Question about routing oil lines for twin turbos.
Old Dec 10, 2000 | 07:24 PM
Jester's Avatar
1. Should I put the oil pickup in the bottom of the pan..or can I put it in one of the existing fittings in the top on the block, like the one above the timing cover or behind the intake manifold...maybe one for each turbo.
2. Does each turbo require it's own lines, or can I run one line in, then one from one turbo to the next, and one return?
3. Should I weld the return into the oil pan, or is the valve cover sufficient?
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Dec 10, 2000 | 11:19 PM
Twin Turbo 358's Avatar
my oil supply is tapped in from behind the intake manifold at the top of the block (oil sending unit). the line goes into the drivers' side turbo and then across to the passenger side turbo. the oil return lines go straight down to each side of the oil pan (i've got AN fittings welded on the oil pan).
hope this helps...
Jeff
99 T/A WS6 A4, RKSport lid & free EGR mod
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Dec 10, 2000 | 11:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
I've seen a bulkhead fitting put into the fuel-pump block-off place for the oil return, might be easier to do if you don't want to drop your pan.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Old Dec 10, 2000 | 11:43 PM
GMI FAST's Avatar
Twin Turbo 358, I have seen the photos of your engine, and I have a tip for you. The oil feed you have shown will shorten the life of your passenger side turbo. The proper way to route the line is to "Y" the line in the center of the turbos or run separate oil feeds. By the time the driver's side turbo gets oil, there is not much volume or pressure for the other one. Just a tip, nice ride...
1989 Formula, 383", DFI, Mini-Ram, S-Trim Vortech, blah, blah...
Best ET: 10.796 @ 125.8 mph
TURBO 406 PROJECT STARTED!!!
Other expensive hobby: assault weapons/shooting sports
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association
www.mfba.org
Old Dec 11, 2000 | 09:47 AM
Jester's Avatar
I think I'll route the turbo oil in lines seperatly..one from the hole in the back of th eintak manifold..one from the hole above the timing cover....thanks guys.
Will that mess up the oil presure for the rest of my engine tho?
Old Dec 11, 2000 | 10:29 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I tapped off the oil galley at the rear top of the block with a 1/8" (or 1/4"?) NPT to 4AN tee. I ran -4An lines to each turbo, and then -10AN drain lines to the oilpan (45 deg AN to NPT swivel fitting) where I welded 1/2" NPT bungs on each front corner of the pan. You don't want any restriction in the drain, and it must drain above the oil level of the pan. Otherwise you'll have the oil backing up in the center section of the turbo, and seeping through the shaft seals and getting burned. The fuel pump plate I don't think would be free flowing enough for a drain, dunno about the timing cover (I tried to keep hoses away from moving parts like belts and pulleys). HTH!
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
Old Dec 12, 2000 | 06:37 PM
Jester's Avatar
Thanks Andris...what kind of oil pressure does your engine see with the lines routed that way?
JSP Motorsports
ICON Motorsports
Old Dec 12, 2000 | 07:44 PM
thanks GMI FAST! that will have to be on the list of things to change this winter. along with finding someone who can make me a set of custom fuel rails for my miniram...
Jeff
Old Dec 13, 2000 | 06:35 AM
Guido's Avatar
Car: 2000 Trans Am
Custom fuel rails?
Have you checked out how I did mine?
http://home.webworks2000.net/guido/fuel.html
Im not sure if you want to do this, but it IS one way of doing it.
Also, I remember reading somewhere that a chevy turbo kit had a drain on the fuel pump cover. It may not have been a Banks kitbut it was someone. I figured that would work just fine.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
Old Dec 13, 2000 | 09:48 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I see normal oil pressures (i.e. about 60 psi cold start, and about 20 psi idle to about 50 psi at WOT warm). I haven't driven the car since I snapped the axle back in October, so this is from my not so perfect memory I have a Sealed Power high volume / reg. pressure oil pump, BTW.
Jeff - A friend of mine got rid of his mini ram to go Super Ram again, and had a custom rail setup. He had -6 fittings welded to the end of each rail, and had it all metered with an SX fuel pressure regulator. I think he still has the rails if you are interested.
Andris
Old Dec 13, 2000 | 09:55 AM
Jester's Avatar
Is it possible to drill out the oil return line behind the fuel pump cover to a larger size?
JSP Motorsports
ICON Motorsports
Old Apr 9, 2006 | 01:10 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
I've been pondering doin a single turbo blow through setup on my 82 TA 358. I was thinking of putting in an oil cooler and feeding the turbo in series with the oil cooler, that way to cooler would cool the hot oil coming out of the turbo. Would this have enough pressure to work???
84z96L31vortec
Aug 20, 2017 12:16 AM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
