relocated my IAT
Old Aug 12, 2002 | 02:06 PM
5SIZ's Avatar
Car: 1987 IROC-Z
relocated my IAT
I just relocated my IAT sensor right below my air filter. I know its a free mod and it wont give me a noticable dif. but I am just wondering how much.
I also heard that relocating the IAT in a maf is very beneficial but in an SD setup it doesnt really do squat, how come?
Old Aug 12, 2002 | 03:15 PM
Lounge Lizard 6's Avatar
Don't know about MAF but it does matter with SD. You can make adjustments in the Prom to account for the cooler air.
Old Aug 12, 2002 | 07:15 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Re: relocated my IAT
It's the other way around. It does squat for MAF (for fuel). Air temp is all handled by the MAF sensor NOT the IAT/MAT sensxor. But can cause problems with the how the EGR works (which is the only thing the IAT/MAT does on a MAF car). Generally, a relocated MAT causes the EGR to cease functioning much at certain air temps (when it would normally work). So for a MAF car, at BEST its a useless mod. At worst, it screws up the operation of the EGR.
On a SD car, you MUST recalibrate the eprom as a relocated MAT drastically affects the fuel tables. If you don't, you will run overly rich with a SD car.
Old Aug 13, 2002 | 07:58 AM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
So does this mean that I can eliminate the MAT on my MAF car since my EGR is removed anyway?
Old Aug 13, 2002 | 09:21 AM
Car: Death Mobile
Engine: 666 c.i.
It is most likely going to throw a SES code. Could stick a 4.7K resistor into the connection and that would solve the problem since the 4.7K resistor equates to 52*F and within tolerance.
Old Aug 13, 2002 | 10:50 AM
HotRod's Avatar
Car: 87 GTA
It will throw a SES but it won't affect the actual function of the injection........ just the egr......correct? Thanks,
Old Aug 13, 2002 | 07:23 PM
Car: Death Mobile
Engine: 666 c.i.
When an SES code occurs, the ECM will normally go into "Safe Mode" (not limp mode as most assume). In Safe Mode, the ECM will ignore various sensor readings and use "override" values for a number of settings. Bottom line, the engine will run but not correctly.
If you have a bad MAT/IAT sensor on a MAF car, the best "quick fix" is to stick a 4.7K resistor in the connector.
Old Aug 22, 2002 | 10:02 PM
89Irocz23's Avatar
Im still doing my lt1 stuff. I have a MAF set up and need to relocate this sensor. Is it better if I just stick the resistor thing in the connector? Or just relocate it? I dont have EGR..its disabled in the prom so thats no biggie.
Old Aug 23, 2002 | 01:50 AM
5SIZ's Avatar
Car: 1987 IROC-Z
I would just relocate it then use the rsistor.
Old Aug 26, 2002 | 08:26 AM
Car: Death Mobile
Engine: 666 c.i.
All you do is stick a 4.7K resistor into the connector that you would normally plug the MAT/IAT sensor into. Then you can just leave it connected to the harness in the back of the firewall and shove it somewhere where it won't get burnt. No need to relocate, since you aren't using an IAT/MAT.
Old Aug 27, 2002 | 06:37 AM
bigals87z28's Avatar
Car: Check The Sig
Ok dumb question... but where is the IAT... is it that sensor in the air intake... because i dont have it... there is a patch over where it is supposed to be... but i dont have it...the patch looks like its made of the same material as the air intake... i do have a MAF, one would thing with over 380 posts... i would of asked this question... i saw the sensor in a car that was at my work the other day... my car still runs fine... i dont know what happend... but i dont belive my car had one...
Old Aug 27, 2002 | 06:51 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
It's threaded into a hole in the bottom of the plenum on an 87.
Old Aug 27, 2002 | 09:11 AM
Car: Death Mobile
Engine: 666 c.i.
Yes, you should be able to feel the wires and sensor on the bottom of the plenum near the driver's side rear.
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
86White_T/A305
Sep 21, 2015 05:28 PM
BWilcox
Sep 20, 2015 12:19 PM
89newfun
Sep 16, 2015 09:28 AM
