If i rip out the cat will it help much?
Old 07-02-2001, 10:43 PM
Irish_boy_305's Avatar
If i rip out the cat on my car, since i know exhaust is a big problem for the LG4, will it help a bit until i run true duals with headers? I mean i know its not gonna be like 20 hp gain but will it make my car breath better?
87Camaro RS
305 carb.
K&N air filter
HyperTech Stage II chip
160 Thermostat
Autolite wires and NGK plugs
Old 07-02-2001, 11:27 PM
firbird's Avatar
yes it will breath better and maybe a small preformance gain if any
Old 07-04-2001, 06:45 PM
JETHROIROC's Avatar
I replaced the dual ones on mine with two straight pipes last weekend, to a Dynomax muffler. I noticed a difference right off, and it sure as hell sounds better. Doesn't "stink" any worse either, especially when it goes into closed-loop. Just don't let anyone give you that "engines need backpressure" crap like the pro-cat people always cry....with stock manifolds and stock pipe sizes you will have more backpressure than any engine should be saddled with. Go for it.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, Accel coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley AFPR, ported plenum,
Ruger P95DC, hot wife, new oil filter, thick rubber floormats.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old 07-05-2001, 06:07 AM
ws6formula89's Avatar
Dude, we don't "cry" about it. It's pretty funny how you can measure exhaust pollutants just by the "stink". Stock motors are designed with emissions with a set amount of backpressure. A completely stock motor, with a stock exhaust system will need that backpressure for proper cylinder ignition. When you remove the Catalytic Converter you shouldn't feel any performance gain, except your car will run worse than it did before, remember when you take away backpressure, it will add maybe 3 horsepower at the most, and lose some torque. I don't know where you felt that performance increase but I bet it was small, not noticable. Better run without a PCV valve then, might gain you 1-2 horsepower that it takes up. [Sarcastic]
Your car should have 2 3/4" inch exhaust, that's plenty fine for a stock motor. What I wouldn't give to have 3 inch exhaust stock.
Doesn't make that much of a difference, but you can do anything you want. By the way, I bought my car without a cat, it ran like crap, so I bought a stock converter. Then it ran 15 times better.
1989 Pontiac Formula WS6
69,000 miles.
305 TBI, 4.10 gears, SLP Zexel/Torsen Limited Slip Differential, 700r4 Corvette Servo, LT4 Hot Cam/Valvesprings, GM Aluminum Driveshaft, 2700 RPM Stall, Edelbrock Performer RPM intake manifold, Turbocity TB. Ran on 6-19-2001 again: UPDATED: 14.1 @ 97.68 mph. Dyno'd Bone Stock @ 172.6 rwhp, 266 ft-lbs. of rw-torque.
Old 07-05-2001, 02:21 PM
zupmanZ28's Avatar
Car: 86' Z28
you wont notice any difference, it'll sound a bit different, but for what your leaking into the air without it, its just not worth it. buy a slip on catco from Summit, mine cost me 44 bucks, pretty cheap alternative if you ask me.
Eric
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old 07-05-2001, 04:09 PM
Jza
Jza's Avatar
You could always get that fuel additive that makes your exhaust smell like strawberries..
LOL
Old 07-05-2001, 07:30 PM
JETHROIROC's Avatar
WS6 - You bring up some good points and some straight myths. I'm sure this calf has been licked a million times over, but due to all the wives' tales people conjure up in some backwoods shop and the junk dyno tests high performance cat manufacturers produce in an effort to make their product seem superior to even a straight pipe (an engine can be tuned to produce certain test results), I am trying to clear up some confusion many people still have when it comes to exhaust systems.
You are correct when you say it may not help a stock vehicle, but almost none of our vehicles are stock including mine and Irish_boy's, the person we are trying to give advice. If the engine is properly tuned for an exhaust system without converters, it will perform better than when tuned for the cats. I'm sure we all know the engine is tuned for the cat and not vice-versa, so any engine with emissions controls is in a sense "de-tuned" insofar as performance measures are concerned. This does not mean you should go rip out all the emissions control systems on your vehicle and expect to have increased performance. On the contrary, most systems are best left alone until your homework is done, or left alone indefinitely. I happen to love fuel injection. So please, no more derogatory remarks about PCV systems and such, as you'll be preaching to the choir (see tech articles), a thermal-fluid mechanical engineer, and a specialist in an automotive electronics production facility. I don't know everything about cars, but my modifications are not mindless and random, nor are they held back by myths and ill-informed critics.
If you'll notice from my signature (also sarcastic), my combo will put me in the territory of richer combustion than stock. Reduced backpressure in the exhaust system coupled with good flow velocity will make an engine run leaner via superior combustion gas scavenging. Hence, my engine, which runs too rich for the stock exhaust system (in open loop operation), benefited substantially from cat removal. They were in good condition, I might add. Most engines benefit both in power and economy from a reduction in backpressure so long as adequate flow velocity is maintained and the proper tuning is conducted, and this is the key. Your car just wasn't tuned right for a no-cat system, but don't tell me mine isn't when my *** and rear tires say otherwise.
However, if you don't do the job right, such as when people bang the catalyst out and stuff the shell back in, or produce an exhaust leak, then you are wasting your time. My exhaust system is insulated from the manifolds back to the hog-ring clamp on the Dynomax cat-back, and the joints are tight. Hence, it not only keeps flow velocity optimized and the backpressure reduced by replacing the cat with straight pipe, it keeps the gases hot as well, not to mention keeping the system quiet (up until the tailpipes) and leak-free.
Finally, your eyes and nose are some of the best instruments for sensing the condition of your engine's combustion (lean, rich, near-stoichiometric, etc.) and the detection of other problems (oil consumption, cracked head, puked cat, etc.). I'm sure my vehicle emits more hydrocarbons, carbon monoxide, and oxides of nitrogen than it once did, but since I only drive it about 50 miles a month I really couldn't care less. If I drove it every day, I would feel differently.
No flames intended, but let's try to tell it like it is. And let's also avoid ridiculous generalizations like "remember when you take away backpressure, it will add maybe 3 horsepower at the most, and lose some torque." So the removal of an undefined amount of backpressure adds three horsepower and "loses" an unknown amount of torque... interesting.
[This message has been edited by JETHROIROC (edited July 05, 2001).]
Old 07-06-2001, 12:10 AM
Ok, but I think the emission system is a great invention. I would use it on a modded vehicle as well as stock. I thought people were just trying to free up power, when it doesn't gain much. I would use an emissions system on a 350 horsepower car driven on the street. But I wouldn't use any of it on a Drag Car. The 3 horsepower thing was a generalization for how much power they usually free up. Not much. But backpressure puts more of a load on the engine thus producing more torque. Now in your case, the loss wouldn't be a huge sacrafice. Nor on a stock vehicle. But it is very efficient and people that don't know too much about pollutants and catalysts often bad-mouth the design. Plus I hear people saying they are going to gain like 15-20 horsepower on a stock vehicle with stock exhaust, which is blatently sickening. I drive my car everyday, I don't bypass accessories or remove emissions for a little free horsepower. I think it's quite ok to not have emissions on a OFF-ROAD vehicle, or one that's not driven too much. But I just misunderstood. It's late, I'm not thinking too clear, I'm sunburnt bad...if I goofed anywhere, let me know.
-ws6formula-
P.S. I was joking with you about the PCV valve thing, I know you are smart enough to run those. I guess I should've put a smiley to indicate friendly jokings. About the PCV valve thing....I was joking
69,000 miles.
Old 07-06-2001, 06:23 AM
JETHROIROC's Avatar
It's cool man, this is a pretty hot topic anyways. I shoulda used some smiley faces too .
Old 07-10-2001, 07:07 PM
Lunaticc's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jza:
LOL
</font>
LOL I've used that b-4 in my car i got mine's from JEG'S
Old 07-16-2001, 10:01 PM
RICHRAD's Avatar
Irish boy, Believe what firbird says , I put a straight pipe on my stock lg4 in place of the cat and noticed a substancial power gain. Leaving the stock muffler provides more than enough adequate backpressure. The sound is awesome also, something aftermarket exhaust can't duplicate. You'll also have a slight increase in gas mileage. Get you some lower gears and do a few carb mods and you'll be well satisfied. Worry about the dual exhaust when you start doing engine mods!
Old 07-17-2001, 01:55 AM
90Iroc-Zee's Avatar
You gain about 3-4hp and lose about 8-10 lbs/ft of torque. I'm looking to bump my mph up from 96 to 97 and my torque is plentiful already, I can sacrafice some for some sound and hp.
1990 G92 5spd LB9 - 3.42 80,000 miles
Accel Ignition/Wires (8.8mm), Advanced Timing, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters, Centerforce I Pressure Plate and Clutch, Edelbrock TES Headers, Dual Cats, Edelbrock RPM Series Catback, Homemade Ram Air, Bosch +4 Platinum Plugs
14.4 @ 94mph w/2.0622 60ft (w/o headers and catback)
14.426 @ 96.19mph w/2.167 60ft(w/headers and catback)
Old 07-17-2001, 03:07 PM
SSC
SSC's Avatar
Car: No more birdy
Far be it from me to claim superior knowledge but catalytic converters change carbon monoxide to carbon dioxide. Carbon dioxide is supposed to be less hazardous to the ozone. Carbon monoxide is what plants soak up to produce oxygen. In a city where there is a lot of plants/trees the monoxide would be soaked up before it even had a chance to reach the ozone layer. It not like it shoots straight up in the air when expelled it disperses and plants soak it up. There is a 30 year study in the Brazilian rain forest to test the results of this theroy and on year 22 now the results are looking very good, "No dead trees". Where as LA where smog is considered the NO.1 enemy and catalytic converters have been mandatory since 73 the level of pollution has worsened. There is no one in their right mind who can claim that automobiles are killing the environment, its heavy industry who we would be pointing the finger at! An example would be pre motorized New York. In the 1880-1900 New York was the industrial capitol of the united sates manufacturing all sorts of material from textiles to processing Oil for use in lamps as well as keeping the machinery at the factories spinning. One can take from this that actually producing oil causes more ill effects than running it through the combustion process, I believe that pollution level was considered to be 40 parts per million which is highly lethal. Again I site California and they're many oil processing plants along the coast. So far we can only see the effects of modern oil processing for a reduced amount of pollutants in the air as well as the reduce amount of coal being used for heating as back in 1890. Since 1973 to present there is very little change in the smog situation in California and any dramatic change can be contributed to the closure of industrial facilities not cleaner running automobiles. Back to subject in my twisted way of course, removal of the converter seems to improve fuel economy, every little bit helps.
IMO I would rather have a car that's better on gas and produces plant food "also improves HP power mind you" than one that's supposedly safer for the ozone layer yet produces more waste. BTW that Hole up there in the ozone is still getting bigger even though we banned aerosol hair spray. Subject, Yes the removal of the cat will give you more power!
If were killing the earth we might as well pave it! J/K I love the earth and would rather nuke it and let nature start over than live in a desolate planet.
Dont let Al Gore read this, He might kill himself!
SSC
[This message has been edited by SSC (edited July 17, 2001).]
Old 07-17-2001, 04:05 PM
IROC5.7TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by SSC:
SSC
</font>
Well put
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
Old 07-17-2001, 08:18 PM
Dan87IROC-Z's Avatar
You'll feel a nice gain in your car's performance. It may take a small amout of power down low away, but nothing very noticeable.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old 07-06-2003, 10:15 PM
joshwilson3's Avatar
Old 07-06-2003, 10:23 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
Originally posted by joshwilson3
I believe that you are wrong, SSC. Plants use carbon dioxide to make oxygen, not carbon monoxide. Humans use this oxygen in the air and make carbon dioxide. So when you exhale, you are breathing out carbon dioxide. If plants used carbon monoxide to produce oxygen, then we humans would all be dead, because carbon monoxide is poisonous to us. That is why they make carbon monoxide detectors for homes. Carbon monoxide is odorless and tasteless.
"I'm dancing on the fuking graves!"
:lala:
He's right.
Old 07-07-2003, 12:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
lol
you guys can be so silly somtimes.
whats the big argument about anyway?
to answer the question "If i rip out the cat will it help much?"
1st question. is the cat clogged?
if yes, then yes you will see a huge diff. if not move on to the next question.
are you running stock manifolds?
if yes, then no, you will not see a huge diff. the car already has a restriction on it much larget then the cat. if not move on to the next question.
are you running a modified motor with headers and large Ypipe with a well flowing catback?
then yes, you would notice a slight diff with the cat gone... less low end, and more high end..
ONLY THEN will you lose or gain anything from the cat....
when you're running a factory "slow" motor... it really doesnt make a rats ***** worth of diff in hp or TQ if its there or not..
oh, and plants breath in carbon DIoxide..... we breath out carbon DIoxide.... carbon MONoxide is colorless odorless, tasteless and very poisonous to us.
carbon MONoxide is asorbed in our bloodstream like oxygen is, taking its place. however since we cant use it, it just goes thru the body and the parts of the body that are suppost to get oxygen dont... and we die.. basicly its like holding your breath or drowning... no oxygen = dead.
since we cant detect it, we have carbon monoxide detectors...
Old 07-07-2003, 03:57 AM
25THRSS's Avatar
Whats this crap about losing torque? That is absolute bs! Any time you reduce a load on the engine it will produce more hp and torque! Please people, don't spout out bs about how you need backpressure. Backpressure is bad, no if's and's or but's about it.
Old 07-07-2003, 11:38 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
a specific amount is good and helps the low end.
however, most 3rdgens already have enough because of the y pipe... so its a moot point.........
if you want more info, do a goo search here: www.google.com you'll find alot more info on the subject then on just this site.
Old 07-07-2003, 11:58 AM
25THRSS's Avatar
NOOOOOOOOOOOOOO, any amount of backpressure is bad! Any, and all backpressure is bad, very bad. You want 0, absolutely no backpressure at all. That is what will produce the most power AND torque. Say it with me now people; Backpressure is bad, velocity is good. Please don't start this backpressure bull**** again.
Old 07-07-2003, 12:20 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
you obviously havent done any research.
im not going to argue with someone thats ill informed... do a search on google and read.
Old 07-07-2003, 12:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
btw, do you also believe the larger the primary tube on the header, the better it is for the engine??
Old 07-07-2003, 12:22 PM
25THRSS's Avatar
I don't have to do a search and I am not ill informed, you are just one of the many who have fallen into the "i need backpressure" bs. It's simple. An engine is just one big pump. The easier it is for it to pump out the exhaust gasses the less work the engine has to do there for the more hp it makes.
Old 07-07-2003, 12:25 PM
25THRSS's Avatar
If you had actually read what I posted then you wouldnt even ask a dumb question like that. I said backpressure is bad and velocity is good. When choosing the right headers and exhaust system you have to take into account how much horsepower you will be making, aka how much gases you will be pushing out to achieve the maximum amount of velocity without creating backpressure. You can actually go too big which would slow the escaping gasses down and in effect create backpressure, so see I am not the "ill informed" one. It seems that you are. I will say again, BACKPRESSURE IS BAD!
Old 07-07-2003, 12:35 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh, cool. atleast you know somthing.
now on to your generic "the engine is a pump" outlook.
first of all. i agree accessive backpressure is bad. also, i agree that 99% of all thirdgens already have more then enough back pressure.
lets step away from 3rdgens and talk engines for a min.
now obviously, the more radical the engine, the more noticable the diff...
imagine a engine with a cam that has alot of overlap and a backpressure free exhaust system.
at lower RPM, as the air/fuel charge pours in, rather then going to the bottom of the cyl, it wants to flow out the exhaust port. you lose a little power that way..... that would be a way over simplified example... but think about it a bit...
in anycase, i still suggest you do a search. im leaving for work so i cant search for you.
Old 07-07-2003, 12:41 PM
25THRSS's Avatar
Yes, I do know quite a bit. I know enough to know that ANY BACKPRESSURE IS BAD!!!!!!!!! It doesn't matter what engine you are referring to, third gen or not, hell even a honda civic would benefit from 0 backpressure. No engine "needs" backpressure, but every engine wants no backpress. It's too bad you are leaving for work because you might actually learn something by searching yourself. Have fun believing an engine needs backpressure, it doesnt matter how much, little or big amounts of it, any is still bad. Any time an engine has backpressure it makes it work harder to push the exhaust gasses out of the port and in turn loses horsepower and torque in the process.
Old 07-07-2003, 12:43 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok just thought of this on the way out the door..
if backpressure is SOOOO bad, why does yamaha on their hyper efficent sportbike engines, have a elec motor controled butterfly valve in the exahust?
you know... the one that is closed part way at low RPMs, and opens all the way at the high RPMs these engines reach? answer that mr "this allways works for every engine no matter what" (sounds kinda stupid when i put it thatway, eh?)
Old 07-07-2003, 12:53 PM
25THRSS's Avatar
I have no idea why they did that. Is that engine a 2 cycle? I would guess that at very low rpm they close the valve to achieve more velocity at lower rpm's which doesn't push out as much gasses at that point. Those engines are complely different than anything you will find on a normal car. Most sport bikes were designed to rev to over 12,000 rpm and I would bet that at extremely low rpm the engine losses some efficiency because they were designed to be run at extremely high rpm. There for closing the valve, or making the exhaust pipe smaller, will speed up the excaping gasses at very low rpm, where the engine does not push out nearly as much gasses to need the extra piping that it does at 12,000 plus rpm. It was a trade off yamaha designed to achieve the desired tube size that the engine needed at low rpm's. Still think backpressure is good "eh"?
Old 07-10-2003, 01:22 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
ok for once I agree with 25th
backpressure is bad
it reduces velocity on the exhuast
and as for the due who said it puts more load on the motor thereby making more torque
there is one flaw
it does put more load on the motor hence making the motor WASTE torque to push the exhuast out and also reduces the scavenging effect of the exhuast
here is a little write I did once
just noticing that around here there is so much false information going around about backpressure and how it is needed.
so I am going to try my best to address how backpressure is NOT needed as well as a few other ideas
first thing I want to talk about it how people say backpressure is needed because it keeps velocity up and helps scavenging.
I see to major problems with that. first backpressure is in itself a resistance to flow correct? what happens when you put resistance to flow? it slows down correct? so if there is resistance in the system slowing the exhuast gas down how is it supposed to keep velocity up? it can't. second thing I is with how since backpressure keeps velocity up it makes it to where the first exhuast pulse helps create a vacuume to help suck the next exhuast pulse out. here lies the problem with that the words vacuume and sucking mean low pressure or no pressure. the word backpressure makes it sound as though there is pressure in the system. so which is it? you can't have a both pressure no vacuume at the same time in the same spot now can you?
also just want to take care of a few example of how backpressure works and how they are not able to be used and why.
backpressure is good it speeds the exhuast gasses up. example put your finger over a garden hose and see how the water comes out of there a lot faster.
yes the water does come out of there a lot faster but there is a difference with this when trying to talk about an exhuast system. first on the water hose it is a static system. no pulses or anything of the sort. an exhuast system has pulses in it so generally there isn't a constant pushing force. instead once the pulse is pushed out it more or less is left on it's own. if it finds resistance since there is still no static pressure behind it that pulse slows way down. second the actuall flow through the hose is a LOT LESS so that isn't helping the cause either
gutting the cat will harm your performance due to less backpressure. this one is kinda iffy.
depending on what style of cat your cat has and how many of them gutting it might harm performance but not from lack of backpressure but rather more backpressure. then again it might help your performance out being the old cat was clogged or used a nasty restrictive style.
but what goes on when the air enters a hollowed cat? it acts as though it hits a brick wall a lot of times. that quick opening to the innard of a cat slows the air down. for the most part air is stagnent through there. another problem is the shape of a lot of cats create turbulance and eddies or other flow situations that make for resistance to flow. that stagnent air creates resistance for the next exhuast pulse to go through hence more backpressure.
now the catch that can make it worse or better then the cat itself is see even though gutting the cat creates backpressure it is a matter of does it create less backpressure then the old cats?
now on to the main portion as to why backpressure is BAD
two things I want to say real quick
there is two types of pressure I am going to be talking about
backpressure which is a resistance to flow. generally can be rated in PSI
and then we have Delta pressure which is the pressure difference between two points
another interesting thing talking about pressure is the faster an object moves the lower it's pressure internal pressure is. try putting the rounded side of a spoon under a faucet with the water running
why does the rounded edge cling the the water as strong as it can? the water is an area of low pressure and on the other side of the spoon is high pressure thereby making the spoon go to the water.
so to talk a little about scavenging here for a second
scavenging is using that delta pressure (delta P). as you should know if you put a zone of high pressure next to a low pressure zone the high pressure going to try to even out with the low pressure zone. the greater the difference the faster the exchange happens. the less restriction between the two spots the quicker it will try to equalize. your cylinder is one big mess of high pressure. and the lower the pressure inside the exhuast (header to catback) the greater the delta P (pressure difference) and what is going to do is get the exhuast pulse out into the exhuast with less pumping loss by the motor itself as well as create a vacuume inside the cylinder which is going to help draw the next intake pulse inside the cylinder to help better fill it with fresh air/fuel.
so you ask where does backpressure fit into all this? how shold it? backpressure is resistance in psi? if you want to get the greatest difference in pressure between the cylinder and exhuast system that would mean you want the lowest PSI in the exhuast system which means no backpressure.
another problem with backpressure on top of restricting flow and causing a lower pressure difference is that it can help cause reversion. now what is reversion? that is when the exhuat gasses change direction and head back towords the exhuast port. when you have high amounts of backpressure/low exhuast velocity your exhuast gas can be sucked back in once the piston passes TDC and is now heading back to BDC that creates a little low pressure zone inside the cylinder and having backpressure kinda reverses the whole delta P thing. and this burnt gas mixture is going to cause a problem with making for a cooler combustion. sure it might reduce NOx but heat from a hotter combustion makes for more pressure. burnt gas will cool things down. also it can mess with the flame front. creatin an irregular burn.
also comes the problem of pumping loss. if the exhuast pulses help one another to help suck the exhuast out it makes for less work for your motor to do. when there is backpressure again remember that is resistance to flow that means your motor is also overcomming that resistance. that means WASTED power.
so let me ask this question real quick also. what woud happen if I could turn your exhuast into the freest flowing thing out there and figure out a theoretical fan to put on there. that would cause a vacuume correct? vacuume means little to no pressure... hence no backpressure. and with the concepts we just talked about I'm sure you can imagine what would happen.
with pipe sizing. too large of a pipe will cause a restriction in flow just as too much of a pipe will.
sure the large pipe wll flow a lot more under static pressure flow.
but in a pulse system what is that the exhuast gasses start to eddie around and more or less just flow in random patterns also leading to possible reversion. all of these cause restriction.... BACKPRESSURE.
small pipe we all know aobut.
chockes the living **** out of your car right?
we can pass that one then
another thing to think about is sonic tuning
makenzie71 kinda touched up on it but here I can go a little more in depth for you.
first backpressure doesn't cause pressure waves that bounce to and from the exhuast port
those are caused by changes in elasticity of the air.
you exhuast pulse starts out as a high pressure pulse hits a big open area like a gutted cat. that sends back a negative pressure pulse (not exhuast gas just a pressure/sound pulse) to the port.
if this pulse hits the port when the valve is open it will reduce the pressure in the exhuast and make the gas come out faster and easier (another clue that backpressure is BAD). things that cause these waves?
youe tail pipe, collector, gutted cats, mufflers can be a smalle cause of them. basicly anything that changes the shape, size or flow character of the exhuast gasses. now sure most of them do cause backpressure but some can relive or keep it the same...
now problem is it only works for a small narrow rpm range.. and at some rpms ranges it can make a high pressure zone right in front of the exhuast port and do more harm then good.
and now to kinda address the turbo crowd
this will be small though
but some people are saying that scavenging has no effect on a turbo car.
those people are worng also
before the turbo you can't really controll too much without different style turbo so the pressure there is kinda win/lose situation
but what you can do is make it to on the part after the turbo (d/p back) is as low pressure as possible. what this will do is help scavange the exhuast from the turbo system even and make the turbo spool quicker, flow more. should be able to figure that out from the topics we just talked about
might add more later
my fingers are getting tired and I'm bored so off to something else now
and to the example of the guy who pointed out the large cam and sucking the exhuast out
there is a problem with that idea also
at low rpms the exhuast velocity isn't going to be that high as it is due to the long duration of the cam.
this is going to cause some issues with exhuast gas reversion.
this is where the exhuast gas kinda changes direction when the piston reaches TDC and starts to move to BDC
at this point the cylinder is trying to suck in more air
you put a restriction in the exhuast and make the exhuast as slow down even more you cause a greater chance of reverion.
at this point when the exhuast gas starts to flow back into the cylinder that unburnt fuel doesn't burn.
this creates wasted space inside the cylinder. space that could better be used by air/fuel. also the dilution of the air/fuel mixture with exhuast gas will creat a colder burning flame. as you shoudl know heat produces pressure so less heat means less pressure and less pressure means less power.
then comes the issue of the flame front.
since burnt exhuast gasses don't burn once again they creat a very messed up flame front that is more or less eradic in it's burning proccess.
if you want more information you can search for backpressure for subject and my name for the user
find the post called "3" true duals for a daily driver" there is a lot of information backing up my post there a little better posted by various sources along this website and others
it might be of information to you
MR. dude where you the guy I couldn't get along with on 3go? it not sorry. if so hope we can work things out so no problems here
oh and haha I own here
welcome aboard though
Old 07-10-2003, 05:29 PM
Grimaldo's Avatar
The easiest way to say it is, a muffler is all you need. Cats are pointless and a way for smog clowns to feel they have sh###t controlled.
Old 07-15-2003, 09:27 PM
Zralou's Avatar
Hiya Guys
Just thought i'd throw in a little variation on the Backpressure v's no-Backpressure discussion.
Anyone considered the physics angle on this matter?
Below is a link regarding "ideal gas law"
http://www.vishnutuning.com/news_pvnrt.htm
Quote:
--- For those who don’t recall their high school chemistry classes, the Ideal Gas Law states:
PV=nRT
Where:
P = Absolute Pressure
V = Absolute Volume
T = Absolute Temperature
n = Number of moles
R = Universal gas constant
Why can’t this law be used to represent an exhaust system? Simple. There is no finite “n” when modeling an exhaust system. In other words, an exhaust represents an open system when the ideal gas law can only be used for closed systems (such as balloons, tires and other sealed containers.) In other words, how can pressure be measured in relation to temperature and volume when there is a big leak at one end of the system (the tail-pipe) and a big in-flow of gas on the other end (downpipe inlet)?
And that’s not all. As the name of the law implies, this equation only pertains to an “ideal” gas in which all internal energy is in the form of kinetic energy (energy of motion). With the presence of both inert and chemically combustible gases, the requirements for being accepted as an “ideal” gas aren’t even close to being met. ---
Take care, be good...
Sara Lou
Old 07-16-2003, 09:24 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
ws6 formula is sooo wrong,lol.... you obviously dont know anything about ignition,combustion or the 4 strokes of the engine. both valves are closed during ignition on the compression stroke,its what gives u power,on its way up the exhaust valve opens and releases the gas,the easier it gets out,the more power... and when ur at high rpms,and theirs valve overlap,u gain more from the exhaust getting out faster because it helps to suck in the air and fuel mixture... and if you think im wrong,i can show you a book that explains it,and u can tell the A.S.E. techs that write these books their wrong,lol
Old 09-04-2003, 09:45 PM
iroczman380's Avatar
Somebody tell me what the hell is wrong with the people on this board!!!!! 25thrs is 100 percent right, Why do dragsters run open headers,!!!!
I have installed countless sets of headers with buddies, on irocs mustangs, chargers and etc. NEVER HAVE I EVER EVER EVER FELT MORE LOW END AFTER HAVING MUFFLERS AND CATS BOLTED UP WITH PIPING!!!!!!!!
I put an edelbrock tes system on my iroc, and drove it around a couple days with the open y pipe. It was so loud, and was very fast compared to the stock exhaust. Once I had midwest exhaust bolt on the flowmaster with a pipe going to the back with no cat!!!!, i noticed a substanital power loss on the LOW END and the TOP END. the farther the exhaust travels the slower it gets out!!!! I now have a cut out ( right by y pipe) , and when i hit the cut out switch,, it is always faster. but maybe since backpressure is good, i could add a couple more cats and maybe a resonator, and have a cut out for that!!!! hahah
STOP THE BS, and tell the gosh dang truth, there are people on this board who would like to the real stuff not this jacked up story. And may i ask 90irocz and mr dude, and anyone else supporting them HAVE YOU EVER PUT HEADERS ON< or a y pipe, or have you ever experimented removing cats/mufflerss etc..
well obviosly not cause if you had you wouldnt be posting bs. Why dont you take your nonsense to a ***** board where you belong.
STOP THE
Old 09-04-2003, 11:59 PM
Transmission: t-5
agreed
Old 09-07-2003, 03:56 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The engine does not need or want any backpressure. Why do you think engines running open headers make more power than and engine that has a full exhaust system?
The only thing that needs backpressure (and its a VERY little amount) is the computer, so that some systems can run properly.
and yes, gutting the cat will make for more power. Not much, but it is one less bottle neck in the exhaust.
And why would anyone say that hp goes up and torque DOWN? you need need to create torque to create horsepower...
Old 09-07-2003, 04:00 PM
25THRSS's Avatar
Thank you! That is the understatement of the century, but most people don't even have a clue the 2 are very closely related. The only reason you might want a little backpressure is so some egr valves can function properly.
Old 09-07-2003, 09:44 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
Ok. I've searching all weekend because one of my cats is going south and I am soooo happy that I ran across this "debate".
I took the instruction of MrDude_1 and did a serch on google and this was the first thing that popped up.
"During the exhaust stroke, a good way for an engine to lose power is through back pressure. The exhaust valve opens at the beginning of the exhaust stroke, and then the piston pushes the exhaust gases out of the cylinder. If there is any amount of resistance that the piston has to push against to force the exhaust gases out, power is wasted. Using two exhaust valves rather than one improves the flow by making the hole that the exhaust gases travel through larger."
This is just one paragraph from this article http://www.howstuffworks.com/question172.htm.
After reading this and reading rx7Speed's posting, I believe that I am going to rid my car of the converters innards and quite possibly run a straight pipe through them so there is no loss of velocity.
Anybody have any spare cat's lying around
Old 09-07-2003, 09:55 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
More searching! Here's another one!
E.P.A. Says Catalytic Converter Is Growing Cause of Global Warming
Does anybody have two cat's lying around?
Old 09-08-2003, 08:50 AM
bigals87z28's Avatar
Car: Check The Sig
Velocity is good. Backpressure is bad.
Try running a 40 yard sprint with a straw in your mouth. Then run the 40 yard sprint with just normal breathing. Baisc physics here guys. More air in, more fuel, more power, and the faster you get the crap out the better. The little thing on the motorcycle that closes a valve probably does that to get the engine up to operating temp, and acts like an exhaust brake on a diesel truck to help the bike slow down. Backpressure is bad for you. If it wasnt, then hooker, hedman, flowmaster, etc.. would all file for bankrupcy. It comes down to this... Does your state require it? no? THEN TAKE IT OFF!! The feeling of the load the backpressure puts on the engine will make it feel like it is helping, but putting on a high flow exhaust will increase the power band over all. Area under the curve is what is looked for, not peak.
Old 09-16-2003, 11:52 PM
bonz's Avatar
Car: 89 GTA
backpressure
Maybe not on V8s but on the little honda's and other 4 banger import crap taking away back pressure will burn out your engine quicker.
Old 09-17-2003, 01:19 AM
25THRSS's Avatar
Re: backpressure
lol
Old 09-17-2003, 01:24 AM
Car: Check The Sig
Re: backpressure
WHAT... wow, you know nothing about honda motors... if you put backpressure on the honda motor, it will kill the hampster inside!! wow... you know nothing about honda motors.
And wtf do we care about honda? Last time i check they were still packin like 60 hp to the wheels.
Old 09-17-2003, 10:56 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Transmission: 6 Speed
Axle/Gears: 9" 4.11 Truetrac
hmm im not gonna step into the argument i will just share my own experiences. on my own personal car, when the cat was removed i did notice a loss of low end torque for sure, but it seemed to be nice and free in the 5k rpm area so i knew i got somewhere. then when i took my dynomax super turbo muffler off and added a flowmaster 80 series i noticed it to be even more sluggish down low. the 80 series did more hurt then good for me so i put the dynomax back on and got my low end torque back and still had the same top end. my friends have taken their cats off as well, my friend has a supercharged thunderbird and backpressure in that car is a big problem, hes running a super turbo exhaust as well. when we removed his cats it lost a bit of low end snap but it was better on the top end. well ill leave it at that.
Old 09-17-2003, 01:12 PM
txhotRS's Avatar
I have a 305... with a cat that was stock (which means clogged, old, rusty...etc..).. I took the cat off and replaced it with a regular steel pipe... the car sounded better,and the car had better response, ( I didn't say the difference was huge.. BUT it WAS there)
whoever said it said it best... AN ENGINE IS LIKE A HUGE AIR PUMP WITH A ROTATING OUTPUT... the more air out = the more air pulled in (it's called a vacuum for those of you who are disbelievers)which equalls more POWER... so if you have a restrictive cat, and you remove it... = less resistance, better breathing, more air flow.... = more power (even if it's a small amount)
take the third gen for example... it already has inherantly excessive back-pressure, the exhaust WAS NOT a good design... 8 cylinders of air in a 2-1/4 inch pipe
PEOPLE... if your car breathes... you make POWER... hence better flowing heads, HEADERS, bigger cams, intakes... it's ALL for air (gas too, but it's mixed with air)
YOU NEED A LITTLE BACKPRESSURE FOR LOW-END... but there are always high-flow cat's for that
Old 09-17-2003, 01:26 PM
WTF???????
YOU PEOPLE JUST DONT GET IT DO YA, NO BACKPRESSURE IS NEEDED, NONE!!!!!! BACKPRESSURE IS BAD, WTF DOES IT TAKE.
Old 09-17-2003, 02:27 PM
rs_boy's Avatar
Car: '89 IROC-Z Convertible & '91 RS
What's with all the flaming? Damn, you guys need to respect each others opinions and stop shooting each other down.
Old 09-17-2003, 09:39 PM
25THRSS's Avatar
Originally posted by iroczman380
WTF???????
Old 09-17-2003, 10:52 PM
Car: Check The Sig
Backpressure produces a load on the engine, that gives you a feeling of fantastic low end... But im 100% that the area under the curve will increase and thats what we are all looking for.
Old 09-19-2003, 11:44 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
You dont want backpressure not even on a stock car. If you dont beleave people who tell you the same thing time and time agian maybe a picture will help. I still have the stock tbi heads and cam.With my cutout open before my cat I make more hp and torque with no loss in power anywere. Here you go none beleavers.
I also have 1 3/4 inch headers on my 305 without power loss.
So ditch the cat if you dont need or want it. You wont lose power
Quick Reply: If i rip out the cat will it help much?
