pics of powersteering pump
Old Jan 6, 2003 | 03:06 AM
radiateu2's Avatar
Does any one have pics of the power steering and its brackets installed on lg4 cant find a good pic anywhere. I know that Vader probably has it lol.
Old Jan 6, 2003 | 05:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well you're in luck.... I happened to be changing my header gasket the other day, and since this question gets asked so much, I snapped a few shots. This car has Edelbrock TES on it, but all the harware around the brackets is stock; I made spacers to exactly duplicate the exhaust manifold thickness.
Here's the lower bracket, it needs to be put on first.
Old Jan 6, 2003 | 05:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how the hardware needs to be assembled on the exh man bolts. Note that these are studs, not bolts, and note the placement of the washers.
Old Jan 6, 2003 | 05:54 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's what it looks like with all 3 of them on there. Note the stud and washer where the top (pivot) of the power steering pump will go.
Old Jan 6, 2003 | 05:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Here's how the PS pump attaches.
Old Jan 6, 2003 | 08:33 PM
EvilCartman's Avatar
Car: '82 Z28
Heh, I've been running without that small bracket ever since I put the engine back in the car a few years ago. Now I finally know where to put the silly thing.
Old Jan 7, 2003 | 11:44 PM
radiateu2's Avatar
brackets
Hey thanks RB it was a big help although your brackets differed from mine I guess yours had AC? But none the less thanks for your helpful response as always.
Old Jan 8, 2003 | 12:16 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
When we did my heads and cam, we puzzled for an hour or so trying to figure out that stud arrangement on cylinder one
Old Jan 8, 2003 | 09:35 PM
radiateu2's Avatar
stud on number one
I used a cheaper version that works the same. I used a piece of threaded rod and screwed it into the head tightened it down with a lock washer and and nut. I then put the bracket on the end of the threaded rod. I bolted the the bracket to the front of the head first then I used a jam nut on the inside of the bracket and tightened the bracket on the 1 stud with another lock washer and a nut. I then cut the piece of threaded rod of that was sticking out with a hack saw and filed down the rough edges. Total cost $2.14 doesnt look bad either.
Old Jan 9, 2003 | 12:20 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
HEY THANKS VADER!!!
I always wondered were that stupid bracket I had left over went! lol.... Never had any problems without it, but it most go there for a reason.
Guess I'll drag it out of the "spare parts" bin and install it now. lol
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
backtothe80s
Sep 5, 2015 12:39 AM
Street Lethal
Aug 12, 2015 11:33 AM
