TPI Manual Transmission .Bin
Old Oct 21, 2002 | 08:00 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I am in the process of tuning my manual transmission car. Problem: When shifting gears, the map pressure falls to a point that corresponds to a greatly advanced area on my timing curve, causing a backfire and making me generally sad. Anyone have a bin I can look at to resolve this issue?
Old Oct 23, 2002 | 08:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
APYP might be a good starting point if you haven't tried it already. I'm running it in my car, and haven't had any issues with backfires... but then again, I didn't have any backfire issues with ARAP or even my stock 305 auto chip either.
Old Oct 23, 2002 | 09:44 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I believe TPI guy is speaking of a 730 SD ECM.
Old Oct 23, 2002 | 02:32 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
With your 355 I'd start with the vette speed density manual bin. I think it is AXCN if my memory serves me right. There was a thread a couple months ago asking about the vette manual transmission .bin try a search for it.
Old Oct 23, 2002 | 03:07 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If you try to use a vette manual bin then you will get a check engine light due to the oil temp sensor which we don't have on the f-bods.
Tim
Old Oct 23, 2002 | 03:21 PM
Car: 1991 Firebird
Engine: 427 LSX
Is there a way in tunercat to turn this off? Also, I would assume I he could just use the timing tables, right? Can anyone confirm the exact bin?
Old Oct 23, 2002 | 03:55 PM
YenkoZ28's Avatar
Car: 1991 Z28
Yeah you can just uncheck the oil temp error box. Here is a thread with some info. https://www.thirdgen.org/techbb2/sho...tte+manual+bin
good luck.
Old Oct 23, 2002 | 06:25 PM
kevinc's Avatar
Car: 1982 Z28
I'm using ARFP.bin as my base, 1990 L98 Vette with manual trans. Downloadable as ARFP7185.bin from diy-efi.org
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Sanjay
Aug 12, 2015 03:41 PM
