how much power can a 700R4 handle stock?
Car: 81 Camaro
Engine: 406w/TPI & Serpentine belt setup
Transmission: 700R4 & 3.42 Posi
Basically, same as subject. How much Hp/TQ can a stock 700R4 withstand? I've got one that I bought off of someone.. Supposedly, it has an 11-vane pump, corvette servo, and a shift improver kit.. and 31-spline input shaft.. If it has all this like it is suppose to, would it be safe to install it behind my 300hp/375TQ 400sbc? Also, using the stock torque converter. I have a 3.42 posi & a cam like 2 steps above stock.. probably 224 - 230* adv. duration.. I think it's a 270 magnum cam, but not sure..
If it doesnt have the upgrades, and is stock, would it be safe to install it if i took it easy?
Thanks for any advise & input..
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I blew my 700 at least 6 to 8 times, and the car was mainly stock. Part of the problem was the %#@$ *** bandit that was building it. But yours sounds like it will hold up.
Car: 81 Camaro
thanks formula... How bout the torque converter? would there be any adverse affects of using it with a cam like the one i mentioned & 3.42 gears?
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
it will handle 300hp no problem, i wouldnt worry about that. ive seen em handle more then that. what year did it come from? 89+ is when they starting beefing them up.
Car: 81 Camaro
Iroc8t8
May 4, 2026 08:09 PM
