Stock MAF flow for TPI cars 165 ecm
Old Oct 23, 2002 | 01:02 AM
funstick's Avatar
ok guys heres the maf flow chart for 165 ecms running a bosch sensor.
grm/sec.......counts....... VDC
3.2.................64........... 0.18
4.5...............128............0.37
6.3...............192............0.55
8.2...............256............0.73
10.9.............320............0.91
14.0.............384............1.10
17.7.............448............1.28
22.3.............512............1.46
25.0.............544............1.55
27.6.............576............1.65
30.6.............608............1.74
34.1.............640............1.83
37.1.............672............1.92
40.7.............704............2.01
44.5---------- 736--------- 2.10
47.7---------- 768--------- 2.19
51.2----------800----------2.29
55.1----------832----------2.38
59.0----------864----------2.47
63.2----------896----------2.56
67.8----------928----------2.65
72.3----------960----------2.74
77.2----------992----------2.83
82.0----------1024--------2.93
87.5----------1056--------3.02
92.8----------1088--------3.11
98.6----------1120--------3.20
104.4---------1152--------3.29
110.7---------1184--------3.38
117.1---------1216--------3.47
125.0---------1248--------3.57
134.5---------1280--------3.66
142.3---------1312--------3.75
150.4---------1344--------3.84
158.5---------1376--------3.93
167.4---------1408--------4.02
177.1---------1440--------4.11
186.0---------1472--------4.21
195.0---------1504--------4.30
206.2---------1536--------4.39
212.2---------1552--------4.43
218.1---------1568--------4.48
225.1---------1584--------4.53
232.1---------1600--------4.57
239.1---------1616--------4.62
247.1---------1632--------4.66
254.0---------1648--------4.71
254.0---------1664--------4.75
254.0---------1680--------4.80
254-----------1696---------4.89
254-----------1712---------4.93
254-----------1728---------4.97
254-----------1744---------5.01
254-----------1760---------5.05
254-----------1776---------5.10
254-----------1792---------5.15
ok enjoy. hopefully this will lead to larger maf housings in the future. also looks to be some unused maf resolution to take advantge of in terms of what the code sees.anybody got a *** equation to take grm/sec and turn it into CFM. if so i can get a larger housing flowed some time later in the month and we can use the voltage and flow rates in CFM and convert it back into grm/sec
ok guys see you later.
Old Oct 23, 2002 | 06:53 AM
tjrh522's Avatar
Re: Stock MAF flow for TPI cars 165 ecm
using ideal gas law...
pounds / cubic foot = ( MW / 10.73 )( psia / °R )
molecular weight of air is 29
R is in rankine R=459.67+ degrees in F
psia is absolute pressure (inches of mercury 29.92=14.7 psi)
1 lb = 454 grams
CFM= GPS / 454 / (pounds / cubic foot) * 60
(Grams/sec) * (lb/grams) * (cubic foot/lb) * (sec/min)......gives (cubic feet/min)... hate units....
question tho....is this your modified sensor? I mean no screen?
Old Oct 23, 2002 | 07:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
At 72F, sealevel:
CFM = GmSec / 0.5647
RBob.
P.S. do you have any way to measure the pressure drop across the sensor?
Old Oct 23, 2002 | 08:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Just found this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=139215
Seems related. . .
RBob.
Old Oct 23, 2002 | 10:54 AM
funstick's Avatar
no this is a copletely stock sensor. bosch. the one i have been using is for a 302 ecm runnign $3a code and is FQ based nto voltage. looking at teh volateg gradient its almost funny you could almost use a MAP sensor. anyways anybody cares to work out the flow changes for a larger housing let me know. i havent the time right now.
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
NBrehm
Aug 25, 2015 11:49 PM
marcusaw
Aug 10, 2015 08:13 AM
