Twin Turbo GTA inside...........
Old Oct 15, 2002 | 05:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hi....
Look at this car!
The engine he has now is 540 cui al. block with +700hk and plus NOS. Runs 10.06 228km/h
Transmission 4L80....
Buildning a twin turbo engine.....
http://www.evo.no/reportasjer/polly_...port/index.htm
Enjoy!....
Why dont I have that kind of money and time
Old Oct 15, 2002 | 09:24 AM
Guido's Avatar
Car: 2000 Trans Am
Holy shoehorn batman! I bet thats a trick to get in that car. LOL
Looks badass though!
Old Oct 15, 2002 | 10:57 AM
87Z-ya's Avatar
Like the electrical taped on n2o button.. Done that before!
Old Oct 16, 2002 | 06:01 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
Not too cluttered. Just the bare necessities. That's how I like it.
Steve
Old Oct 17, 2002 | 01:39 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
anyone know how to read what all that says?
i look at it and i think i'm in :lala: land
Old Oct 17, 2002 | 02:08 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
If copy and paste or tell me what you want to translate, I'll help you.....
Old Oct 17, 2002 | 03:13 AM
83 Crossfire TA's Avatar
you can use the traslator on google or bablefish.
Not sure that it would be all that usefull, notice that they don't show the TT engine in the engine bay. I don't think that it would fit. Even a small block wouldn't fit with the turbos positioned like that unless you do something completely different for brakes.
Old Oct 17, 2002 | 03:21 AM
man, how did I miss that. I guess it might fit in there car, notice something missing?:
Old Oct 17, 2002 | 06:05 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
hmmm... how about the lack of a master cylinder?
Old Oct 17, 2002 | 10:05 AM
Guido's Avatar
Car: 2000 Trans Am
Maybe he is using a handbrake?
Its not unheard of. Tony "Sandman" Williams drives a pro outlaw 6 second doorslammer and he uses a handbrake.
:shrug:
Old Oct 17, 2002 | 10:35 AM
89ProchargedROC's Avatar
he could always be pulling a fred flinstone too :lala:
Old Oct 17, 2002 | 03:33 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I've heard the word "doorslammer" used in context wayyy to many times, I would like to know your definition of it because I always thought a "doorslammer" couldnt run those kind of times.
Old Oct 17, 2002 | 04:34 PM
doorslammer- a race car that has doors that open like a normal street car.
His brakes... look at the rest of the pics, he's running an aftermarket brake pedal which I'm betting has twin pistons mounted at the pivot, inside the dash. I'm also betting that this is at least partially facilitated by that aftermarket guages and the guage pannel that mounts them probably close to 2" higher up...
Old Oct 20, 2002 | 12:54 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I dont think he has ever heard of engine degreaser or polish though...
Old Oct 29, 2002 | 07:15 AM
JPrevost's Avatar
Car: 91 Red Sled
If it don't make you faster don't do it.
Old Oct 29, 2002 | 11:00 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
hear hear!!!
Old Oct 29, 2002 | 11:03 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
And a couple cans of spray paint later....
Old Nov 9, 2002 | 05:57 AM
espen's Avatar
Looking through my logs I noticed you guys have been loyal visitors til my page lately so I thought I'd pay a visit.
I wrote an article on this car for a local car magazine this summer and yes, it's a door slammer that gets used every day. However that's not the full story, as it has a complete tube frame built in so that all susp mounts, engine mounts and such go into the tube frame. Makes for a pretty heavy car (1835kg drag ready with driver) but stock appearance is essential in car-hating Norway unfortiunately.
The owner, Paal Arvid Blytt, has built this car for a dead serious attack on the Silver State Classic in the unlimited class. He ran a rented Viper at an average of 159mph at the event back in 2000 in case you wondered if he's for real. He is very serious. Not only that, but he's spent the time and money to make a car that works and is really beginning to produce results at drag strips and race tracks here in Scandinavia.
Besides kicking very expensive and high profile *** at the drags, it's the ability to do the same at race-tracks that has really gotten attention over here. Everyone knows an amcar with a bigblock cant turn a corner, right? Well try to explain that to the barely street legal high profile racers that had a mirror full of T/A at "Gatebil" street legal track races this summer AWD turbo power isn't much help when you're not going any faster in the corners and arriving at the straights with a disadvantage of 300 or 400 hp... not surprisingly, the faster high profile cars refused to race.
I'll put up a spec sheet below. Since the shots were taken, he's added an Autronic SM2 ecu and a second staged NOS system jetted for apx 250hp. When run in conjunction with SM2 and traction control, one button controls both systems while SM2 controls one/two stage actuation. Neat
Ok, what you all want to know - yes the turbos do fit as everything was built with the engine in the car - and they are going into the car but Polly has decided that using the steel Brodix-head bigblock is off since he can develop suficcient power in the Donovan alu block and save a lot of weight. So lower comp pistons are going into that engine and turbos too. Turbos will be electronic wastegate controlled by SM2 so that the boost can be tailored to available traction - the existing solution was simply too brutal as there was wheelspin pretty much all the time. polly has calculated he needs about 1000 reliable hp in order to get the performance he needs in Nevada.
I've had a test ride - kindly declined a test drive as I'm used to about 1/10th of the power - but the car is so competently set up that even though the engine roars like thunder and the speedo indicated speeds in the several-years-in-prison range (welcome to Norway...) the cars doesn't feel "out-of-control" fast like a turbo fwd car does. It just feels like a rediculously fast car held back by other traffic - 120mph feels like an ambling run for groceries and even at full power theres no twitchiness or instability. Tho the Polly did admit that the nose gets light above 300km/h (190mph) so while the car pulled briskly he had to back off at 330.
Perhaps for you draggers out there this isnt that much out of the ordinary, but me I'm used to fast cars beling defined as an M3 or a chipped Audi S4... and in comparison it's mind alteringly fast!
Ok sorry for alle the text, it's hard not to get worked up a project like this in Norway where government is pretty much trying to snuff out anything that's noisy or fun.
If youre still reading, thanks
Espen Vindegg
evo motorsport
www.evo.no
Old Nov 9, 2002 | 05:58 AM
espen's Avatar
Heres a spec sheet written in cooperation with the owner:
1986 Ponitac Trans Am, GTA aero package
Owner: Pål Arvid Blytt, Bergen, Norge.
Engine: 540” Donovan aluminum block with Scott Shafiroff ported Dart heads and matched Dart intake. 4.50” bore 4.25” stroke. Cailles billett crank, Oliver rods, JE pistons 10.78 compression. Competition Cams 250 deg rollercam at .650” lift with Jesel 1:1.7 roller rockesr. Autronic SM2 fuel injection with MSD ignition. NOS Fogger two stage kit (150hp + 250hp). Moroso dry sump lubrication with external reservior. Hand built exhaust system with backpressure operated muffler bypass for silent cruising yet thunderous races.
Transmission: Precision Industries converter, 4500 stallspeed. 4L80 prepared by Ole Ringstad. Manual shifter. 0.75:1 4th gear and 3.00:1 rear end for a teoretical top end of more than 400km/h!
Susp front: Art Morrison forged, all bushings replaced with uniballs. Adjustable Koni coilovers. 36mm Herb Adams stabilizer. (Racing Selholm coilovers being developed)
Susp rear: 3.00:1 9” Ford with Mosler shafts. Lightened aluminum center with Detriot Locker diff. Custom adjustable three-link rear end, all uniballs. Adjustable Koni coilovers. (Racing Selholm coilovers being developed)
Bremser: Front Audi RS4 360mm floating discs and four piston Baer calipers, rear 12.5” Wilwood vented discs and four piston calipers.
Tires: Front 245/40/20 Michelin Pilot Sport, rear 285/35/20 Pirelli Pzero. M/T ET Street 820/11,5/15 for drag.
Rims: BBS RC 9x20” og 10x20”.
paint: Original and well broken in.
Interior: MOMO Corse FIA approved racing buckets, Autometer instruments, Simms fourpoints - and a 20 lbs NOS bottle!
ICE: Pioneer CD-player and speakers up front, 783kW all aluminum subwoofer..!
Weight: 1835kg (4110 lbs). Distribution 50/50% when fuel cell is half full.
Performance: DIN 780hk/6800 and 940 Nm (695 lb/ft) /5000 in engine dyno. Power on NOS calculated by Precision Industries at 1065hk (that's what it would take to slip their converter to redline)
¼ mile 10.06 sek/228,8 km/h (142 mph) at Gardemoen - 10,41s/221 km/h (137 mph) on Pirelli PZeros at Mantorp. 1/8 mile 6.501 sek/180 km/h at Gardemoen. SM2 logs reveal 0-100 km/h (0-62 mph) in 3.5 sek street tires on street, 2.8 sek street tires at Mantorp and 2.5 sek DOT radials at Gardemoen raceway. Top speed power restricted at ~ 350 km/h, fastest driven is 330 (205mph) and climbing.
hope you can understand my english, technical terms are a bit hard for a Norwegian. No Speedvision here!
Old Nov 9, 2002 | 06:09 AM
espen's Avatar
Ok, one last thing...
Old Nov 9, 2002 | 06:28 AM
JPrevost's Avatar
Car: 91 Red Sled
One word....wow.
Old Nov 9, 2002 | 11:51 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Holy Crap!
Monte and Guido might have some competition other than Fighter planes
T-bone
Old Nov 20, 2002 | 08:00 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
here's a movie with the "Polly" trans am......
http://xpress.mine.nu/illegalracer/f...tt_TransAm.avi
Old Nov 20, 2002 | 09:52 AM
JPrevost's Avatar
Car: 91 Red Sled
Too much traffic. Link is dead. Anybody download that file? If so, share it please.
Old Nov 20, 2002 | 08:03 PM
TexasLT1's Avatar
Car: '92 RS
holy friggen crap! :hail: *druel*
Hmmm...anyone else get the feeling they need ALOT more power?!
<----- 700 posts, WOOHOO!
Old Nov 20, 2002 | 08:13 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
WOW. thats all i can say WOW!!! i wana see the video but it won't download i get an error page can't load...
Old Nov 20, 2002 | 08:14 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
If I can get it, I'll host it on my site as a mirror. Assuming I can get permission to do so.
That car sounds like its a beast! A car like that here would probably be pulled over in two seconds flat. ^_^
Old Nov 21, 2002 | 12:18 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Wonder what times he will be doing after his twin turbo set up is finished? big block twin turbo.......:hail: :hail: :hail:
Old Nov 21, 2002 | 12:49 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
YES....I thought that when I got my ATI I will be satisfied but after seen htis car I'm not sure. ONE thing is for sure, I need more money!
Old Jun 15, 2003 | 11:32 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Updates:
Romours says that the new twinturbo engine has been tested this weekend. I'll be back when I have more info...............
http://www.evo.no/artikler/reportasj...port/polly.php
Attached Thumbnails Twin Turbo GTA inside...........-polly_motorsport_016.jpg
Old Jun 15, 2003 | 11:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
:hail: :hail: :hail: :hail: :hail: :hail:
Old Jun 15, 2003 | 12:06 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
it's baaacckkk!!!!!!!
Old Jun 15, 2003 | 01:26 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im sorry I love the power and the concept, I have a problem with anything that lacks some sort of pride and workmanship.
Old Jun 15, 2003 | 03:35 PM
Damon's Avatar
I like it. It looks like something I'd build- street functional filthy and goes real fast.
I don't have the scratch for something that wicked, though.
Old Jun 15, 2003 | 03:56 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
Huh? Maybe you misunderstood... I'm not knocking it at all.
That bugger's wicked. Absolutely insane and I love it.
cheers, BW
Old Jun 15, 2003 | 06:42 PM
espen's Avatar
Yes, and it works too!
In stead of thundering exhaust, theres now a sweet whine as the turbos spool up and a huge blasty woooosh from the exhaust. And then its just gone
Old Jun 15, 2003 | 06:44 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
that car in general looks sooo sweet!
the ram air hood definatly changes the whole apperance of the car IMO, i am definatly getting one.
Old Jun 15, 2003 | 07:48 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
damn i want one
*adds 2 turbos to the "still to get" list*
Old Jun 15, 2003 | 11:44 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Espen: Good to have you here, please give us more info about how the car is running, times, dynos and so on. Are "Polly" going to race in sweden this year( have to see it!)
/N.
Old Jun 17, 2003 | 06:25 PM
PONTIACGTA1988's Avatar
did anyone get to see the movie clip for polly? i get an error message espen you out there?.. need link too movie
Old Jun 18, 2003 | 04:26 AM
espen's Avatar
Hi, sorry but I don't know anywhere to download the movie from.
Old Jun 19, 2003 | 11:27 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
My pants are tight...
Old Sep 4, 2003 | 01:54 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Timeslips...
201m 7,40s 106,25mph major traction problems..........
402m 10,4s 137,50mph boost only 0,5bar.....
Traction and building up boost seems to be a problem, needs bigger turbos..............
Old Sep 4, 2003 | 02:13 PM
FruityOne's Avatar
Indeed, the clip was down when I tried to see months ago.
Old Sep 4, 2003 | 02:20 PM
Cool Runner's Avatar
Car: 86 Trans Am WS6
For people who were having difficulty reading this like me. I did the conversion to make it easier to glance at and understand.
201m = 659.4408ft | 1/8 = 660ft
402m = 1318.8816ft | 1/4 = 1320
1/8 in 7.4sec at 106.25mph
1/4 in 10.4sec at 137.5mph
They are not exactly equal to the 1/8 and 1/4 but close enough for comparison.
*note: many european countries use commas where we would use a period
Old Sep 4, 2003 | 08:14 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
OMG this thread willnot die...
Old Sep 5, 2003 | 02:52 AM
CrazyHawaiian's Avatar
Car: too many ...
This is the best thing I've ever seen. Ever. :hail: :hail:
Old Sep 5, 2003 | 01:45 PM
lol..That's because there's so much interest in turbos around here.
hint...hint...Guido
Old Sep 5, 2003 | 02:11 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah!
Old Sep 5, 2003 | 02:35 PM
Guido's Avatar
Car: 2000 Trans Am
hint...hint...Guido
Im working on it my friends. LOL
I work a full time job @ 50 hours a week so this stuff is all in my spare time right now. LOL
