Burnt 3-4 clutches
Old Jun 20, 2003 | 06:44 PM
tpi_roc's Avatar
Burnt 3-4 clutches
What would cause my 700R4 to burn the 3/4 clutches?
The transmission has aproximatly 30k miles on it
Hayden cooler
vette servo
B4C wot upshift valve
superior shift kit (ick)
They toasted as I was passing a car, no more tranny.
Whats the most likely candidate?
Old Jun 20, 2003 | 06:50 PM
tpi_roc's Avatar
and a 2,500 rpm stall
Old Jun 20, 2003 | 08:23 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
how hard do you drive your car?
the 3-4 clutch pack is the 700R4's weakest point (of many)
Old Jun 21, 2003 | 12:55 AM
tpi_roc's Avatar
In no way that should result in a 30k mile life of a tranny
its been a year to the date since it was installed
Old Jun 21, 2003 | 03:50 AM
Pro Built Automatics's Avatar
In fact, the way you drive the car, the TV cable adjustment, and that the "Inferior", excuse me, Superior valve body kit does nothing for the 3-4 clutch pack, has "everything" to do with it.
Old Jun 21, 2003 | 12:35 PM
tpi_roc's Avatar
Believe me the superior kit was just a turn of bad luck
I had the transmission built by a less than straight forward guy, the only thing that made it INTO the tranny per my spec was the vette servo and b4c valve. I had worried about that kit from day one.
Would it be reasonable to replace the bands and install a new kit and go? Or do I ***need*** to completely rebuild it all?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Bigold4x4
Sep 28, 2015 05:21 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
