Spearco & YS Trim plumbed
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
I got these pictures today of my custom Spearco intercooler plumbed to the YS-Trim. Three inch intlet into the intercooler-three inch outlet into a four inch oval into the throttle body.
Don't have the flow specs on the cooler, but as you can see, it is quite large.
Car: 2000 Trans Am
Looks good!
That STB looks like an edelbrock.
what are you going to do about the hood? It doesnt look like the hood can clear it going over the core support like that.
Car: 1990 IROC Z
Originally posted by JAYDUBB
Where did you get the STB from?
Car: 1990 IROC Z
Originally posted by Guido
Looks good!
Looks good!
Thats really great looking and your car is quite impressive :hail:
I have a question for the various custom plumbing guys. Where do you get the 4inch oval to connect to the TB? I have to custom plumb my paxton and won't be using an intercooler atleast for now but I still need a 4in oval section to attach to a 3in round in some form or another. Oh yeah and what rubber pieces are you using? Where do those come from particularily the one on the oval one on the TB.
Car: 1990 IROC Z
Glad to hear the cogs are working for you, I never had a single belt issue with them. Now the 50mm setup... that's another story
. I notice you either studded the blower shaft, or you are in the process of fabricating a strut rod assy. Can you elaborate on what is going on there?
Again, I think that is a sweet setup, I am now kicking around the idea of running a FMIC. If you can, get us some temps before and after the i/c, I'd be interested in the results. Thanks DonB.
. I notice you either studded the blower shaft, or you are in the process of fabricating a strut rod assy. Can you elaborate on what is going on there? Again, I think that is a sweet setup, I am now kicking around the idea of running a FMIC. If you can, get us some temps before and after the i/c, I'd be interested in the results. Thanks DonB.
Car: 1990 IROC Z
The IAT gauge of the DFI says below 100 degrees so far, and that is without the fan running on the dyno- I do have the Autometer 4373 dual channel IAT gauge going in soon, so I will let you know some real data soon.
:hail: Your car is sweet!! I look at those pics you first posted and went wow, then I checked your car out and said WOW, then I read your sig and said YEAH! Built to roadrace! Nice!!
I have a Vortech S/C too (just a S-trim tho) and I've been wondering how I'm going to plumb an intercooler. Thats a very nice install. I'd be interested to know if the car runs hotter now that you've got an IC in front of the radiator. I've been thinking about adapting the ATI twin IC setup Willie designed to a Vortech S/C but only because everyone says you cant put anything in front of the radiator. I'd prefer to just have a single IC.
Nice Ride Brah!!
Nice Ride Brah!!
Car: 1990 IROC Z
Crazy-thanks for the :hail:
I had two small Spearco intercoolers mounted low, but they just didn't move enough air to keep up with the YS Trim. I haven't had it on the track yet-that will happen at the RA F Body event April 12 & 13th. I do have a mechanical fan and custom shroud along with the BeCool radiator, and Edelbrock aluminum pump. We'll see if it stays cool on the road course!
Car: 1992 B4C 1LE
that setup looks awsome, I bet if another inlet were placed on the top tank for the pass side then a twin turbo car could use one like that.
Car: 1990 IROC Z
http://www.turboneticsinc.com/spearco/custfab.htm
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I was wondering where that pulley went off to
I originally had that cogged crank pulley and I traded it in for the standard (non-underdrive) crank cog pulley. Also had Don fab me up a billet bracket to prevent the flex of the stock bracketry ....
http://www.celligent.com/tim/iroc/progress/DCP_0871.JPG
http://www.celligent.com/tim/iroc/progress/DCP_0874.JPG
One day I'll get that YS ... it will just be awhile
I really love what you did with the intercooler. I might have to imitate you one day.
Tim
I originally had that cogged crank pulley and I traded it in for the standard (non-underdrive) crank cog pulley. Also had Don fab me up a billet bracket to prevent the flex of the stock bracketry ....http://www.celligent.com/tim/iroc/progress/DCP_0871.JPG
I really love what you did with the intercooler. I might have to imitate you one day.Tim
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I noticed in your pictures that you have the ground control caster camber plates. How do you like them? I am going to make a set for myself and I was wondering if you have and more pictures of them besides what are posted on your site?
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Axle/Gears: Stock 10 bolt 3.42
Tim
Originally posted by '91 Formula
TRAXION, Are you sticking with the stock ECM with the YS-Trim?
Tim
Yes. I'll be running the stock ECM repinned for a 749 with $58 code. I have an Accel Variable Injector Controller that I picked up really cheap that will allow me to run low imp injectors ... that will allow me to go big on the injectors.
Car: 1990 IROC Z
Car: 90 Camaro
Will your car be there all week and when are you going to be there I would like to meet the man behind the machine. bbunting can you give me your name so I don't feel like a total idot when I ask to see your car. Send me a email if you like, I wouldn't post this but I don't know how to get ahold of you any other way.
Car: 1990 IROC Z
649 RWHP 580 RWTQE gas only
Max IAT 95 degrees off the DFI after the intercooler at 6800 RPM and 12 pounds boost. That was with the fan in front of the radiator. I will hopefully have the gauges hooked up soon so that I can give you before and after temps. I will also dyno after I get another small pulley without ribbing so that I can get back up to the 16-18 lb. range.
Sweet numbers!
It will get real interesting when you get "real" airflow across that I/C. Didn't you have a 29 tooth pulley for the s/c? that should put you in the high teens (17-19#). I am now curious as to what pulley combo you have now to get 12psi. Currently I have a 77/29, and I am expecting to see over 20psi. if you are running the 75/29 and only seeing 12psi.... I guess I am in for a bit of suprise.
Either way, you are getting great results from that setup, and I am always looking for these updates. I am glad everything is working out so well for you, that Y/S is doing the job!
:hail:
:hail:
bbunting,
If you want a pulley capable of putting out more boost I think I have the smaller blower pullies? Don would know for sure but I thought that I did? I'll count the teeth on the pulleys later if you are interested.
Tim
Tim
Car: 1990 IROC Z
Sweet numbers!
:hail:
Sweet numbers!
:hail:
EDIT-we might have made more power if the Centerforce DF clutch would have held up-smoked pretty bad. Anyone recommend a clutch?
I e-mailed the Summit tech line a few months ago and asked what they recommend for a clutch setup for my application. I asked specifficlly if the DF would hold up. They said "no way" and pointed me to the Mcleod Street Twin. So that is what I have now, the billit aluminum flywheel model. It's not a drag car so I didn't need the extra inertia of the steel.
Car: 1990 IROC Z
Update
Ordered the SPEC Stage III ceramic package. After talking to their tech line about my aplication, that is the route I took-gets delivered Saturday. Hopefully have the clutch installed this weekend and get some real world intake air temps while breaking in the new clutch-even though it is only 35 degrees here.
Chevy - Camaro
Application Performance Kits Flywheels
..........................Stage 1 Stage*2 Stage*3 Stage*4*Stage 5
Torque Capacity: 400...........490........578........598...... 850
http://www.speclutches.com
Chevy - Camaro
Car: 1990 IROC Z
Intercooler temps update
Here is some real world driving data after the new intercooler install. Ambient temps today 75-80 degrees.
Highway cruise at 2500 RPM
Blower discharge temp 100
Intake manifold temp 88 (back of intake manifold)
4th gear WOT from 3500-6500 RPM
Blower discharge temp 120
Intake manifold temp 99
Looks like you dropped a constant 20* across the board. That is good info to refrence the results of my air to water i/c.
I can't believe how low your outlet temps were, that is great! I have seen outlet temps higher than that with an S-trim. That makes me happy
Thanks for sharing your results, DonB
Car: 1990 IROC Z
Intercooler temps update-Road America
Don- I will get you some more results the 12/13th at Road America. I will have a passenger that can log all the temps during warm ups lap (WOT thru 2,3,4, & 5th gear). But the large single is much better than the two small Spearcos.
Car: 1990 IROC Z
Re: Intercooler temps update-Road America
Originally posted by bbunting
[B]Don- I will get you some more results the 12/13th at Road America. I will have a passenger that can log all the temps during warm ups lap (WOT thru 2,3,4, & 5th gear). But the large single is much better than the two small Spearcos.
Humidity: 60%
Max temp at blower discharge: 180's
Max temp at intake manifold: 150's
Taken at the end of the straight in fifth gear at 5400 RPM
(160 MPH)
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
wow. thats lower than my roots blower's outlet temps after only a short 0-60 (6000) rpm run through 1st gear!!!
B, I am glad to hear the temps are so low with that y/s-trim. I am hope to have mine running soon, and would be thrilled to see outlet temps that low!
Thanks for the update. I'll let you know how mine turns out when I'm finished with it, although mine is a straight line runner.
BTW. 160mph is sick! :hail: Hopefully I can trap @ 150mph in the 1/4, but I just can't immagine what 160 must feel like. You are the man! Keep us posted.
Don B.
Don B.
Car: 1990 IROC Z
Car: 1990 IROC Z
Cold air intake
Here are some pics of the air intake for the supercharger. The hose has wire running through it to prevent collapse-even though it does compress if you give it too much slack-under the car is a 4 inch round K&N cone filter pulling cool air from under the fender-the fender brace needed a little "massaging" with my BFH, but it seems to work well. Also snapped a few new shots of the interior gauges, seat, new Grant wheel, etc
Car: 1990 IROC Z
One more RA clip
Here is a little close up of a 0-100 dash out of the grid.
http://home.mchsi.com/~debbie3004/IROC_RA4.wmv
Transmission: 4l80e
Axle/Gears: 3.512
hey what does your fuel economy look like, and do you drive the thing on the street much?
72pph injectors are huge! how do they do around town? no problems controlling them?
Car: 1990 IROC Z
Haven't really measured MPG yet. It really runs fine as long as your maintain 2500+ RPM-otherwise the cam doesn't like it. Runs down the highway at 65 MPH with no problems.
PS-72's aren't that big-they are almost maxed right now. I am looking at 96's.
Yeah, I know what you mean, I am running VP C-16. It is $30 for 5 gal... that works out to be 6bucks a gallon
I am going to have to break down and buy a 55gal drum one of these days, might save a buck or 2.
