Sun visors keep falling!
Old Sep 19, 2002 | 08:52 PM
Maximus's Avatar
Car: 1992 Camaro Z28
Transmission: 5spd.
I've tightened the screw as much as possible, Do I need to buy all new sun visors? I wish they made these better, everytime I hit a bump they fall in my face. I may just take them off! Let me know if there's a secret to this, PLEASE!
Old Sep 19, 2002 | 09:04 PM
Saywhut's Avatar
Drill a 1/8 hole thru the black body, and the shaft in it, and install a poprivet.
Old Sep 20, 2002 | 01:40 AM
CrazyHawaiian's Avatar
Car: too many ...
same thing used to happen to my passenger visor in my B4C. velcro saved the day!
Old Sep 20, 2002 | 01:21 PM
redraif's Avatar
Transmission: Th700R4
There is a plastic piece that fits in the visor. It is supposed to cause a tight fit on the shaft. If it wears out it will fall because the fit has loosened.
Old Sep 20, 2002 | 02:36 PM
Saywhut's Avatar
Here 'ya go.................
Drill a 1/8 hole thru the body, and the shaft. This will get your depth so you don't drill all the way thru
I used trim paint and a paper matchstick on the rivet
Here you see where I drilled, and the finished product. If you drill from this side, it will be invisible, this is the side away from you when in the car.
Old Sep 20, 2002 | 03:22 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 'bullet' that slips into the plastic insert is often at fault. The 'bullet' is supposed to be stationary, but often breaks and turns. As a consequence, regardless of how much the screw is tightened, the visor will fall.
JamesC
Old Sep 20, 2002 | 03:29 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
yeah
same thing happens to my drivers side one. its horrible, i think i may just go to the junkyard and get a new one
sorry but i didnt understand those steps that the other member sent
bub
Old Sep 20, 2002 | 04:33 PM
Saywhut's Avatar
Originally posted by bubbakutz
yeah
bub
Maybe some more explanation is in order:
The last pic, fuzzy as it is, shows the driver's side visor, as if you were looking thru the windshield.
I simply drilled a hole thru the body and the shaft, and put in a poprivet, then painted the rivet. I only drilled thru one side of the body, and the shaft itself.
The masking tape on the drill bit, naturally, was to keep me from going deeper than the rivet is long. I didn't want to go completely thru both sides of the body. I used a 1/4" rivet, (it's actually about 7/16 total, 1/4 is the thickness of sheetmetal it will hold together), just popped it in the blind hole like you see.
This is how my bud at the upholstery shop fixed my first set, what has happened to mine is the shaft gets loose inside the body. The shaft turns in the body, instead of being solid there, and the visor turning on the shaft, like it's supposed to. Now it's tight again, and the visor stays up, or swivels down just like it should. I guess the plastic insert on the 3 pairs I've repaired was ok. But on this last pair, I could actually see and feel the play between the shaft and the body.
Hope this helps explain it some.
A little more on the rivet:
It's a 1/8 diameter rivet, 1/4 is the length on the package.
Drill a 1/8" hole.
Old Sep 20, 2002 | 04:49 PM
bubbakutz's Avatar
Engine: LG4
yes it did thanks, but how does the rivet stay in the hole
Old Sep 20, 2002 | 04:58 PM
Saywhut's Avatar
Put it in with a rivet gun, it expands inside the hole.
Old Sep 20, 2002 | 07:15 PM
Maximus's Avatar
Transmission: 5spd.
Thanx guys, I tried velcro before and that never worked for me! So my next attempt will be the rivet trick, saves me from buying new ones!:hail:
Old Sep 20, 2002 | 07:21 PM
Saywhut's Avatar
Let us know how it works out.............
Old Sep 20, 2002 | 08:02 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I like the rivet trick. That is easier than what I did. I took it off and hammered into the body with a punch until the body deformed enough to capture the center post. I punched the side that wasn't visible from below. It took a heck of a lot of deflection before it finally stopped that inner shaft from rotating. Then I painted it. I've wondered if epoxy would do the trick.
Lon
Old Sep 20, 2002 | 08:57 PM
JamesC's Avatar
JB Weld would certainly be an option, I think. Of course, the hanger could be picked up at a boneyard for little or nothing.
JamesC
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
bjpotter
Oct 15, 2015 11:07 AM
LT1Formula
Oct 8, 2015 08:34 PM
FormulasOnly
Oct 2, 2015 05:52 PM
3.8TransAM
Oct 1, 2015 07:47 PM
