Biggest wheel clearance?
Old Nov 21, 2002 | 02:18 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
I'm currently putting together a 6-pot front caliper set-up together.What I need, is an idea of any 16" or 17" wheels with a spoke pattern which would clear the caliper.The caliper sticks out about 30mm (inc. 5mm for clearance) from the hub face.Anybody run big brakes with this sort of problem?Absolutely any help with this would be great.Thanks
Old Nov 25, 2002 | 05:06 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
You could run C5 or 4th gen rims with a set of 2" billet wheel adapters. That'll give you plenty of clearance! We've got quite a few folks road racing with them.
Old Nov 26, 2002 | 12:03 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Hell yeah, Askulte is the man to talk to on this.. He's got what you need to get these C5 rims mounted with no problems.
Old Nov 26, 2002 | 02:16 PM
CrazyHawaiian's Avatar
Car: too many ...
Or you could contact a wheel manufacturer with a style you like and see if they can check or maybe even custom make to fit. I went with Boyd Coddington and had a set of 18" wheels custom made for my 91 Z. Took them about a month. And when its all said and done, its the same price as 4th gen wheels + adapters. Plus you get a direct bolt on fit. Up to you though. Mr. Skulte makes some awesome adapters.
New2Chevy
Sep 28, 2015 12:35 AM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
L0tuS
Sep 4, 2015 11:16 PM
