rear end swap???
Old Nov 24, 2002 | 02:50 PM
bluedude22's Avatar
Car: 87 Trans Am
Engine: 355ci
Transmission: w/c T5
rear end swap???
swaping out the non posi rearend that has drum braks, and swaping it with one with a posi and has disk brakes. Question is what do you have do for the brake system, do i just hook up the lines or what????
Old Nov 24, 2002 | 05:14 PM
ThirdGenP@rts's Avatar
NO! you need to order an aftermarket proportioning valve. you can get them at summit. then there is a tech article here on thirdgen on how to install it, by just swapping the lines, you will only create problems for yourself. good luck
Old Nov 24, 2002 | 06:09 PM
MdFormula350's Avatar
direct bolt in, just make sure the parking brake lines hook up right, and i believe you need the proportioning valve off the master cyclinder, but i have heard for the pbr disk that you do not to change it..
Old Nov 24, 2002 | 06:14 PM
ede's Avatar
ede
if you have the new PV, flat sided maCHINED ALUMINUM YOU DON'T NEED TO CHANGE IT, IF YOU HAVE THE ROUND CAST EARLIER STYLE YOU NEED TO CHANGE. sorry about the cap lock, fat fingers
Old Nov 25, 2002 | 04:05 PM
strategery's Avatar
Installing a Wilwood Proportioning Valve
Old Nov 25, 2002 | 07:10 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
I am not 100% positive here, but... DOn't you have to change the brake booster and Master cylinder to make the change from drum to disc due to the pressure difference. Like I said not 100% here.
Old Nov 25, 2002 | 07:59 PM
AFreaknGoodTme's Avatar
I have an '87 Camaro RS w/ non-posi drum that I swapped an '87Iroc rearend w/ posi and disc brakes about a year ago. The only modification I did was the removal of the spring and plunger from the front of the PV to increase pressure. My brake system feels top-notch. I run aftermarket rotors and carbon-matrix pads.
Click here for PV mod:https://www.thirdgen.org/techbb2/sho...hreadid=127100
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
