Polishing plastic - How to inside
Old Nov 18, 2003 | 07:09 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I restored the parking lights from my Camaro today. Here's what was needed:
-sandpaper (600 grit, 1000, 1500, 2000)
-Drill
-Soft buff wheel
-Emery, Tripoli, White rouge
-Blue Magic aluminum polish (or any other alum. polish)
-A good wax (I used Meguiars Gold Class)
First sand the plastic with 600wet, under running water. Repeat with 1000, 1500, and 2000 grits (wetsanding). You must wetsand otherwise the plastic clogs up the sandpaper, and leaves a dull finish to the plastic. After that its time to buff. Buff them with the Emery compound first, then wipe off excess. Then buff with Tripoli compound, etc etc. Repeat with the white rouge.
Then you can use a rag and polish them with the aluminum polish, I experimented and it takes out alot of fine scratches. Finally when you're done, wax the plastic with a good name brand wax to protect it, it also gets rid of some very fine scratches. Here are the results
Before-
To this...
I have yet to try any true "plastic polishing" compounds, but from what I hear they work pretty good. Although Tripoli compound is recommended for buffing plastics.
Old Nov 18, 2003 | 07:13 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
wow that came out real good.. thanks for sharing your work
Old Nov 18, 2003 | 07:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you got great results, and not to upset you or anything..
but i did mine by wet sanding with 1000 grit, and then used alum polish.... results came out outstanding....
sand paper and the polishing compounds are cheap, but i just did mine with what i had and it came out excelent...
so anyone worried about foobaring your headlights by polishing too much, you may be able to just sand and finish polish..... its pretty much foolproof... jsut dont use a electric sander, lol....
Old Nov 18, 2003 | 07:37 PM
I agree with ya completely man. Work with what ya got. Honestly, I found out how to polish plastic completely by accident and experimenting! These are just the steps which I have found work best.
One tip - Don't keep the drill in the same spot at high speed for too long, heat will build up. Just move it around slowly and you'll be fine.
Old Nov 18, 2003 | 10:27 PM
joshp14's Avatar
That process looks like it worked well...BUT...there is a little easier way that could give similar if not better results.
Try plastic polishing compound from eastwood. All you need is a polishing wheel and the compound.
Here are the results from polishing my 3rd brake light on my other car....
Old Nov 18, 2003 | 10:36 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Transmission: 700-R4
THANKS!
I'm going to have to try it on my Tail lights...
THANKS for the info!
Old Nov 18, 2003 | 11:54 PM
Red89ta's Avatar
Just like polishing paint but easier.
Old Nov 19, 2003 | 06:39 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Looks great!
I really don't see why you would use aluminum polish after, it is much more abrasive then rouge. Rouge should have gotten the fine scatches out.
Anyway, who cares, they look great
Old Nov 19, 2003 | 06:42 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Wow, that looks great.
Old Nov 19, 2003 | 08:33 AM
LUVmy92's Avatar
Car: Camaro
You just sved me money! I was gonna go buy new front lights because they look like yours did in the before pics! I want to leave work now and try it now! Thanks for the info! I will post before and afters when I get done but it might be a day or so.
Old Nov 19, 2003 | 08:37 AM
LUVmy92's Avatar
Car: Camaro
Where can I get plastic polish (Advance/Autozone/Napa)?
Old Nov 19, 2003 | 09:10 AM
SweetRide45's Avatar
You can get it from the Eastwood Company. Here's a direct link:
Plastic Compound
I just did my rear lenses w/ it...and some sand paper...I tell ya, like lookin' in a mirror!
Old Nov 19, 2003 | 09:12 AM
Oh yeah, and Plastic Polish/Wax...pic up some Mothers Plastic Polish. It works great! So far, only place I saw it was at Murrays Auto. I'm sure you could order it. It's like $6 a bottle. I heard Meguiars PlastX is good too, but, I could only find that in little pouches at Autozone.
Old Nov 19, 2003 | 11:38 AM
Steve89GTA's Avatar
I used the blue compound from eastwood.
Old Nov 19, 2003 | 11:44 AM
That's the stuff!!
Old Nov 19, 2003 | 11:53 AM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Nice! I have to try that on the taillights on my Tahoe!!
Ken
Old Nov 19, 2003 | 01:26 PM
CaysE's Avatar
I used Mothers on my 86 third brake light cover. Matches my black paint now!
I can't make heads or tails of joshp's picture... which way is up???
Old Nov 19, 2003 | 02:33 PM
What all these guys said will work great.
I have yet to use some of the Eastwood plastic polish, I'm thinking about asking for some for Christmas.
Old Nov 19, 2003 | 02:39 PM
I'll post pics of the job I did w/ my lenses...Maybe sometime tonight or tomorrow.
Old Nov 19, 2003 | 06:55 PM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
On the discussion of plastics...has anyone used any of these techniques on Lexan T-tops and did it work? The Meguiar's Plastic Kit did not remove any of the inperfections.
Old Nov 19, 2003 | 11:41 PM
joshp14's Avatar
LoL...up is up. It's the 3rd brake light from my high rise spolier on my 95 TA....here is the tail lights of my 88 TA that have been polished with Eastwood Plastic polishing compound (blue stuff)...
Old Nov 20, 2003 | 06:45 AM
CaysE's Avatar
Ah, ok, now I see! Not too familiar with 4th gen cars yet.
Old Nov 21, 2003 | 11:37 AM
ss85tadude's Avatar
Car: 85 Trans Am
Josh,
That looks great (did you also polish your filler panel)
I need to do this to my tail lights also
Old Nov 21, 2003 | 12:57 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Meguiers Clear Plastic Polish/Cleaner
For people who are looking for some plastic polish/cleaner locally, I picked mine up at Advance Auto Parts about a year ago... It was located in the marine section (where all the small batteries are and everything).. Two separate products, Meguiers Clear Plastic Polish and Clear Plastic Cleaner... Worked great when I polished the plastic behind the instrument bezel to remove fine scratches (how they got there I have no idea but Meguiers took em out)...
Old Nov 21, 2003 | 03:45 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
When using a buffing wheel on plastic, be sure to move the piece around a lot and do not apply a lot of pressure, or you'll damage your part....Ask me how I know
Old Nov 21, 2003 | 03:47 PM
I'll post pics as soon as my DISPUTE w/ the host company is over...bastards! lol
Old Nov 21, 2003 | 04:03 PM
joshp14's Avatar
Originally posted by ss85tadude
Josh,
Sure did.
Also, kind of off subject, but could you downsize your signature picture by about 150-200 pixels? I would appreciate it.
-Josh
Old Nov 22, 2003 | 12:51 AM
oldblueZ's Avatar
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
I just used Blue Magic plastic polish found at many local auto parts stores. The difference that I think I found between using this and the compounds you guys are talking about using (with the drill and all that) is that I have to polish my plastic every once in a while (like paint). It seems like the way you guys are doing it will last longer. I have no pics, but I did it all by hand with a cloth. It seems like the results were fairly similar too.
-Jesse
Old Nov 22, 2003 | 12:55 AM
With the drill and buff wheel, you can get into the finer crevises that a rag just can't reach. I mean, the wheel actually "digs" into the lense and gets out those little imperfections. The compound is like EXTREMELY small sand paper (in my opinion), and w/ high speeds, takes out ALL scratches and marks. I would HIGHLY recommend this method, as opposed to hand buffing.
Old Nov 22, 2003 | 12:59 AM
oldblueZ's Avatar
Car: 85 Z28
......I don't own a drill. Otherwise I would use the buffing wheel!
-Jesse
Old Nov 22, 2003 | 01:01 AM
Check small automotive/hardware stores. I got a 1/2" 3600rpm Impact Drill that is PERFECT for buffing small plastics, etc. w/. And the best part is, it was only $3!
Old Nov 22, 2003 | 11:51 AM
LUVmy92's Avatar
Car: Camaro
At the most $20 at Walmart! I am doing my lights tonight so I will have pics up tomorrow or monday unless I screw em up then I will hide my shame from all of you!!!
Old Nov 22, 2003 | 03:09 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
$3 You need to pick one up for me bro
Old Nov 22, 2003 | 03:14 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
NICE!!!! im going to have to try that....
Old Nov 24, 2003 | 07:14 AM
ss85tadude's Avatar
Car: 85 Trans Am
LOL I have been meening to do that
Old Nov 24, 2003 | 01:36 PM
LUVmy92's Avatar
Car: Camaro
Heres mine....
My Cardomain site
Old Nov 24, 2003 | 01:41 PM
LUVmy92's Avatar
Car: Camaro
Its amazing how much better they look for the small amount of work that it took. I also found a great cleaner to remove the scum that builds up inside the lights after 11 years of abuse and dirty water! Its called Greased Lightning...just put some in let it sit for a minute then shake it like its your.....uh.....well just shake it and its spotless!
Old May 24, 2004 | 11:28 PM
kid camaro's Avatar
Car: 91 z28
Engine: 305 tpi
i know this is a old thread but when you polished your park lights di you take the lens out? or did you just polish the outside? thanks for any help
Corey
Old May 25, 2004 | 07:40 AM
LUVmy92's Avatar
Car: Camaro
I took the parking lights out of the car but that was it. I didnt seperate them or anything from the housing. Th main thing was getting a high strength cleaner inside the housing and letting it sit for a while to get rid of the scum inside.
Old May 25, 2004 | 10:06 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
"....Ask me how I know", ditto on the screw up. Make sure you don't allow much heat to build up.
Old May 25, 2004 | 11:19 AM
KBeez's Avatar
Car: 88 Camaro S/C
thanks for the info! What do you guys recommend to let sit on the inside though to remove the "scum"?
Old May 25, 2004 | 03:47 PM
LUVmy92's Avatar
Car: Camaro
I used Greased Lightning, not diluted at all. I let it sit for 15 minutes each light. It was great. Check out my link to my Cardomain site to see before and after.
Before and after
Hotrodboba400
Dec 10, 2019 07:07 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Saxondale
Sep 15, 2015 06:42 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
