Body Modifications Plan
Old May 8, 2002 | 04:10 PM
un4givin89's Avatar
Well, I have mapped out the project for this car, the real sleeper. Zero Profile as I like to think of it.
The car will have no identifiable markings to hint to which of the carline series it is.
I plan on replacing the doors with fiberglass door skins, fiber glass front fenders, and fiberglass 2inch crowl hood.
I want to smooth out all the body lines, and blend the gfx into the car remove the side molding and shave the door handles and antenna. I want nothign but perfectly str8 lines. I am planning on getting the IROC spolier from ASCD. Also tint the windows to the legal max all the way around.
I think I might be forgetting something, I'm not too sure.
As for the engine, it'd be a 383 TPI, me and my g/f are still doing or research on this, but we are gonna build her from scratch, and now that I have a good cash flow coming in, (NEW JOB) the engine shouldn't be more than a 2 1/2yr project!
All the seriously awesome cars around here weren't done in a few months, so no rush. =)
Gonna start body work within the next week or so. =)
What do you all think?
Old May 8, 2002 | 04:42 PM
pontiac90's Avatar
I think that that will look very nice/sleek. Are you gonna keep the car the same color or repaint it? How do you plan on smoothing the seem betwwen the body and the GFX? Good Luck!!
Old May 8, 2002 | 05:14 PM
un4givin89's Avatar
It will remain black
Thats a good quesiton, a few members have tried before and not had much luck, i plan on doing some reasreach on this, possibly custom fabircation, not sure about that just yet. The main problem is the car expanding and contracting do to weather....
Old May 8, 2002 | 05:23 PM
Bill Krumel's Avatar
Looks like a very nice plan un4givin89...
What made you decide to keep the RS???
On the IROC rims are you going polished or chrome?
Are you doing the body work yourself?
Lastly, How much are you budgeting or estimating
for this project?
Old May 8, 2002 | 05:31 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i think you car is going to look really nice. good luck
Old May 8, 2002 | 06:19 PM
un4givin89's Avatar
Long story on the IROC, I might get one later, but I came to the final conlusion that I couldn't give up the RS either, and gave my friend his 1000 deposit back.
I am going to do all of the body work myself, the great thing is, I have alot of knowlegde in this area, building the engine is where I will do all my learning. When I owned my Cutlass with the famous rocket 350 I did alot of serious body work to that car.
I'm not sure as for a budget, becuase i think of this as a long term project the body work should me mostly low cost, except for the hood and fiberglass panels.
I'd except around $3000 total for body work including paint.
It will remain black yes, 3 base coats, 5 clear, and wet sanded =)
I can take care of most of those this week, gonna remove the stupid lil pin stripe, pull the antenna off and the emblems are already off and pull the door molding as well.
The rims, I think I'll just clean them up, i dont' want them chromed out or overly shiney.
Old May 8, 2002 | 07:03 PM
CrazyHawaiian's Avatar
Car: too many ...
Thats gonna be a really nice car!! Are you sure you want to do 10% tint on the windshield though? Its gonna be really hard to see at night with oncomming traffic headlights and all .. I had 45% on my windshield for a while and it was good. Infact, in my truck I have 35% on the windshield and I think its perfect. Looks like your car is gonna kick ***!!! Hey I might have a tip on the smoothing but its gonna take alot of work ... I thought about doing what you wanna do before I bought the 91-92 GFX. I planned to take out the RS emblem out of the sideskirts and fill it in, as well as smooth the sideskirts to the body. The main problem is the bondo will have nothing to grip to. You can sand it all down and apply but vibrations from driving will cause it to come loose. I think the solution involves drilling small holes into the top of the sideskirts and the bottom of the door and using a wire mesh (maybe chicken wire?) to create a frame for the bondo to hold on to ... so once you have this ugly looking mesh along the bottom, you bondo over that and then it should grip better. It will look whacky when you're doing it but the final product should look good. There's prolly better ways to do this but thats my idea. hehehhe
Old May 8, 2002 | 07:45 PM
un4givin89's Avatar
I was thinking of somethign stronger than bondo , like a fiber glass resign, but that is an excellent idea actually. I will have to talk to some people about that and do some tests...
Old May 8, 2002 | 08:53 PM
juxstapo's Avatar
Ahh, you beat me to the punch, you wouldn't be piffed if I did this too eh? (Posted pic with annotation)
The car is going to be madd coo, by the by.
Old May 9, 2002 | 01:20 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
I didn't see a toggle for the 180 degree trick-braking......???
Old May 9, 2002 | 02:15 AM
un4givin89's Avatar
Let me lay to rest the trick braking once in for all, i finally found the correct wording for were i read that from, and what I was gonna do back in the day when i bought my car:
Ever wonder just how the car did those great 180 degree turns? While it was the skill of the stunt drivers like Bill Shelly, it was also done with mechanics.
A brake differential lock was used and tied into the master cylinder and actuated by a toggle switch. When activated, the front brakes were disabled and only the rears were active when the brake pedal was pushed. End result was the famous "bootleg turn". The system was restored to full braking when the toggle switch was hit again by the stunt driver.
Old May 9, 2002 | 07:06 AM
Bluerocket's Avatar
Heres a start. That 5 mins of time on photo shop. I had nothing to do in my class
Old May 9, 2002 | 07:11 AM
Bluerocket's Avatar
the other
Old May 9, 2002 | 09:00 AM
scauffiel's Avatar
Fiberglass is the only thing that's held so far.
Oh yeah, in your pic you might as well go ahead and shave the door lock too.
It's not like you'll be using it.
S.
Old May 9, 2002 | 09:06 AM
un4givin89's Avatar
I just learned you can't run at the track with shaved door handles, maybe I'll grapht some different door handles in its place....
Old May 9, 2002 | 07:47 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
hey mike, what about the door handles off of a 88-98 chevy 1/2 ton pickup?
you could fit them flush to the body, plus, no handles to stick out and smack the air.
Old May 9, 2002 | 08:09 PM
no_car_yet's Avatar
i say keep the pinstriping, the rest sounds pretty good
Old May 9, 2002 | 08:13 PM
juxstapo's Avatar
I take this to mean you wouldn't be miffed if I posted something similar?
Old May 9, 2002 | 08:17 PM
RSFreak's Avatar
Transmission: TH700R4
Sounds like a good plan. I wanted to get an 'IROC' spoiler from ASCD, but last time I checked, they weren't advertising it anymore.
Old May 9, 2002 | 09:26 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Hmm... weird. You said something about a tree falling on the IROC in another post. Get your story straight.
Old May 9, 2002 | 09:31 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
doorhandles
Something different...
Old May 9, 2002 | 09:37 PM
un4givin89's Avatar
deadbird, what handles did you use? I remeber reading your orginal post, excellent job by the way
Old May 9, 2002 | 09:52 PM
deadbird's Avatar
Engine: TPI 305/ v6
A courteous remark for un4given ?? wow.. I'm honoured .. j/k
(I'm not interested in past quibbles you've had with comments made so I'm not going to go there..just bs'ing ya)
The handles are off a 95 (or so) Intrepid but, are also on Neons & I believe the Stratus.. not sure about the last car.
I can tell you this and others who seek to get rid of the crap GM box handles, graphting new handles onto you car is no easy feat and, if you don't have at least some metal working exp, it's not something a DIY'er should attempt. It is not a simple swap. To pay someone to do it (like a bodyshop) would (IMO) not be worth it either unless you've got money to burn.
Even the seen before full size chevy truck handle swap is no easy venture. There are ways around having to use a welder but, not a durable. Just my opinon, I could be wrong.
Old May 9, 2002 | 10:36 PM
Azure's Avatar
Hey, yeah! Lightning struck a tree and it fell on the IROC!! The insurance money was going to mods...! WHew, MetalliCamaro, thanx for keeping up with this soap opera, I'd lost track!
Old May 9, 2002 | 10:54 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Its a tough job but someone's gotta do it.
The money is actually coming from his high end job he has making like $75K a year at 19 which he is so proud of. Don't get me wrong, if you really are making that much money, legally, at 19, thats great, good job. But its hard to believe anything this guy says now..
Old May 9, 2002 | 11:07 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Hot Rod Mag put in some flush Corvette handles awhile back.
Old May 9, 2002 | 11:49 PM
un4givin89's Avatar
When did I ever say I was making that kinda money?74K yr?? hahaha, in my dreams maybe... Is it your personal problem to start something in all of my posts?
For you information, I'm currently working as a photographer/web developer for several real est. firms in this area, taking pictures of homes and mantaining their websites.
I'm not even gonna drop to your level in this post, back to the topic...
Deadbird.... Metal working skills I have some of lucky for me. When I had my Cutlass before the Camaro I had to replace the flor pans and weld an quater panel back in place along with repairing some serious rust through spots.
I do like the idea of the door handles flush, but I'd have to do alot of looking at door handles, the one on your car looks great, but the over all shape in my personal opinion is too cruvish (real word?) for the car lines...
Thanks for imput
Old May 9, 2002 | 11:59 PM
Car: 1989 IROC-Z
Engine: 383 stroker
The $75K a year was an exaggeration. You always brag that you make this and that at 19.
It's not my personal problem to start stuff in your posts. Maybe if you would stop contradicting yourself all the time, I wouldn't feel the need to bust your *****.
This "friend" you gave the deposit back to- is he the same "poor kid" who was actually gonna buy your "crappy car with all the problems" for so much? I remember a previous post by you saying some poor kid was actually going to buy your car. If I am remembering incorrectly, I apologize.
If I wouldn't have brought up your differing stories, I'm sure someone else would have noticed. I don't think I'm the only one reading the Appearance and Detailing board and the Body and Interior board.
Old May 10, 2002 | 12:13 AM
Azure's Avatar
Hell no you aren't, and I hate to break up a good thread with this stuff. Unforgivn, I like a lot of the ideas, they look like a decent plan...but when you just go shooting your mouth with really stupid lies and then not expect people to question you, there's a problem. I can't help but mention the IROC bullsh!t (that never existed..? Was yours but got struck by lightning? Wasn't yours...? Exploded during a freak trick-braking and imagin-NOS experiment...??) because it was SO blatant...it makes anything else you say look pretty unbelievable. "I'm not even gonna drop to your level in this post, back to the topic... " Sheesh....I think lying about owning a vehicle just to impress some people on the internet is bottoming out pretty low...
Old May 10, 2002 | 12:49 AM
un4givin89's Avatar
wait? how have you come to the conclusion i don't own this vechial?
Old May 10, 2002 | 12:53 AM
Azure's Avatar
I was referring to the IROC that either a) Got smashed by a tree that got hit by lightning or b) You didn't buy off of your friend.
Old May 10, 2002 | 03:21 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Not to start anything, but Mike, I know you personally.
When I say I am going to do something, I usually do it.
I want flush door handles. Someone needs to write a tech article. I'll volunteer my car for this purpose, I just need someone to come and do it since I don't have the skills.
Old May 10, 2002 | 06:50 AM
Mirsiro427's Avatar
Yood think a guy hoo bilds and manetanes websites wood be a bedder spellar.
Old May 10, 2002 | 06:57 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Not too bad, but you misspelled thirdgen in your profile sig.
Old May 10, 2002 | 07:03 AM
RCR's Avatar
RCR
BTW, keep the personal crap out. If you don't like each other,(you know who you are) stay out of each others posts. Pretty simple really...
Old May 10, 2002 | 07:27 AM
un4givin89's Avatar
MAnny, i will send you 20 bucks in a week, just relax. I am already pulling most of that off my car, gonna cover the antenna this Sat.
The doors, prolly not for awhile, but I do have acess to my uncles arch welder.
Deadbird is the main guy on this topic, can ya give us any tips?
Old May 10, 2002 | 07:39 AM
Zepher's Avatar
I know you are good for it, Mike, I am just giving you a hard time.
You can swing by if you'd like.
Old May 10, 2002 | 11:29 PM
un4givin89's Avatar
can you break a 100 for me?
Old May 11, 2002 | 01:36 AM
Zepher's Avatar
ya, I can break 100.
Old May 11, 2002 | 02:25 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Good to see you two getting along us virginians need to stick together!
Old May 11, 2002 | 06:42 PM
Jza's Avatar
Jza
LOL.. what's a thridgen? In a graphic no less.
Old May 11, 2002 | 07:41 PM
dsaint1347's Avatar
LOL, thats just the ghetto in him.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
gta90
Sep 15, 2015 04:00 PM
PestilenceIV
Aug 20, 2015 02:33 AM
