SFC's Where do these "tie in" up front
Old Jul 21, 2003 | 07:52 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I am thinking about purchasing some SFC's....probably spohn's but I am still figuring that out. But the question I had is does anyone have any pics showing where these things sort of tie into the body/frame rails up front???? I am trying to get a visual as to where these things need to be welded.
Thanks,
Old Jul 21, 2003 | 10:53 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I always wondered the same thing, if you look at the sticky someone posted a picture for me and a link to other pic's.
https://www.thirdgen.org/techbb2/sho...5&pagenumber=1
I ended up going with the alston's, they connect much beter imo to the front rail. The spohn's just tie into the frame extensions behind the front wheels and have a extension that welds between the front rails at the trans mount to the sfc's. I was going to have to do some heavy mods to make spohns connect like I wanted.
I did get some pleasent surprises from the install. After putting it up on the lift(roll on type) and drilling bolting and then welding. I roll it off the lift, and I notice the front to rear is actually level now. The car launches better. The steering is more responsive. And it cut down on nose dive during braking. So all in all I lke the alstons. The one thing I like spohns is it connects to the LCA's and not the rear frame rail. This gives for a better suspension point. But I plan on tieing the LCA mount and the rear frame togeter.
Not to mention the handling improvements, the car actually does weight transfer's correctly in hard cornering. I can get the nose down and pull a curve much better now. With alot less sqeal from the tires. After I get the poly bushings installed and my 16" wheels and tires installed. She should handle like shes on rails.
I was afraid that my car wouldn't see a big improvement, my car has always seemed thighter than any other I have driven around here. but I did.
Old Jul 21, 2003 | 11:28 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Thanks for taking the time to write such a detailed response.....I took a look at things and there are some good pics in there which help me sorta get a "picture" of how these things come together.....thanks alot!
Old Jul 21, 2003 | 11:35 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
No prob, I am a programmer so I type like 80 wpm, it doesn't take that long to type it out when you type fast LOL. Good luck withe the decision, but any will greatly improve the car.
Old Jul 22, 2003 | 06:02 AM
ebmiller88's Avatar
Here's the driver's side of mine. I made the small piece of extra metal you see to take up space. The passenger side butts up against a small ledge of metal so it's a bit easier to see when you trial fit them.
Ed
Attached Thumbnails SFC's Where do these "tie in" up front-drvr-front-brace.jpg
Old Aug 28, 2003 | 01:18 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
Those kenny brown pics is what I'm going with. Thanks for the pics. Now that I see a concensus of what is out there, I am suprised to see what they are charging! Its a couple of feet of tubing. Perfectly easy project that I can get out of the scrap bin.:rockon:
Ghettobird52
Apr 21, 2020 08:44 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
zayne0
Aug 24, 2015 07:22 PM
