Romulator is acting up
Old Mar 13, 2004 | 07:50 PM
ULTM8Z's Avatar
When I'm idling, it cuts in and out and the engine almost stalls before the stall saver kicks in. If I put a regular chip in with the same calibration, it runs fine.
Do these Romulators go out after a while? It says there's a battery inside... maybe it's going out? Anyone else experience anything similar?
Old Mar 13, 2004 | 08:56 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Might be RFI.
Try a layer of AL foil around the ribbon cable, Romulator, and ground that.
If the foil cures it, look for a bad plug wire, rotor, cap, etc..
Old Mar 13, 2004 | 09:02 PM
ULTM8Z's Avatar
Grumpy, thanks. Hadn't considered that. Actually I did some work around the distributor cap recently. I'll go back and re-examine my work to make sure I put everything back together properly. Though, I'm not picking up any RFI in the radio???
Old Mar 13, 2004 | 10:26 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
The Romulator, seems to be very sensitive, RFI wise.
It even seems at times, that a late model PWM alternator can cause fits for one. I *think* that's the reason it doesn't like my truck.
Old Mar 13, 2004 | 10:52 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
grumpy - were you able to get the autoprom working with your truck? just wonderin'. I know you were going to try it, but never heard the result.
Old Mar 14, 2004 | 10:06 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I thought I'd done a memo about that.
Yes, the Autoprom was hitch free in the truck.
And on the bench, I've gotten it to work with the Radio Shack, Serial to USB adapter.
So far, I haven't been able to do any long term testing, since the weather's been just so miserable.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
