VSS scaling
Old Apr 2, 2003 | 02:23 AM
Odyssey's Avatar
VSS scaling
Hey everyone. I was wondering if anybody successfully modified the VSS data in the chip in order to calibrate the speedometer. I have WinBin and a 730 ecu file, and I tried to change the VSS ratio with no results. The speedo stays unchanged. The way I understand it, the ECM has a hardware frequence divider and a serial interface that it uses to pass on that information to the speedo board. (inside the cluster). Is this not true ? Anybody have any info on this ?
Old Apr 2, 2003 | 11:57 AM
CheezX's Avatar
The VSS ratio only changes what the ECM sees. There's another divider value for the speedo. I changed it for my T56 swap and it worked.
Here's the web page I got the info from copied and pasted (it doesn't work any more):
1992 1227730 VSS re-calibration after a T-56 swap
NOTICE: These instructions are provided for educational and benchtop experimental use only, by advanced hobbyists and the like. Amatwur twiddling with engine control parameters in vehicles intended for road use is not what I am advocating here. Recently it has been discovered that people (imagine!) are selling info like this, found on the net, on Ebay. This info is FREE and you get what you pay for.. no warranties, guarantees, or promises. Steal this info and sell it and rot in the hell of boiling sewage.
ON to the IN-Fooo...
After my T56 swap I discovered that the conversion boxes for getting the speedometer and the computer to read the correct vehicle speed were like $90 and more, and were rumored to be troublesome (although I have no direct evidence that they are). I already have adopted the "fewer parts to fail" attitude so I did not want a little bug to be there and have to stay working all the time for me to drive my car. Given all that, I thought I'd look into making one myself. Well after some research I found that my 92 ECM and my 92 instrument cluster both supported a scaling factor parameter, set on the chip. It took a while to figure out the scaling for the Speedometer factor but trial and error prevailed.
Its trickier thsn most settings on the '730 ECM..since the ECM variable is OR'd with a value that already has meaning in the code, only a certain set of values can be used. For those technically interested, here is the breakdown of the Speedo scaling variable, best guess so far:
The 3 high order bits at 8014 in AXXC (92 305 TPI M5 3.08) control the scaling of the speedo in my application (remember, I do not know at this point, nor do I care to go find out, what other years this applies to. I know the 90 year F car uses a magnetic VSS where mine was optioned for the optical unit. this does not nessecarily mean the re-scaling wont work.. in fact, the scaling bits ARE sent to the external hardware when the MAGNETIC *OR* OPTICAL sensor is used.). This is a hardware divider sent via SCI (serial control interface) from processor to a descreet circuit. from the best I can gather at this point, thru eyeball testing is this:
00000000 0 =do not divide (aka div by 1)
10000000 128 =divide by 2
01000000 64 =divide by 3
11000000 128+64 =divide by 4
00100000 32 =divide by 5
10100000 128+32 =divide by 6
01100000 128+64 =divide by 7
11100000 128+64+32 =divide by 8
6.17.01
Ignore the "divide by" figures in the chart above... Here is some new test data:
Drive Testing results:
Observed MPH , 4th gear, @ 2500 rpm
bit 7 set: = 96 mph
bit 6 set = 83 mph
bit 7 and 6 set = 73 mph
bit 5 set = 65 mph
bit 7 and 5 set = 58 mph (closest I can get.. pretty dead-on using a chase vehicle)
bit 6 AND 5 set = 53 mph (amazingly, I still have room to go)
So bit 6 corrects to 86% of what bit 7 corrects to.
bit 5 corrects to 67% of what bit 7 corrects to
When bit 6 AND 5 are BOTH on, the correction is about 86%*67% of what bit 7
corrects to. (58% by math, 55% by testing(eyeball speedo))
For reference:..
@ 2500 rpm... 1:1 trans gear, 3:08 ratio (I'm going about 58 mph.. turns out)
B7 b6 b5 b4 b3 b2 b1 b0 (b4-b0 are not used in the correction)
B7 set = (10000000) value of 128... speedo reads 96 mph
B6 set = (01000000) value of 64... speedo reads 83 mph
B7,B6 set = (11000000) value of 192... speedo reads 73 mph
B5 set = (00100000) value of 32... speedo reads 65 mph
B7 , B5 set = (10100000) value of 160... speedo reads 58 mph
B6 , B5 set = (01100000) value of 96... speedo reads 53 mph
When I set B7, B6, and B5 all together (11100000).. ths speedo just reads Zero.
When NONE of these 3 bits are set (the factory setting), the speedo pegs 110
when I'm going 15 mph. The SPEED LIMITER will shut your injectors off if you
do not disconnect the VSS from the trans... but disconnecting the VSS makes
then engine stall when you come to a stop, because the ECM does not know
that the car has transitioned from moving to not-moving.
Imagine ASSUMING any of the above!?! the numbers are way out of order.. but
if you look hard you can see that the significance of the bits is reversed. look
at 128(b7) as being "1", 64(b6) as being "2", and 32(b5) as being "4" and it all
makes sense ;-))
Old Mar 25, 2005 | 06:35 PM
92Z-666's Avatar
Car: 92Z
Engine: 6.6
Transmission: 6
Amazing that this info is still kickin'
My web page changed a few times.. but I always left links behind for the lost. I don't use metatags I think if someone wants the good stuff it should be a little harder than a google search.
http://www.eecis.udel.edu/~dzug/92z2...0-vss4T56.html
man that was a while ago... Note the "let me know how it works out!" part at the end. Anyone wanna guess how many people emailed me?? :-) Thats okay.. I didn't do it for money OR fame :-)
BTW Cheez... Nice job leaving my disclaimer in. :-).. You did a swap... Did you get one of my 6-speed shift plates?
http://www.eecis.udel.edu/~dzug/92z2...hiftplate.html
... same statement.. not done for money or fame... but I *HAD* to do something before someone used 5th to back into a dragster or somethin' :P
$750 L98
Feb 1, 2025 02:25 PM
GTAman
Jul 3, 2024 07:29 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
paul_huryk
Oct 1, 2015 04:27 PM
