A couple of Air Conditioning Questions
Old Dec 8, 2002 | 09:58 PM
gruveb's Avatar
Car: 1989 IROC-1
When I did my cam swap I didn't put the AC back on. I will be doing my exhaust soon and then I'll put the AC back.
The air conditioner never worked (since I've owned it) and I'm sure even if I repair it that it will be very expensive to charge it with the old (can't remember the number R-12?) refridgerant (sp).
What are my options? Can I get a newer ac unit from a junk yard? Would it be cheaper to just re-install my old ac unit and take it down to Pep Boys, have them check it for leaks and charge it?
Old Dec 9, 2002 | 09:23 AM
Vader's Avatar
Check into recharging with an R-12 replacement, like R414B or Icor "Hot-Shot". It will provide a lot better cooling (15-20%) at a lot lower pressures than R134A, and even slightly better (8%) than the original R12. The R414B is a lot less costly and environmentally friendly.
Reinstall all your parts, install a new accumulator, evacuate the system into a deep vacuum for several hours to remove all moisture, replace the oil, then charge it to the pressure spec, not the weight spec.
Old Dec 9, 2002 | 09:57 AM
Damon's Avatar
Where do you get that stuff, Vader? How much?
I've done several R-134a switch-overs with good results, but it's always about 80% of the cooling as the original R-12 refrigerant, which I'm told is about normal. I'd love to use something that actually cools BETTER than R-12.
Old Dec 9, 2002 | 10:34 AM
gruveb's Avatar
Car: 1989 IROC-1
You know, the way I'm going before you know it I'll have a decent car on my hands!
Old Dec 9, 2002 | 12:17 PM
Vader's Avatar
You probably already have one. It only seems that a little "catch-up" is necessary to get it back into proper condition. That's just busy work and details (which makes all the difference between a ride and a beater).
Old Dec 9, 2002 | 06:01 PM
gruveb's Avatar
Car: 1989 IROC-1
You're right.
I know an out-of-work paint & body guy with his own home shop that offered to fix the dent in the door and re paint it (the car) for $500 if I do it before Christmas! I had him do a car of mine before....dodge shadow that had faulty primer from the factory and was at the time suffering from male pattern baldness.
I'm thinking I may post-pone my exhaust purchase for a month or two!
Old Dec 9, 2002 | 08:33 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
One of the things we do with 134a is use a f**d orifice tube and that usually gains you IIRC 6-8 degrees of cooling.
Old Mar 22, 2003 | 12:31 PM
patrickm00's Avatar
what part # would that be?
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
ezobens
DIY PROM
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
jackhammer
Aug 15, 2015 10:04 PM
