All 1982 S/E are WS6 ?
Old Nov 1, 2002 | 01:35 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Here is a shot from the 1982 brochure and the S/E came with the same suspension as the T/A
this is my doubt ..all 82 S/E are WS6 ?
how can i visually identificate them ? i got no RPO sticker ¡
Attached Thumbnails All 1982 S/E are WS6 ?-ws6.jpg
Old Nov 1, 2002 | 02:13 PM
90TA's Avatar
Look for rear wheel disk brakes.
Old Nov 1, 2002 | 04:29 PM
83firebirdS/E's Avatar
Car: 1983 Firebird S/E
All S/E's are NOT WS6!!! WS6 was very rare in '82. If you have rear drums then it's not a WS6.
Old Nov 1, 2002 | 04:38 PM
Calderone's Avatar
Car: 87 Vette
Not sure
I have a friend with a Formula 88 with the performance suspension badge in the "glovebox" and with rear drum brakes
and in the center cobers of his Formula wheels says WS6
Old Nov 1, 2002 | 06:44 PM
In '88 it was different! In '82 if you didn't have disc's-you didn't have WS6!
Old Nov 1, 2002 | 08:50 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
I doubt this old wive's tale will ever be put to rest. WS6 is not a suspension package, never was, never will be. it's a performance package that includes many upgrade items, one of them being better springs & sway bars. but guess what, it also includes better brakes, better steering ratio, positraction and other stuff.
That picture does not say anything about WS6. the "Special suspension package" it refers to is LEVEL TWO suspension for 1982, I guess the equivalent of RPO Y99 or F41. "Special suspension package" and "Special performance package" are not the same thing.
it breaks down like this:
FIREBIRD - LEVEL ONE suspension is standard. peewee front sway bar, no rear sway bar at all! doh. also the steering system is not rack & pinion, but is some ancient corkscrew design I can't think of at the moment. LEVEL TWO is optional and includes 30MM front sway bar, 12MM rear sway bar but still 14 inch wheels. LEVEL THREE is not available.
FIREBIRD Trans Am - LEVEL TWO suspension is standard and it has 30MM front sway bar, 12MM rear sway bar and 14 inch wheels. LEVEL THREE suspension is available but the only way to get it is to order the WS6 performance package, which includes 32MM front sway bar, 21MM rear sway bar, and stiffer springs, which is what LEVEL THREE is all about.
Firebird S/E - exactly the same as FIREBIRD Trans Am above.
WS6 was not standard on anything. it was a pay-extra option for all f-bodys, at least in 1982, which is what we're talking about here.
your photo talks about Y99/F41, not WS6. it shows Y99/F41 available on Firebird, standard for Firebird Trans Am and standard on Firebird S/E, ( A, S, S ) which is right on the money.
I assume you're on the 82 brochure.. well if so, look on the back cover, middle column, about two thirds of the way down. You'll see "Special performance package". That's WS6. the availability will look like this: ( -, A, A ). The dash means Not Available. which is the same way I tried to describe it above.
In 1982 they also had a shortage of WS6 disc-brake rear axles, so they substituted in drum-brake axles for most cars. The car still kept the rest of the WS6 goodies, but since it didn't have the disc brakes, it was different enough to warrant its own RPO. They called it WS7. So when you ordered a WS6 in 82, you probably got a WS7 instead unless you were lucky. All 2000 of the 82 Recaros got mandatory WS6 but there wasn't much left after that. To find a 1982 WS6 non-Recaro is pretty damn rare. Only PHS can verify it, as the cars didn't have their RPO stickers in 'em till 1984.
just tryin to help :
GT :rockon:
Old Nov 1, 2002 | 08:56 PM
Calderone's Avatar
Car: 87 Vette
kizz you rule ¡¡
:hail: :hail: :hail:
Thanks ..for your complete info ¡¡
it solved my doubts ¡¡
Do you have any home page with big info on 82s ??
Really thanks ...there is a guy who i thought it was you
check : http://www.geezernet.nu/transam/
Thanks kizz ..btw do you like Kiss ??
Old Dec 22, 2002 | 05:57 PM
GTDave's Avatar
Car: 1998 Dodge Ram 1500 4X4 Quad Cab
Engine: 360 V8
Transmission: R47RE 4 spd auto
Axle/Gears: 9.25 rear/DANA 44 frt / 3.90 gears
Do you know what the RPO would have been for an 84 Firebird with the level two suspension? Based on your description above, my 84 V6 has the level two suspension. I know for a fact it was all original when i got it, and it has the 30 mm front sway bar and a tiny rear sway bar.
Thanks, Dave
Old Dec 23, 2002 | 04:09 PM
kizz's Avatar
Thanks, Dave
That all does sound like level II which should be F41. Look in the RPO sticker in the middle console for that code.
Old Dec 24, 2002 | 01:31 PM
Dirty Rob's Avatar
Great info Kizz, just one more thing i didnt know about s/e's that makes them that much cooler to have.
Old Dec 24, 2002 | 03:54 PM
kizz's Avatar
But WS6 a.k.a. "level 3", was optional on S/E too with all the goodies.. posi, 4 wheel disc, etc. optional. Look at my post above from 11-01-0202 for full info
Old Dec 24, 2002 | 04:10 PM
Dirty Rob's Avatar
Anybody find a stripe kit for em yet? Hoping not to have to get one custom made...$$$$
Old Dec 24, 2002 | 09:43 PM
I wish they had an S/E package. I had to custom make mine and just match the three tone as close as I could.
Old Dec 25, 2002 | 02:40 PM
kizz's Avatar
S/E's were plentiful.. they made WAY more S/E's than GTA's for example.. that's hard to fathom. Think how common GTA's are.. you see zillions of 'em on this website and everywhere else online. Well they made MORE S/E's than that, but you never see them, they're all dead. problem is, nobody really pays any respect to an S/E because they don't have readily visible differences from Firebird or Trans Am, though a close look (which nobody has time for) reveals they are really unique. plus the fact that they came with a V6 standard (V8 optional) turns off a lot of hot rodders. So S/E's end up raped & left for dead or customized / modified to death, and now there are hardly ANY good condition S/E's anywhere. And as a result, nobody cares to restore one.. so there's no stripe demand.. so nobody makes the stripes or any of the other S/E unique stuff. It's really sad. they are very unique cars. I love 'em all. 83firebirdS/E's 82 black/charcoal was one of the best ones I've ever seen. very rare exception. I hope it went into good hands.
GT
Old Dec 25, 2002 | 04:22 PM
Dirty Rob's Avatar
so there's no stripe demand.. GT
There's a stripe demand! I demand it!
A custom shop that could do good ones could definitely pull a group business off of this site.
Old Dec 25, 2002 | 05:48 PM
Calderone's Avatar
Car: 87 Vette
HEre is my 82 S/E
AND I LOVE IT ¡¡¡
Attached Thumbnails All 1982 S/E are WS6 ?-16three.jpg
Old Dec 26, 2002 | 05:55 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
Transmission: T-5 Manual Clutch
Axle/Gears: 3.73 Positraction
WS-6 No Disk Brakes
I had an 88 Trans Am which had the WS-6 with drum brakes on the rear. It was a 305 TPI car. It had the black laced wheels too.
Old Dec 26, 2002 | 09:35 PM
GT
Me too...
Old Dec 26, 2002 | 09:38 PM
Re: WS-6 No Disk Brakes
'88 was different dude, read above.
Old Dec 27, 2002 | 08:15 PM
LG4TA's Avatar
Car: 83 T/A WS-6
Engine: LG4 305
WS-6
I know it was different I was just stating I had one like that. Trying to show it was pretty common.
Old Dec 28, 2002 | 07:59 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
What are you talking about? Of course its a suspension package...or let me rephrase that..a performance handling package. For the first few years of the 3rd gens and last few years of the 2nd gens it included rear disk brakes but other than that, it was all suspension. All of the suff you're listing(besides the posi) has to do with handling..i.e., suspension. And I believe the positraction you mention was a stand alone option.
The 4th gens call it the WS6 performance and handling package due to the extra performance of the ram-air hood. The thirdgens have no horsepower enhancements from the WS6 package.
Old Dec 29, 2002 | 02:35 AM
kizz's Avatar
Available WS6 Special performance Package* includes: 12.7:1 quick steering gear ratio, 32mm front sway bar/21mm rear sway bar, limited slip differential, four-wheel ventilated disc brakes with low-drag calipers and quick-take-up master cylinder, P215/65R15 steel-belted high performance radials, 15" x 7" Turbo cast aluminum wheels.
*WS6 Special Performance Package is required with the 5.0 liter V-8 Cross-Fire Injection on the Trans Am. It is available with the 5.0 liter V-8 4-barrel on Trans Am.
(even though they are only discussing WS6 on Trans Am in this section, WS6 is also available on Firebird S/E, as I said in an earlier post a few up from this one, dated 11-01)
Special performance package includes special handling package, 15x7 aluminum wheels, four-wheel disc brakes, limited slip axle and 215/65R15 steel betted blackwall tires
You with me so far? Clearly the performance package and the handling package are two separate things; the handling package is a part of the performance package; it's part of it; a sub-set of it, among other items. These quotes are from Pontiac documentation in 1982 which I assume you haven't read. I'm not pulling this stuff out of my azz. OK great, moving right along.. Now.. by doing a simple piece-by-piece comparison of those 2 quotes above, we can see that the so-called "special handling package" consists of two items: the upgrade 12.7:1 quick steering box (normal is 14.0:1), and the upgrade 32mm/21mm sway bars (normal is 30mm/12mm). In other words, those two items in the "special handling package" in addition to the upgrade 15x7 wheels (normal is 14X7), upgrade 15 inch tires (normal is 14 inch), upgrade 4-wheel disc brakes (normal is front disc / rear drum), and upgrade positraction (normal is no positraction) are what make up the "special performance package", also known as WS6. Doesn't this make sense? It totally agrees with how they say the handling package is part of the performance package. It's what I would expect it to be. TWO different packages. I don't care what someone's uncle's brother's wife's dog barked out, and I don't even care what someone's Formula center caps say, if they don't say something logical. Besides, we're talking about 1982 only. I care what I read in official Pontiac documents, especially if they make sense, which this one does, to me anyway. I don't know how to explain it any better than by quoting from Pontiac themselves, i.e. the horse's mouth. From that point on, it's up to the reader to interpret it properly, and apparently, nobody ever does.
Those of you that want to waste your time on a petty little technicality like this, go ahead! I was hoping this thread could die a peaceful death.. We've been through this subject before. This is the last time I'll post on this thread. There's too much other cool stuff to read on this website than to talk to deaf or at least misinformed ears. Have fun.
GT
Old Dec 29, 2002 | 07:39 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
[i]Those of you that want to waste your time on a petty little technicality like this, go ahead! I was hoping this thread could die a peaceful death.. We've been through this subject before. This is the last time I'll post on this thread. There's too much other cool stuff to read on this website than to talk to deaf or at least misinformed ears. Have fun. [/B]
It seems like the pettiness is in your argument not mine. You can list all the features of the WS6 package from the Pontiac literature all you like, the bottom line is, it is predominantly a suspension package upgrade. The bigger sway bars, the bigger wheels, the faster sterring box, fatter tires all equate to HANDLING. Even the limited slip you mentioned from the Pontiac brochure, is listed under the "special handling package". The brakes are the only thing that kind of fall under there own category, and even they were optional(WS7 I believe?).
And for the short run that the WS6 package included anything other than suspenion upgrades, it wont change its overall interpretation historically as a Pontiac handling package.
Old Dec 29, 2002 | 02:54 PM
kizz's Avatar
I'm going to assume that you're not really this dense in your assumptions, but that you just made a mistake. Go back and read what I wrote; it's all there in plain english.
GT
Old Dec 29, 2002 | 03:01 PM
85yellowiroc-z's Avatar
dude its OK!Relax,give em a break dude!HE knows what hes talkin about,Ive got the same info!!!Read the threads again,maybe then you will understand.
Old Dec 29, 2002 | 04:44 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
GT
Good assumption. I read your ramblings and I responded accordingly. Maybe if you could see past you're own arrogance you would understand my point. All I'm trying to say is that the WS6 package when all is said and done, is most noteworthy as a top of the line suspension upgrade for the Firebird. Now there may be a year here and there where it included another option or two(like in 82), but it doesn't change the overall perception of what the package is.
If you read MY response more carefully, you might have comprehended this. How's that for plain English?
Old Dec 29, 2002 | 07:11 PM
And what does your plain english have to do with the subject of this thread, titled: All 1982 S/E are WS6 ?
Old Dec 29, 2002 | 07:23 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Where have you been? Obviously we have been off topic for the last 27 posts.
Old Dec 30, 2002 | 12:16 AM
That was my point! Time to give it up. IBTL.
Old Aug 17, 2004 | 12:46 AM
82 S/E WS6's Avatar
Car: 82 S/E WS6
Engine: LG4 305 4BBL
Transmission: M24 B/W 4 Speed
Getting back on topic All 1982 S/E are WS6 ? Nope, But mine is
Old Aug 17, 2004 | 01:39 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Old Aug 17, 2004 | 03:23 AM
82RECAROTA's Avatar
Old Aug 17, 2004 | 11:34 AM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
but did s/e have or not have fender vents in 82 ?
s/e or t/a or both have 21mm rear bar ?
ive got both items on my drum rear 82 trans am
if its really a t/a
Old Aug 17, 2004 | 03:08 PM
82 S/E WS6's Avatar
Car: 82 S/E WS6
S/E never had vents in 82 or any other year as far as I know. the base S/E w/2.8L V6 had 30mm bars front & 12mm rear.
The S/E with the 2.8L & WS6 had 30mm front & 18mm rear.
S/E with the 5.0L & WS6 had 32mm front & 21mm rear.
A base T/A should have the 30/18 and 32/21 with WS6.
My 82 S/E WS6 has the 32/21 setup & the J65 rear disc's
Old Aug 17, 2004 | 05:06 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
ok so since i have a 21mm rear bar and i have fender vents and LG4 and such then my 82 definitely is a T/A for damn sure,
ok. got that figured out now,.
oh and has the 82 dated power bulge hood in which was not an s/e item, correct?
it is stamp dated 9A 16 82
RH fender is dated 7A and something and 82
is A the month or the 7 and 9 on the parts ?
next is how could i tell if mine was one of those that was supposed to have a disc rear but didnt get one because of the shortage of the disc rear axles ?
no way to know huh ?
thanks
Old Aug 17, 2004 | 07:10 PM
82RECAROTA's Avatar
Old Aug 17, 2004 | 11:07 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
so the WS6 ones were built first before Ws7 and s/e and birds and such?
thats what that sounds like
thanks
Old Aug 17, 2004 | 11:14 PM
82RECAROTA's Avatar
thanks
WS7 was used as an alternative to WS6 when the 4-Wheel Disc was not readily available. It was used in February, April, and from June to end of the production year.
Old Aug 17, 2004 | 11:51 PM
Agent13's Avatar
Car: 1983 Daytona Trans Am
Engine: LG4
82RECAROTA : You have got to make a FAQ page on the 82-84's. Your knowlege on them is just amazing.
Old Aug 18, 2004 | 12:08 AM
82RECAROTA's Avatar
Thanks Alex. I probably should. A book might be better.
Old Aug 18, 2004 | 12:20 AM
Agent13's Avatar
Engine: LG4
Even better!
Old Aug 20, 2004 | 06:26 PM
Randy82WS7's Avatar
Engine: 4.3L Z TBI
yep you should write a book
i need to do the same for the 67-72 CST era GM trucks cuz i know as much about them as you know about the 82 83 84;s here,
thanks
Old Aug 21, 2004 | 12:37 PM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
I agree 100 % :hail:
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
bjpotter
Oct 4, 2015 07:48 PM
rusty vango
Sep 29, 2015 02:44 PM
indygene
Sep 26, 2015 11:21 AM
