Borg Warner rear broke
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The posi is worn out. In the case of a 9 bolt, the clutch cones and inner housing is worn.
I am not allowed to post a link or give you information on this, so hopefully someone else will!
Miles
Miles
since i am try www.9bolt.com they have a lot of 9 bolt parts and great people and service
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
Miles
Miles
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Thanks ede!
The cones ride against the inside of the carrier halves. As the cones wear, they ride deeper into the carrier. Once they bottom out, then the posi stops working and the cones start chewing up the inside of the carrier halves. The only way to know for sure is to take it apart.
no problem miles, i'm not really such a bad guy, i just play one on www.thirdgen.org
Car: 1999 Z28
Thanks ede!
Thanks ede!
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
If this is any interest, I saw a 9-bolt on a '85 T/A in the boneyard yesterday. No one had even messed with it yet. Tires were still on the rear-end. Still had the tag on the back. If it is still there tomorrow, I will pull the cover and take a look at the gears.
Originally posted by SLP IROC-Z
alright so it should be visible, would this wearing of the carrier cause a "clunk" or somethin, i have two nine bolts that clunk going into gear.
The other will clunk and spin both tires on wet pavemant AND dry pavement.
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
correct me if I'm wrong, but from what I've been told, most of the time, true posi rearends make a clunk. don't know why, they just do, prob something to do with the posi unit.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
No
A posi unit should not clunk.
The clunking noise is coming from excessive back lash, or play in something. If the posi doesnt' work, the cone clutches are worn out/and/or the springs are weak. In my expirience, it's usually both. It's as simple as that.
theshackle
Sep 17, 2020 08:26 AM
