Aftermarket T-56 Specifications
Old Jul 17, 2002 | 09:35 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Tag on my t-56 has this part number: 13-86-011
The number is listed under TTC website as 1386-000-011.
This is the same part number as the number on the transmission tag, I called and verified it with Tremec.
http://www.ttcautomotive.com/products/t-56.asp
p/n: 1386-000-011
center distance: 85
weight: 115-129lbs
touque capacity(lbs.ft./Nm): 450/610
1st: 2.97
2nd: 2.07
3rd:1.43
4th: 1.00
5th: 0.8
6th: 0.62
Rev.3.28
I know there has been conflicting reports on TQ capacity and gear ratios out there for the aftermarket T-56. I had to find out what was right.
Old Jul 29, 2002 | 06:31 AM
ttt
Old Jul 30, 2002 | 08:57 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Both the 94-97 and the aftermarket t56 and the Richmond R.O.D. 6 speed have a torque capacity of 450 lbs/ft
The aftermarkets, I believe, are available with different ratios. I know the R.O.D has like five or six different choices when it comes to picking your gear spread.
Old Jul 31, 2002 | 03:09 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
thing is, that r.o.d. tranny is not a dual overdrive. 5th gear in that tranny is 1:1.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
