crankcase vent/ oil trap idea..opinions pls..(pic inside)
Old Sep 25, 2002 | 07:20 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Or replace the breather with an elbow that goes straigth to one of the primary tube of the headers via AIR tube with maybe a check valve ..Opinions or ideas??I still dont know what to use as canister though
Daz
Old Sep 25, 2002 | 02:33 PM
pyro's Avatar
not trying to be a smart a@$ but wy not use a coffe can they are cheap (you probably got one lying around with some worthless brown powder in it)you can seal it reasonably well heck you could
mig wield something on top to seal it then paint it.
I know it sounds like some ******* engeneering but why spend mony you dont have to
Old Sep 26, 2002 | 10:09 PM
Vader's Avatar
Have a little blowby, do we? I know the feeling. Why not use one of these?
Installed like this?
Old Sep 26, 2002 | 10:49 PM
Vader's Avatar
It's simlar to your design, but with a little design difference.
Under heavy loads, case pressure in excess of the limits of the PCV will force oil vapor through a 5/8" hose, into the filter. The bronze wool helps trap the oil droplets and allow gasses to vent. But with the opening on the bottom, oil can automatically return to the crankcase when crankcase pressure is normal and the PCV is operational again. With the filter unit mounted at the correct height, the slight vacuum in the PCV system will draw oil back to the crankcase. Any additional air entering the case will be filtered by the wet bronze wool (steel will rust out). The whole mess cost me less than ten bucks, and temporarily solved the blowby oil loss and subsequent smoke. Obviously, ,the best long-term solution is new rings, but if you're planning to trade it in...
I'll bet the dealer mechanics were scratching their heads over that "AC" CCV Filter... The custom label was a nice added touch, so it looked like it belonged there.
Attached Thumbnails crankcase vent/ oil trap idea..opinions pls..(pic inside)-ccvcutaway.gif
Old Sep 27, 2002 | 07:36 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
thats amazing!!!..What is that canister made off??Also what do you think is better a partially closed(with PCV)or fully open system(both venting to a trap like yours).Or is it a dealer item??lol...If it is..doh..What kind of PCV are you using on that set up??PCV with a "T"?
Daz
Old Sep 27, 2002 | 08:23 AM
Vader's Avatar
Go to your local building supplier. Get a 4" black polyethelyne cap made for corrugated poly drain hose (the type used for landscape drainage) and a 4" diameter drain interceptor. A second cap will work in place of the trap/interceptor, as long as you cut off the raised ridge. Cut ventillation slots in the upper cap, punch a hole for the grommet in the bottom, and install the hose connection (from an auto parts store HELP! section). Stuff it full of bronze wool as an oil resistant filter material, then glue the two halves together with PVC solvent cement. There's your filter/trap.
I mounted mine with a 4" plumbing riser standoff clamp, but anything that will hold it satisfactorily and not look like a complete Rube Goldberg job should do.
Mine went on an old Fiero that had no rings left just before I sold it to a used car dealer. The device stopped the oil pumping to the intake tract and resultant smoke. It couldn't have happend to a nicer guy...
Old Sep 27, 2002 | 09:09 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
great thanks!!..
Daz
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
