does the transgo reprogramming kit solve WOT 3-4 shift?
Old Jan 6, 2004 | 09:02 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
as subject says does it solve 3-4 WOT on 700's? or is the GM B4C kit required?
Old Jan 6, 2004 | 10:32 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
No shift kit will solve this problem. You need the overdrive shift valve. I think the B4C cars used the right valve. Most aftermarket ones won't complete the shift at WOT, only at 3/4 throttle or less.
Old Jan 7, 2004 | 06:36 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Part #8673948 for new factory upshift sleeve for WOT upshift into OD.
Old Jan 7, 2004 | 05:34 PM
chevypower's Avatar
Car: '89 Formula, '97 Z28, '88 Formula 350
Engine: 305 TBI(LO3)
Transmission: TH700R4(MD8)
I used the B&M upshift kit, and its nice. The car goes into overdrive where it used to stay in 3ed. Now I can just bareily let off the gas and it goes in OD. I feel I gained a good 20-30 mph topend.
Old Jan 7, 2004 | 08:46 PM
Car: 1988 IROC-Z
i have ordered the B4C kit. thanks alot.
86Firebird86
Dec 26, 2015 07:21 AM
FormulasOnly
Sep 6, 2015 10:42 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
