Stuck in Cell 4.
Old Jan 20, 2003 | 09:58 PM
Bort62's Avatar
Stuck in Cell 4.
Stuck in Cell 4.
Its a 7730 based TPI retrofitted into my 85 Sport Coupe.
I am stuck in BLM cell 4 for no apparant reason. I did a little research on here, and heard of two possible causes.
1.) No VSS. I know this is not a cause, Because the 86 IROC I just converted to Speed density Did Not have a VSS either, and I did not have this problem, So Rule that out. I don't have a VSS installed yet, however.
2.) Canister Purge. I am using a stock BIN in respects to this, and am Still stuck. I have tired Several Differant BINS, Including one wich I KNOW works. Would it matter that I have no Charcoal Canister to Purge ? doesnt make sense that it should.
So, I may be an Idiot, but I have the following Codes -
41, Cylinder select Error. I think I am using a V6 memcal. Going to GM tomarrow to straiten this out. - Could this cause it? I wouldnt think so... but Maybe ?
23 LOW MAT - Not really sure what the deal with this is...
54 LOW fuel pump Voltage. Since this is a retrofit, I cut the wire at the relay and ran a new Wire back to the pump. Not really too sure whats cuasing this code but Im not entirely worried about it, Ill resolve it later.
Any ideas? Its frustrating the Hell out of me.
Old Jan 21, 2003 | 10:44 PM
Bort62's Avatar
Old Jan 21, 2003 | 11:08 PM
funstick's Avatar
could be the cylinder select error but i dont know ??
Old Jan 22, 2003 | 06:40 PM
87_TA's Avatar
I was under the assumption that the 7730 ecm spends about 95% of its time in cell 4.
If i recall my car is always in cell blk 4
Old Jan 23, 2003 | 08:26 PM
Bort62's Avatar
That hasnt really been My experiance.
Plus, It has NEVER left Cell 4 - Not at all.
Old Jan 23, 2003 | 08:34 PM
justme's Avatar
The same thing was happening in my vette before I hooked up the VSS in it. Always in cell 4. After I hooked up a VSS it started going to different cells, even though it never was running right. The SD TPI in my jeep is the same way. No vss and it always stay s in cell 4, never changes.
Old Jan 23, 2003 | 08:56 PM
Bort62's Avatar
Well, Im gonna pick up a VSS come end of the month, but I know for a fact that the 86 IROC i just converted to SD didnt have any VSS input, and it worked just fine...
tmellott89
DIY PROM
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
3.8TransAM
Sep 27, 2015 08:37 PM
ULTM8Z
DIY PROM
Sep 16, 2015 09:15 AM
