What kinda Torque Converters are u 305 TPI people using.
Old Mar 5, 2003 | 01:34 PM
iroc_cragg's Avatar
Ive been looking into getting a new torque converter for some time now and I would like to know what kind u 305 TPI guys are using. I was gonna get a Corvette Converter but the deal fell through. I also was looking at the B&M 2400RPM stall. Would that one be any good. Whats a good Stall Converter for a 305 TPI. Any info would be appriciated.
Thanks alot.
Old Mar 5, 2003 | 05:20 PM
Pro Built Automatics's Avatar
Depending on what you want to spend, I would avoid the B&M due to poor construction and a "high" comeback ratio. Use Continental, Precision Industries, A.C.T., Yank, etc. Anything higher than 2,200 rpm stall on a stock diameter torque converter can get very slippery. The Corvette torque converter would be a better choice. Don't cut corners when buying a torque converter.
Old Mar 6, 2003 | 06:32 PM
1991 RS 305's Avatar
I'm debating this same thing. At this point I'm thinking either the GM #24202310 ( 93-95 S-10, also known as "L-35" converter), or A.C.T. 9.5 2400 stall. The A.C.T unit , unfortunately cost more than double the GM piece, not sure if it will offer twice the bang. I've also seen a GM Corvette converter #24202174 , not sure how it differs from the "L-35" converter, but I believe it has the same stall, 2100-2200. Opinions?
Old Mar 6, 2003 | 11:31 PM
MdFormula350's Avatar
http://www.slponline.com/view_produc...RTNUMBER=60100
i dont have this, however this might be a good one to look into.
Old Mar 7, 2003 | 03:44 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
I had TCI break away converter few years ago at my -85 tpi z-28.I like that converter stallspeed(approx.2400 rpm).Works good ,only minus was that it wasn't lock-up type converter.Now i'm running with TCI saturday night special converter.Works good,but stallspeed is little low(approx.1800 rpm).i liked more that 2400 stall.
jaridjohn
Jul 8, 2024 03:49 PM
jklein337
Sep 19, 2018 06:23 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
gwade12
Aug 8, 2015 08:17 AM
