Interesting EGR operation??????
Old May 19, 2002 | 12:26 PM
Psmurf's Avatar
Hello to All! Been browsing the BB for some time now and picking up a lot of good info. But I have run across a wierd problem with the EGR on my TBI, but could not find an answer for it.
So here is the issue it has. History on the 92 TBI (this is a 350 from a p/u), rebuilt the motor .030 over, put in a comp cam 12-388-4, run an open element air cleaner, thorttle spacer, every thing else is stock. The computer is from a 92 Suburban. Bought a harness from Howell, and dropped the engine in my jeep. When I got the sensors and seleniods for it, the EGR selenoid had broken nipple on it, so I just plugged off the vacuum port on the TB. It would run ok, but would set a 32 at highway speeds, did not bother me much. I noticed a slight ping under a pretty good load, so decided to replace the selenoid and hook it up.
Here is what happened.......
Idles fine. Give it enough throttle to get it to about 1000-1200 rpm, and the valve opens. Wont run worth a crap unless I get the R's up. If I keep it in the 1000 rpm range, it will almost die. I let the engine idle, and the vavle will close, and stay closed until I just brush the throttle again. I check the valve, it does not stick. So I take a vacuum gauge and connect it to the output of the selenoid. At idle, no vacuum signal. At about 1000rpm, a vacuum sig is present for just a second, enough to deflect the needle to 20, but only for an instant. Then I hooked up a line to the EGR itself and gave it a suck to open it while it was running, and ofcourse it stumbled at idle. When I quit sucking, the valve closes, and it runs fine. I put the everything back to normal, rev it up to the point the vavle opens, then disconnect the input to the vacuum at the selenoid, and the vavle closes.
Where I am confused is, the vacuum gauge on the output of the selenoid is only present for a instant, so why is the valvle staying open after the vacumm signal is gone. When I used the sucking vacuum, the vavle did close when I let go. Could the sig from the ECM be pulsing the signal so fast that the vacuum gauge cant pick it up?
One other thing that may matter for t/s purposes. I have a manual tranny with a speed sensor from Howell, no shift lamp, no AIS. The ECM came from a auto tranny set up.
Any help would be greatly appreciated, and sorry for the LOOOOOONG newbie post guys.
Old May 21, 2002 | 11:02 PM
Psmurf's Avatar
Someone on the BB must know the answer to this one....
Old May 22, 2002 | 09:10 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
well... even if the valve was staying open, it would run good at all rpms but idle and, possibly WOT. EGR staying open al teh time only makes for a harsh idle but when the throttle opens, the engine smooths out. I found all this out when the electronic EGR on my s-10 was improperly instructed to open by the ecm (just unplugged it to fix that one!). A bad egr staying open will only cause trouble at idle, At higher rpms, the egr is open anyhow. The solenoid, however, could be causing the valve to open eratically. I dont know what effect that would have on you but if it runs ok w/o the egr hooked up, then the solenoid or its operation is to blame.
P.S. Try over at general tech, they may be of more help.
92firebirdguy
Sep 1, 2016 07:53 AM
69GTOby
Apr 18, 2016 02:34 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
