Lets Play, Whats That Noise????
Old Aug 17, 2002 | 07:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Got my car back, put my new cat back system on. I still have the same "chunk" sound when I give the car full gas. It did this before I took it to the tranny shop. I have looked over all their work. I was hopping it was my muffler rattling, thats not it, I replaced all it. You feel it really hard on the passenger floor board. My new guess' are Motor mount, or suspension. Let me know your thoughts please.
Old Aug 17, 2002 | 08:20 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
is your cat loose at all. cause that right under passengar side floor
Old Aug 17, 2002 | 08:32 PM
Dale's Avatar
Engine: 350 S-TPI
OO, forgot to say when it happened. stupid me. Its when you give the car full gas, the back squats, the front rises, "chunk" .
86camaro rs, no its not the cat. I check the whole exhaust system today. Replaced half of it!!!
Old Aug 17, 2002 | 10:10 PM
WaynesRS's Avatar
tranny mount ?
Old Aug 18, 2002 | 12:48 AM
michael's Avatar
Car: 1991 Formula
Engine: 6.2 383 TPIS Miniram
Axle/Gears: Moser 9" 4.11
hold the brake hit the gas before it spins do you feel it? kinda like the rear end moves
if so its the rear tranny mount about 8.99 at pepboys easy as hell to replace check else where for poly though if thats what you want its probly 15 bucks more
Old Aug 18, 2002 | 10:04 AM
Dale's Avatar
Engine: 350 S-TPI
No, its not the tranny mount. They replaced that while it was in for the tranny, and I have looked it over. All the bolts are tight!!!
Old Aug 18, 2002 | 12:31 PM
I Cant Drive 55's Avatar
Sounds like a bad motor mount to me . The engine is torquing and the exhaust is hitting the floor.
Old Aug 18, 2002 | 02:46 PM
Dale's Avatar
Engine: 350 S-TPI
thats what I'm leaning towards, but wanted everyones opinion as I don't have much experince on camaros and whats known for breaking easy. Also rem I got this car from a teenage male.
Old Aug 18, 2002 | 04:37 PM
GhostRider84's Avatar
I had this "clunk" when I reinstalled the motor. When we rebuilt the trans. we put it up on a 4 point lift and tightened everything up - it went away. I still don't know what was causing it - sorry.
I had some motor to trans. bolts loose as well as some other stuff. It wasn't a U joint.
Old Aug 18, 2002 | 10:39 PM
funstick's Avatar
look around the undercarriage for a shinny spot. usaully this will be the point of contact. then get a pry bar and wrench on the tranny and motors and see what gives.
Old Aug 19, 2002 | 07:31 AM
Dale's Avatar
Engine: 350 S-TPI
Yea, I still trying to fig out how to get to the right motor mount due to all the emissions CRAP. Does the motor tweek from right to left, or left to right?? And how hard are the motor mounts to get to??
Old Aug 19, 2002 | 09:25 AM
pontiacguy1's Avatar
Looking from the front of the car, the crank spins clockwise, so the pressure side will be the passenger's side of the car. What happens some times is that when you decelerate, the engine will shift to the driver's side, then twist around to the passenger's side when you hit the throttle,causing the clunk you are hearing. I think that if it isn't the trans mount, there are two things that I would check:
(1) Engine mount. Like everyone else has said, it is most likely your culprit. You will need to remove the exhaust manifold and smog equipment on that side to get to it.
(2) Rear end lower control arm bushings. Could be that you have a bad control arm bushing that is clunking against the rear frame rail when you hit the gas. I have seen this happen, but it is much rarer than a trans mount or an engine mount.
Hope you get it fixed. I had a trans mount rip out once, and I couldn't give it any gas without the thing clunking and moving around. How annoying, and not too good for the car either!
Old Aug 19, 2002 | 09:31 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are you sure it's a new trans mount? Climb under the car, and try to bench-press the tailshaft (rearmost end) of the trans to the floorboard. (It will pivot easily on the engine mounts.) If you can move the tailshaft of that trans upward at all, the trans mount is shot. My trans shop didn't replace mine, they put the busted one back in. Nice, eh? Get the poly one from energy suspension (thru summit) for $26 and you'll never replace it again.
Old Aug 19, 2002 | 10:09 AM
Dale's Avatar
Engine: 350 S-TPI
Its new alright, nice clean black rubber thingies, with nice new chrome/nickle bolts. The rest of the bottom of the car is NASTY!!!
So I gotta remove the emissons #$^@# to look at that. Damn. thats gotta be a pita.
Old Aug 19, 2002 | 10:27 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
I'd throw a set of cheap rear shock on that thing first. My 83 was pretty "clunky" at first. Turned out the rear shock mount on the body was broken. After welding that in with some new shocks, all was good
Old Aug 19, 2002 | 01:32 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
while your under the car, check the torque arm mount too, they "clunk" real good when broken.
Old Aug 19, 2002 | 05:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Again, buy the ES poly torque arm mount; a pain in the butt to put on, and you have to lower the trans tailshaft a bit, but it really improves the car's handling! It totally eliminates the "wiggle" in the car's rear that happens during sharp turns! I did one when I replaced the last transmission.
Old Aug 19, 2002 | 08:03 PM
Dale's Avatar
Engine: 350 S-TPI
Well, after playing around with my show truck fixing its tranny mount. I went over to the camaro and started inspecting crap. I took a pry bar and put in on the right side of the engine, started lifting engine up. I could get it to move about .25-.5 inches. Ok, I went to drivers side, went to move it, No movement. Tryed again, no movement. called my dad to come over, has worked on cars for 30+ years. Did same thing and aggred that the motor mount is toast. Push on the back end of car for shock mount, bounced it off the bump stop a few times. No Nosie. I looked at that bar thing along the drive shaft other day. It looked fine. I'm like 99% sure its the motor mount. SOOOO, what all is involved in swaping these bugers out. I know jack up the engine, but do I have to pull half the suspension out like on my s10?? Or a combo of swivles and extensions work?? My repair book don't tell ya crap on this.
Old Aug 20, 2002 | 08:34 PM
You shouldnt have to tear the suspension apart to change it.
just swivels and extensions.
Old Aug 20, 2002 | 08:45 PM
Dale's Avatar
Engine: 350 S-TPI
Hope not, plan on this next week. Thanks for tip.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
rusty vango
Sep 29, 2015 02:44 PM
