Serpentine Belt?
Old May 6, 2005 | 01:22 PM
benscool1's Avatar
Car: 1985 Berlinetta
Engine: Carbed 305
Transmission: Built 700r4
Serpentine Belt?
Can you get a serpentine belt that is the right size so I don't have to use the smog pump? I have one that is locked up and I thought it might be cheaper and easier to just run a smaller belt. If so where can I get one?
Old May 6, 2005 | 01:26 PM
allsound's Avatar
Car: 1987 Camaro Z28
Engine: 305 carb for now
Transmission: 5 speed
I'm 95% certain that you can get one from any parts shop
Old May 6, 2005 | 04:08 PM
AsphaltAssalter's Avatar
Car: 92 Camaro
Your going to need a longer belt and you will have to reroute it, there is an article in the tech section about it, i did mine and needed a belt about 95" long.
Old May 8, 2005 | 02:20 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
I was looking at a friend's chevy pickup today and noticed that it was basically the same engine setup (TBI), but it does not have an air pump. What it does have is an idler pulley there, and the pass aluminum bracket is smaller. I am thinking about going out to the bone yards and looking for an early 90's pickup to grab that bracket piece from. (Just because I hate the way that thing looks just sitting there without anything in that pump mount)
Old May 8, 2005 | 02:57 AM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
if u delete the smog pump, dayco makes a belt, PN# 968k6 essentially it is a belt that is 96.8 inches long, and has 6 ribs. as for belt routing, starting at the crank pully, your going to go up over the ac compressor, under the idler pully, over the alt, then down & under the power steerin pump then up and over the water pump and your done. hope this helps
Old May 8, 2005 | 08:04 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Derek's got it. Theres also a tech artical in the tech section with a picture.
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
