Almost done
Old Nov 10, 2002 | 04:08 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Almost done
pics of the almost done engine bay. I expect to crank it over tonight!!!!!!!!
http://www.thenebula.com/carpics/pics/almost1.jpg
http://www.thenebula.com/carpics/pics/almost2.jpg
http://www.thenebula.com/carpics/pics/almost3.jpg
http://www.thenebula.com/carpics/pics/almost4.jpg
add radiator, water/coolant, hookup hoses & tranny lines. add power steering fluid.
hold ears, turn over. play w/distributor to keep running.
Old Nov 10, 2002 | 05:58 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Its looking good.
This project is really coming together.
Old Nov 10, 2002 | 09:43 PM
KED85's Avatar
LOOKS SENSATIONAL!
My Blazer 3.4 motor is at same stage. Did my valve adjustment last week & got 150 PSI per cylinder I am so pleased with that high reading.
Rains gone, warm weather, only hope my sprained shoulder holds out to wrap up my 2.8->3.4 Swap Boogie Blazer project.
I am so anxious to drive my moving Blazer again..... (no fun driving it in this current stationary stage!)
Old Nov 11, 2002 | 03:26 AM
Engine: 5.7 / 7.4
got batt carged, & cranked it...........
.wait for it
backfire on mpfi is interesting
think I'll go back & verify that #1 tdc location again
am still going to have open manifolds , will put headers on when tranny dies & needs rebuild. more room to work then , will also be registered & **** e-checked
Old Nov 11, 2002 | 03:36 AM
Engine: 5.7 / 7.4
ignore
Old Nov 11, 2002 | 09:58 AM
KED85's Avatar
You're off a tooth or you're off 180* on distb install.
Be patient You'll make it happen.
You did line new chain up dot to dot right?
Backfire=spark happening wrong time
Hope the new timing chain went on correct!
