Talked with Holley about HSR and...
Car: 89 Iroc
Engine: 305TPI
They said it would work with the Vortec heads. What do you guys with the HSR think. Will it work or will you have problems with anything? Are the ports too tall or anything like that?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
considering that you can see daylight with a 1206 gasket, I have a hard time believing it'll work with vortecs.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
the bolt angles are way different. not that you couldn't elongate the holes. but they are also raised higher to boot. working on my new website dedicated to the stealthram. www.stealthram.com if you have one and would like a link to your site from there just email me with the link. plus any info is greatly appreciated.
It wont work without alot of fab work, and I mean alot!!!! Out of the box a Vortec intake port is just as tall as a 1206 gasket. The Stealthram takes a 1205 and leaves very little room for porting, a 1206 is not possible.
I have held all off these parts in my hand, it just aint close, someone has pics floating around here somewhere.
If it was possible there would at the least some converted LT1 intakes on Vortecs around but there isnt, cause it just aint worth it.
Car: 89 Iroc
Engine: 305TPI
Thanks for the info. It is kind of sad that the people at Holley are telling me that I would be able to use their intake with the Vortec head. If you would like I could paste the email the I got from them.
http://www.thunderracing.com/index.c...yid=1125#P2944
look carefully at the add! the stealth ram is not designed to work with vortec heads, (YES it can be redrilled to get the bolt holes alined & machined to get the ports matched fairly simply at a machine shop and can be made to work but its beyond the average home hobbyist level to do so, IF your looking to get the ports exactly matched!)
HERES VORTEC HEADS
heres normal 23 deg heads
notice the slightly differant ports shape and bolt hole locations and angles of entry and the non-existant center bolts on the center two bolt locations, BTW some vortec heads ARE available drilled BOTH WAYS from some of the chevy dealerships
HERES VORTEC HEADS
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
the_hamturdler
Sep 30, 2015 12:50 PM
