How much will this run me
Old Jun 11, 2002 | 12:31 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I plan on building my own engine for my camaro how much do you think it will cost and how hard will it be for me to do never done it before.
3.4 almunium block
comp cam 2030
almunium 3.4 heads with port and polish
forged pistons
and portand polish the intake
Also what ever else you can think of let me know. I want do it on a low budget but done right and have learning experience and the right to be able to say i built this engine all on my own.
Old Jun 11, 2002 | 12:26 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The "hidden cost" is machine work. Is this a new block? Will it need any prep work before you can use it?
If it's a used block, you need to pay for a hot tank (cleaning with hot acid) and magnaflux (checks block for cracks- cracked block = throw it out). The hot tank destroys camshaft bearings, so new ones need to be installed. (Tool is $200, cam bearings are cheap, it's better to leave the installation/alignment of (oil feed holes) the bearings to the shop).
Putting in a used crank? You should have it magnafluxed (crack check) and see if the bearing surfaces should be ground down. Grind a crank too much = too weak = might want to throw it out. You've also got to get the correct main bearing size- will you measure that, or will you let the shop buy the correct bearings for you? (More accurate for them to do it, a bit more expensive than ordering bearings from PAW.)
How 'bout those heads? Want to do valve work now or later? Hot tank, magnaflux, valve job.
New connecting rods, or re-using? Magnaflux. Want them shot peened (compresses metal for extra strength)? Will they press them onto the pistons, or will you try?
See? The machine work adds up fast. I was told on the tech board to buy the rebuild kit from the machine shop- yes, it'll be more expensive, BUT, the machine shop will appreciate that, and will take extra care with your motor. Plus, what if you ordered bearings through the mail, and they didn't fit? You'd have to send them back, wait for new ones, etc.... the local machine shop would put the incorrect bearings on the shelf, and hand you correct ones.
Forged pistons are an "instant" extra $300 from PAW over the cast ones. I'll use cast in my rebuild. People on the power adder board use cast pistons with a mild nitrous shot with no problems, and I refuse to spend $300 more for 2.8 pistons- but that's just me. It's sick how v8 forged pistons are so cheap.
Old Jun 11, 2002 | 03:11 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
what's the extra $300 for forged really getting us then? Really worth it in the end? If the eights can run NOS on cast iron with no prob, i am sure we can too
Old Jun 11, 2002 | 07:15 PM
FAST RS's Avatar
Wehn i do this im gona use all new parts new block crank pistons rebuilt heads with port and polish any thing enigne wise will be new i will aslo be porting and polishing my intake and getting some 4th gen injectors and have them sent out to be flow tested and all that. And yest i will be puttin nos on it to i plan on spending aorund 1500 or so
Old Jun 11, 2002 | 07:29 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
GM sells just the 3.4L block? Isn't that all you are really using? I read that they sell the 3.4L new for 1800-2000? at least that is what karl said.
Old Jun 12, 2002 | 10:38 AM
Bluerocket's Avatar
Yes it is in the karlpace book as a upgrade to the 2.8 blazer engine
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
