Those with NX part #20920........
Old Feb 3, 2002 | 07:47 PM
Acceld Z's Avatar
Car: 1992 Z28
Is it possible to run both the fuel line for the nitrous and a fuel pressure gauge off of the schraeder valve? Does anyone make some sort of a "T" fitting?
Old Feb 4, 2002 | 03:50 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
Good question. I would also like to know.
Old Feb 5, 2002 | 07:58 PM
Acceld Z's Avatar
Car: 1992 Z28
ttt
Old Feb 6, 2002 | 06:11 PM
Acceld Z's Avatar
Car: 1992 Z28
Old Feb 6, 2002 | 10:26 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
You can do it several different ways.
I am using a fuel pressure gauge sender, a fuel pressure safety switch, a schrader valved fuel pressure relief/test port, and nitrous supply all off the fuel rail port. Here is a pic:
<iframe align="left" width="100%" src="http://www.geocities.com/irockz4me/irockz/pics/eng2.html">
</iframe>
It is difficult to see all of the components I used in this picture, but here is the list starting at the fuel rail port going towards the fuel solenoid.
after removing the valve core form the rail port, I screwed on an NX adapter manifold (D4) with #-04 AN female inlet on one end, #-4 AN male outlet on the opposite end, and a female 1/8" NPT port in the middle. I screwed the fuel pressure gauge sender into the NPT port. On top of the manifold I screwed an Aeroquip #-04 AN 90° hose end and a short section of #-04 hose with a straight #-04 end on the other end. This screwed into the male end of a second NX manifold. This manifold also originally had only one 1/8" NPT port in the middle but you can buy them with multiple NPT ports. I drilled and tapped a second port sized 1/16" NPT in the side of this manifold. I screwed the NX fuel pressure safety switch into the 1/8" NPT port and I screwed in a Ford fuel pressure test port with schrader valve and cap into the 1/16" NPT port so I could have a place to attach a hand held gauge, and/or release fuel pressure without having to take something apart. The Female end of the manifold screws onto the #-04 to 1/8" NPT adapter that screws into the fuel solenoid.
Old Feb 10, 2002 | 05:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
here is one solution, although it will not fit on the fuel test port, it will fit beween the fuel selenoid and the line coming from the test port. the ones in the picture have only one port and in one picture it has a Hobb's pressure safety switch. the holes are 1/8" npt and it is -4 male one end and -4 female on the other (-6 available). you can get a multiport -4 manifold (similar to single port pictured) at http://www.outlawperformance.com/d4manwitmulp.html
Old Feb 10, 2002 | 06:58 PM
IROCKZ4me's Avatar
Thats what the NX manifolds that I used look like.
The -04 size fits right on the factory fuel rail port.
Old Feb 10, 2002 | 07:10 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
these are the NX ones. But, on some vehicle the clearance next to the fuel rail is too tight (like late speed density cars with a MAP sensor) to mount the pieces it can also require the provided fuel line be mounted in an undesirsable way (straight up) above the TPI itself.
Old Feb 10, 2002 | 07:25 PM
IROCKZ4me's Avatar
Yeh, if you had the MAP senser in the stock location on the side of the plenum the manifold may not fit on the rail without relocating the sensor. When mounted on the fuel rail, the top of the manifold is just below the bottom of the plenum. You could use a straight hose end on it but it wouldn't look the best. As you can see in my pic I used a 90° hose end there. I think it all made for a very clean looking install considering all that is hooked up to it.
Old Feb 10, 2002 | 09:05 PM
Acceld Z's Avatar
Car: 1992 Z28
Thanks guys
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
Fronzizzle
Aug 9, 2015 01:15 PM
1nastygta
Aug 8, 2015 07:38 PM
