DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
How will my motor act without the right chip?
Old Sep 25, 2002 | 02:46 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I have a dyno/custom chip appointment scheduled with Ed Wright @ Fastchip on the 21st of October. In the mean time, my motor has to be broken in. I'm in a situation that hopefully some of you may already have a feel for! The motor is a 355 10.7:1, afr 195s, stealth ram, supercomp longtubes, 224/224 110 560/560. If there's anything else you need to know, just ask! My car came stock with an L98 and I want to break her in on a stock chip. I have a set of SVO 30#ers and a set of 19#ers. I know the stock injector pulse width is too long to use the 30#s. At the same time, the 19#s wont flow enough. What should I do and how should I expect this motor to run without the proper tuning? Do you recommend a minimum throttle % and a minimum rpm to keep the motor within during breakin? (of course I wont be abusing the thing during breakin) Thanks!
Old Sep 27, 2002 | 03:53 PM
EROCK's Avatar
Well, I bore my motor over, re-cammed, flowed the heads, valve job, yada yada yada. 4 tenths of a second SLOWER with a motor that is dyno'd at over 400 flywheel. Need a chip change. Just needs tuned that can only come from a chip.
Eric
italiano67
Dec 11, 2016 09:21 AM
69 Six Pack
Oct 5, 2015 07:51 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
