Swapped to old rear spring isolators, got new stance. Pics inside..
Old Oct 22, 2002 | 03:32 PM
ebmiller88's Avatar
As some of you guys know, I installed new GM rear spring isolators when I rebuilt my suspension. They were noticably bigger than the old ones, but I put them in anyway, figured they'd squish down a bit. After all was said and done, it sat a bit high in the rear. I let it go for about 3 months and it still sat a bit too high for me. I changed them out with the old ones and it dropped the rear almost an inch. The pics show the measurements. With the new isolators, the wheelwell clearance was 3" or so. After the swap, only 2 1/4".
So I guess you guys doing rebuilds should keep the old rear isolators. The new ones MUST be for 4th gens, and are the only ones they make anymore. Also, the old ones have a metal core or something, they're stiff. The new ones are all rubber.
More pics to follow.
Ed
Attached Thumbnails Swapped to old rear spring isolators, got new stance. Pics inside..-clearance1a.jpg
Old Oct 22, 2002 | 03:33 PM
ebmiller88's Avatar
Attached Thumbnails Swapped to old rear spring isolators, got new stance. Pics inside..-clearance4a.jpg
Old Oct 22, 2002 | 03:35 PM
ebmiller88's Avatar
Now it sits like this:
Attached Thumbnails Swapped to old rear spring isolators, got new stance. Pics inside..-new-stance.jpg
Old Oct 22, 2002 | 03:53 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
Thanks for the 411, Ed. I guess maybe I'll just stick with what I got!
Old Oct 22, 2002 | 06:52 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
the *** end sat high with the hotchkis springs as well on my ROC. that was with the old original gm isolators. i ended up cutting the damn springs and now sits nicely. i still want to lower it just a bit to match the front though.
Old Jul 14, 2003 | 10:07 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Thanks Ed. Great information.
Old Jul 15, 2003 | 08:39 AM
Car: 1988 IROC-Z
old post huh? heheh. here's the way it looks now with the rear hotckis springs cut. yes that is a grey door . some biatch hit me couple months ago. money has been thin so...
Attached Thumbnails Swapped to old rear spring isolators, got new stance. Pics inside..-stance.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
sailtexas186548
Aug 26, 2015 03:32 PM
