Mirror
Old May 18, 2002 | 05:16 PM
Morley's Avatar
Mirror
Does anyone know where the auto dimming mirror hooks to the fuse block on the mid 80's Camaros? It also has a single green wire that I suspect hooks to the drivers door pin switch to keep the mirror from moving when the light comes on when opening the driver door.
Thanks.
~M~
Old May 18, 2002 | 11:15 PM
2vmodular's Avatar
light green wire is to inhibit the mirror from dimming when the gear selector is in reverse. should also be a wire for ground, and one that is hot when the ignition switch is in the run position.
auto-dimming electrochromic mirrors are neat toys especially if you get one that displays compass and thermometer readings.
http://www.geocities.com/modularmotor/gentexmirror.html
Old May 19, 2002 | 09:58 AM
Morley's Avatar
Thanks for the info. The mirror I have is the motor controlled one with all the wiring and connectors, from a 3rd gen Camaro.
~M~
Old May 19, 2002 | 09:07 PM
2vmodular's Avatar
an interesting point. gentex manufactured the motorized autodimming mirrors for thirdgen f-bodies. gentex also supplied the same model motorized autodimming mirrors to ford for t-birds, aerostar vans, various lincoln models, etc.
ford mirrors go for cheap money on ebay, but as soon as the auction title contains an f-body reference (i.e. z28, iroc, camaro, etc.) the ending price of the auction is considerably more expensive and often exceeds $50.
Pac J
May 17, 2020 10:44 AM
1992Z28!
Nov 19, 2015 07:33 AM
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
scottmoyer
Sep 7, 2015 07:06 PM
