got a 91 rs with factory wheels. I was told i could sand all the paint off them and polish the aluminum with mothers aluminum polish. I wanted to see if any of you have done this, and if you might have any pictures that i could see.
Old Feb 27, 2003 | 11:09 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
you can prolly use the search and find alot of stuff on this topic. Ill try and help ya out as much as i can. Ive got a set of 89 formula deep dish wheels that i polished all by hand. I will admit it is a real pain doing it....but when you get all done....its well worth it. Trust me. I started with some aircraft stripper(paint stripper) and took all the clear coat off. Then started at 180 grit sand paper. I went on and off with wet sanding and dry sanding. I thought that the wet sanding had more of an effect then the dry but you can try and see what you think. Anyways, after the 180 then i went through the grits..220, 320, 400, 600, 800, 1000, 1500, and then finished at 2000. After that, take a rag or something and whip the rim clean. Now, ive used mothers before and dont get my wrong the stuff works great but someone gave me a hint on here to try some stuff called "blue magic". So i did and .... wow......what a difference. You can really see a shine. Hope this helps you out somewhat. Here are some pics of my results. The pics are dark so you can really get the real shine coming from the rim but believe me i think they came out real nice.
Old Feb 27, 2003 | 11:10 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Old Feb 27, 2003 | 11:13 AM
TorchRay's Avatar
Car: 89 WS6 Formula
Old Feb 27, 2003 | 01:14 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
The best way to get a real good polish is by using polishing wheels and greases. Hand sanding will give you an ok finish but with polishing wheels and greases you can get a mirror finish out of the alluminum. I do all my polishing with the wheels and grease.
Old Feb 27, 2003 | 01:30 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
My formula wheels look similar to his above(polished), but i would like them to shine like yours, and tips, or steps to accomplish that?
Old Feb 27, 2003 | 02:09 PM
Car: 85 Camaro SC
Engine: V6
I cant give out my secrets but, plan on spending a wad of cash getting all the equiptment you will need.
Polishing wheels 3 different kinds you need
Polishing grease 3 different kinds you need
Air compressor
Da sander
Glue on the back da sanding pads, need both 180,320 grit paper
Die grinder
Need 180,400 grit strait sanding drums, and also need tapered drums
And the numerous wheels you will use in polishing things.
And then learning how to polish very good, it didnt happen to me overnight. It took me 5 months to get my techniques down to make a mirror shine on alluminum.
Old Feb 28, 2003 | 01:39 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Thanks for your help. that pretty much tells me what i need to know. Except the part where you talked about greases. What do you have to do with that, and what kind of grease do you use. thanks for all your alls help.
Old Mar 7, 2003 | 11:52 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
I dont know about greases? , but i have used buffing wheels and different compounds to do polishing, you should check this site out. http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm , that shoud give you lots of info.
Kevin
Old Mar 8, 2003 | 12:02 AM
85_ZED28's Avatar
Car: '85 Z28
old pic, i know
Old Mar 8, 2003 | 12:03 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Axle/Gears: 3.45
By greases he means buffing compounds. Where the heck did u come up with grease anyway?? Anyway you can get the compounds from Eastwood.com or from your local Ace hardware. As for the procedure, 250grit paper dry, 320 grit wet, 400 grit wet, tripoli buffing compound on a hard wheel followed by white rouge with a medium/soft wheel. good luck
Old Mar 8, 2003 | 12:42 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Actually, he's right. They usually call 80-400 grit compounds... grease.
While you have your other compounds such as white rouge and tripolio.
Old Mar 8, 2003 | 04:05 PM
Car: 85 Camaro SC
Engine: V6
I've always called the compounds grease. When you hit it up against a spining polishing wheel what happens. Put your part or something just under the wheel and compound while putting the bar of compound to the wheel and you get melted compound which looks like grease.
Old Mar 10, 2003 | 12:41 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You can search for my polished wheels as well on here.
Old Mar 14, 2003 | 07:22 PM
skahide's Avatar
85_ZED28
HOW DID YOU DO THAT TO YOUR RIMS?
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
86IROC112
Sep 29, 2015 04:07 PM
kah992
Aug 19, 2015 02:55 PM
novaderrik
Aug 10, 2015 12:44 PM
