tv cable question
Old Jun 6, 2002 | 04:20 PM
pandorafowler's Avatar
Car: `91 rs
Engine: 352 TPI
Transmission: TH700 R4
tv cable question
If the tv cable is out of adjustment, would it cause the reverse to not work? I can put it in reverse and it acts like its in neutral and in neutral its in drive. After I rev the engine up, it goes back to working fine. Its a 700r4. Any help would be appreciated.:hail: :hail: :hail:
Old Jun 6, 2002 | 11:33 PM
blk91z28's Avatar
Maybe the shifter is out of adjustment at the transmission.Theres a lever mounted on the trans that the ****er cable is bolted too.Also check the fluid level of the trans.
Old Jun 6, 2002 | 11:47 PM
blk91z28's Avatar
Maybe the shifter is out of adjustment at the transmission.Theres a lever mounted on the trans that the shifter cable is bolted too.Also check the fluid level of the trans.
Old Jun 7, 2002 | 09:49 PM
Car: `91 rs
Engine: 352 TPI
Fluid has been checked twice this week. It only does it on a down or up grade when I park it. After I rev it up a little, it`ll lock into the correct gear. Its only done it twice.
Old Jun 8, 2002 | 11:12 AM
rsc350's Avatar
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
can not be tv cable, weird though, sounds like something minor inside the tranny, hope it does not turn into something major. Maybe you should not park there anymore.
Old Jul 5, 2002 | 02:36 PM
Nephilim's Avatar
pandorafowler
that happened to me in my 85 2.8 V6
it just stopped doing it after a while then about 3 months latey
the tranny went out all gears so it might need a new tranny
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
