4th gen seats
Old Oct 22, 2002 | 12:02 AM
The Judge's Avatar
4th gen seats
Do 4th gen seats bolt right into a third gen. Ive heard you need to drill holes to make them work.
Old Oct 22, 2002 | 12:23 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Direct 100% no-mod bolt-in perfect fit.
Old Oct 22, 2002 | 01:38 AM
SSaudio's Avatar
d@am right!
Old Oct 22, 2002 | 01:43 AM
SSaudio's Avatar
d@am right!
Old Oct 22, 2002 | 04:12 AM
BikertrashDude's Avatar
yup, go for it
Old Oct 22, 2002 | 05:50 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Really, they bolt right in!!!! Cool.
Old Oct 22, 2002 | 06:57 AM
Z28DJP1987's Avatar
(8) 14mm fasteners for the fronts and (4) for the rears thats all youi have to remove & replace.
Old Oct 22, 2002 | 07:52 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Old Oct 22, 2002 | 09:34 AM
fly351's Avatar
Car: 1996 Camaro RS
Engine: v6
does anyone have any pictures of it?
-fly
Old Oct 22, 2002 | 09:51 AM
i don't think anyone has done it yet
biker
Old Oct 22, 2002 | 10:35 AM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Lookie Lookie!!! I got mine to work after 3 days of modification! I was about to give up.
100% bolt in unless you have a split fold rear seat then you need to loose the little bar thingy on the drive shaft tunnel....right?
Old Oct 22, 2002 | 11:17 AM
Z28DJP1987's Avatar
What modifications??? There is none on 4Th Gen seat install. Did mine in less then 2 hrs and that included cleaning the carpet.
Old Oct 22, 2002 | 11:28 AM
just a joke. This has been posted to death so we are being sarcatic. just a little fun thats all.
Old Oct 22, 2002 | 05:11 PM
Quick6's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
Old Oct 23, 2002 | 01:11 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Here's mine, came out of a '00 Z28.
Old Oct 23, 2002 | 09:50 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Billsfirebird, what 4th gen did those come out of? If i can't get aftermarket those look like a nice set.
Old Oct 23, 2002 | 11:41 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Just to confirm.
I do beilve that they MIGHT fit.
I can neither confirm, nor deny that.
But I have it on good athority that they will fit.
I also have it on good athority that they wont fit.
I guess you will have it work, or it wont work...
Old Oct 24, 2002 | 01:51 AM
bj350hp's Avatar
Car: 1987 Camaro SC
DUDE MAN its so Hard to put 4th Gen Seats in you have to weld and cut in like 50 places its so not worth it
man than you have to drop the gas take and Pull the Trans its a big pain in the but...
i think im gona start being the new Search ****
Try the Search KEY next time
Old Oct 24, 2002 | 07:39 AM
Came right out of a 93 Camaro.
Old Oct 24, 2002 | 08:50 AM
Saywhut's Avatar
How'd 'ya get 'em to fit in your car?
Old Oct 24, 2002 | 09:06 AM
Duct tape and bubble gum.
(in case it was a serious question...just used all the existing hardware. no mods)
Old Oct 24, 2002 | 09:22 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
LOL
Old Oct 24, 2002 | 10:24 AM
FLYNLOW92rs's Avatar
So wait a second........I can actually remove the seats from a 4th Gen and place them directly in a 3rd Gen......????
But the body styles are different.......???
I wouldn't recommend doing this swap, you need to remove the engine for saftey precautions so it can be a long drawn out process............plus you need a engine lift....
Old Oct 24, 2002 | 11:04 AM
wait do you have to take the doors off too???
how about the rear hatch, to get the rear seats in??
lol
Old Oct 24, 2002 | 12:46 PM
FyreLance's Avatar
I heard you need one of those chassis roller thingies. Also, I heard that the swap isn't possible with hardtops, need t-tops or a convertible to get the seats in.
Old Oct 24, 2002 | 12:58 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
seats? what are seats?
Old Oct 24, 2002 | 01:36 PM
Z288Iroc's Avatar
Double Post :lala: :lala: :lala:
Old Oct 24, 2002 | 01:37 PM
Z288Iroc's Avatar
So what do you do after you drop the tank. Cant get mine to work, what kind of bubble gum did you use... Damnit anybody wanna buy a set of 4th gen seats. Thanks for the help guys.
Old Oct 24, 2002 | 02:39 PM
deadbird's Avatar
Engine: TPI 305/ v6
:sillylol: You guys are rotten
Old Oct 27, 2002 | 05:30 PM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I thought it went something like you had to weld in subframe connectors and a main hoop from a six point roll bar and then drill and tap the upper left side of the passenger side seat whith the car in park.
But I could have heard wrong.
I once had a friend that did that swap and he had to get his front end aligned.
Good luck on the this very challenging swap, it will be a long hard road but worth it.
Old Oct 27, 2002 | 11:43 PM
Abubaca's Avatar
You guys are such jerks. The guy asked a simple question....it only required a simple answer.
YES, they do bolt right in.
Of course, you'll have to bolt the rear seat in backwards...kinda like the old caprice station wagons....or it won't fit. If you want your passengers to face forward, then it's a different story all together.
:lala:
Old Oct 27, 2002 | 11:54 PM
See i had my car in Neutral when i tried it and i had to replace the coolant overflow tank because it broke, I got it fixed though............
Old Oct 28, 2002 | 09:25 AM
racereno's Avatar
Car: 91 Camaro RS
Axle/Gears: Stock
I'm SOOOOOO confused!
Old Oct 28, 2002 | 01:14 PM
9-FIREBIRD-2's Avatar
seats
YOUR ALL WRONG !!!!! You have to take the carpet out first, then install the seats, then put the carpet back in ! If you don't then the heater won't work.
Old Oct 28, 2002 | 02:50 PM
mess21's Avatar
i know that the seats are a direct fit but the door panles aren't right
Old Oct 28, 2002 | 02:56 PM
Nope the door panels don't fit right in......
Old Oct 28, 2002 | 04:04 PM
mess21's Avatar
any way to make them fit probally not worth it though huh
Old Oct 28, 2002 | 05:16 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Wait a minute, I had to cut the roof off of mine to get the back seat in because it wouldn't fit through the doors or the hatch! I guess next time ill know just to cut the car in half, it'll save alot of trouble!
Old Oct 28, 2002 | 07:13 PM
kidcamarosc's Avatar
i heard that if you have a 305tbi the seats will not work since the engine is such a torque monster it will actually rip the seats off the of the floor
Old Oct 28, 2002 | 10:20 PM
Car: '86 Trans Am
well actually I've learned from my experience that you should install a wheelie bar and a 4 link rear suspension cause the 4th gen seats completely mess up your weight distribution when running under 15,000+ feet altitude.
I could be wrong but I had a near death experiance when I floored it in 5th gear after my 4th gen seat swap, the car almost completely flipped over and so on.
and for a safety precaution you might wanna consider a pre-'75 dual points distributor setup but that's only for safety purposes.
I've also found that oil pan windage trays help when running the seat swap without the proper suspension setup.
Hope I was helpful.
peace
Old Oct 30, 2002 | 03:52 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
:sillylol: :sillylol: :sillylol: :sillylol: :sillylol: Thanx I needed that, started to turn into a bad day. And as far as the seats go, the modifactions, and yes there was at least one, was the power, if the seats are powered, be sure and get the harness. I think it's worth it, I love mine.
Old Oct 30, 2002 | 09:13 PM
ajm_shorty's Avatar
Huh
I have Power Seats..Can i just splice the wires?
Or do i gotta Rip the doors, hatch, hood,groundeffects off? The hood has a light that takes to much power and your car dies with it on there. Doors need to come off for the front seats to come out and put the 4th gen in. Hatch comes off for the back seats. Groundeffect got to come off or you will scratch them.
Old Oct 30, 2002 | 11:01 PM
Saywhut's Avatar
Hey, does anybody know if 89 IROC seats will fit in a 89 RS?
What would I have to do to make 'em fit?
If they were power IROC seats, and I wanted to put 'em in a RS that had power seats, would I have to swap the IROC harness also? I was thinkin' I could just wire them into the cigarette lighter, then all I'd have to do would be hold the liter in with one hand and adjust the seats with the other. Maybe.
Old Oct 31, 2002 | 12:29 AM
Stop lying to the poor kid............
j/k
Old Oct 31, 2002 | 01:10 AM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I dont remeber this post.
But I seem to have replied to it earlier.
andewayz
I am the Seach ****, so do a Search, and all you wishes will come true....
What was the question again???
Old Oct 31, 2002 | 06:13 AM
SpeedJunkie's Avatar
Car: 88 IROC
I like pizza!!!!!
Old Nov 1, 2002 | 10:15 PM
Wootah's Avatar
Car: 88 Iroc-Z
Engine: 355ci
Transmission: WC-T5
Im gonna laugh when some innocent 16 yr old hacks there car in half with ye ole' chainsaw :lala: :lala: :lala:
Old Nov 2, 2002 | 07:44 AM
Z28DJP1987's Avatar
My personal opinion is that all you "so called comics" have had your fun with this question, so put it to rest. The real impression I get is you are AH's and have no knowledge of the subject or did this conversion.
Old Nov 2, 2002 | 01:49 PM
I do have knowledge on this topic! Why? because I actually searched and looked at other 4th-gen seat swap threads that other people have posted. Now, see how much grief, time, and frustration that silly little mistake of the guy not searching, or looking for another thread on 4th-gen seat swap caused? Now, I know I replied with a stupid post, but we all joke around right? I think this thread should be closed!
Old Nov 2, 2002 | 02:05 PM
Z28DJP1987's Avatar
That would be the smartest thing said about this Post lately.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
