If I swap in a th350 what do I need??
Old Mar 5, 2003 | 11:41 PM
TBI305Camaro's Avatar
Im going to get a th350 with a 9'' tailshaft so my driveshaft will work. I need a crossmember, stall and what else? Dont I also need some type of torque arm mount?? if so where can i find it?
Old Mar 6, 2003 | 12:17 AM
firestarter's Avatar
Car: 86' camaro s/c
Engine: 357
Transmission: th350
I'm in the middle of this swap now. You need a torque arm mount from b&m part # 30299 about $80 from summit. It will contain most of what u need. Of course u'll need the obvious...new trans fluid/filter. new trans mount is also a good idea. hope this helps
Old Mar 6, 2003 | 08:59 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
unless it has the 9" tailshaft you will need the driveshaft from a fbod with a 200r4 in it.
Old Mar 6, 2003 | 10:50 AM
definitive1's Avatar
Just did this with the b&m kit, was very unhappy. If you use the b&m kit you still need to get a new torque arm mounting bracket from GM. They give you 2 part numbers and you have to figure out what one you need. I didnt even bother, I got the torque arm up there temporarily, and Im waiting to put in Spohn's adjustable torque arm for the th350 sitting in my basement. It has a new crossmember and everything made for the 350, so you dont need any kits, just the shorter driveshaft. Its really worth it if you're going to do it right.
Old Mar 6, 2003 | 03:29 PM
I was going to get a ATI TH350 but im thinking about getting a ATI 700r4 possibly. Not sure yet. looks like ill be spending the same amount of money either way now. to much cash....
buddy has a 87 camaro with a 700r4 he will sell me cheap but id rather not get another tranny that has alot of miles and is stock. I plan on heads and cam for sure so that would probably destroy another 700r4. stock one anyways.
so for a th350 swap im gonna need
crossmember-100$
stall-~200$
torque arm kit ~80$
plus a torque arm mount? any kits come with this?
I plan on making 375hp at the crank NA and nitrous eventually with 3.42 gears...should i get another 700r4 or a th350?
Old Mar 6, 2003 | 04:52 PM
Thats why I went with the 350, they can definitely take more power, and parts for them are alot cheaper. I got mine totally done-up, all high performance parts, gears, clutches, 2800 stall, transgo kit, for 700 bucks installed, I know the guy that runs the place, but I couldnt imagine it would be that much more for anyone else. I gave the guy an old tranny I took out of an old truck.
Remember youre going to need to get your driveshaft shortened or get one out of an early 80's thirdgen with a 200r4 tranny.
And your not going to need a new crossmember with the b&m kit, it has a plate for that, but you are going to need that part form GM, It probably isnt more than 30 bucks but I dont know for sure.
One more thing, If you like the lockup feature on the 700, dont go with a 350. I do about 3000 RPM on the highway.
Old Mar 6, 2003 | 10:15 PM
lockup doesnt work anymore anyways...i took the computer out of my car. I was under the impression I DO NOT need a new driveshaft with a th350 with a 9'' tail shaft.
Im also looking at the probuilt 700r4s now. Not sure what im gonna do.
Old Mar 6, 2003 | 10:31 PM
if you have a 6''tail, you can use the one you have. with the 9'' tail, you need to have a shorter one.
Old Mar 6, 2003 | 11:50 PM
Car: 86' camaro s/c
Engine: 357
Transmission: th350
Its a 9" tail will work, a 6" tail will be about 3" off! Yes the B&m kit has the conversion plate so u can use ur crossmember, i went ahead and bought one from and 82 200c camaro just for kicks. A $35.00 part used. If u don't mind running high rpms and need a cheap to repair/replace tranny that can take a beating daily, get the th350! I am takeing the one out of my chevelle i race in daily and i have about 375hp at the crank w/ 3.73's and its my daily driver. Tranny is mostly stock, can't beat it! Although the 700r4's i've had have blown in a matter of a week tops. Just food for thought. Not that hard of a swap either.
LittleFranks
Sep 17, 2015 12:22 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
