Coil Spring Isolator Part number?
Old Mar 19, 2003 | 03:21 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I am going to change springs this weekend and I need the new rubber spring isolators for the top of the spring...Can anyone give me the part number for these things? My local GM dealerships is run by idiots and can't seem to get me the correct parts, so I need to give them a part # to get what I want in. Thanks!
Old Mar 21, 2003 | 12:29 AM
ebmiller88's Avatar
I can get it for ya tomorrow. Or get a hold of Dal and he'll know what you need.
Ed
Old Mar 21, 2003 | 04:28 AM
scott's85T/A's Avatar
front is 14047915...
Don't know the rear
I got mine here, http://gmpartsdirect.com $4.13 each
Old Mar 21, 2003 | 05:19 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Thanks Scott, All I needed were the fronts.
Old Mar 22, 2003 | 07:46 AM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
The front uses 2 isolaters per side for a total of 4 right? One on top and one on bottom? We just got done putting the pro-kit on my car, and the front passenger side had one on the bottom, the front drivers side had one on the top. FrEaKy...
Old Mar 22, 2003 | 08:47 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
It shouldn't use one at the bottom, because it would cover the drain holes.
Old Mar 22, 2003 | 08:13 PM
ebmiller88's Avatar
Correct, none on the bottom. Only the top, total of 2 needed.
Ed
Old Mar 23, 2003 | 02:57 PM
Hg's Avatar
Hg
Car: '87 Z
Umm.. how bad is it to have those holes covered? Cause we put them back in on the bottom
Old Mar 23, 2003 | 05:24 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Well you will probably have water pooling there then, which will cause rust at an accelerated pace lol.
Old May 29, 2003 | 12:52 PM
CaysE's Avatar
Back from the dead...
How about the rear isolators? Any part number for those? I've heard that new rears raise the ride height a bit; is this true?
Old May 30, 2003 | 07:59 AM
ebmiller88's Avatar
Yes! They will raise the *** end of the car a lot. I went back to my old ones, which are mostly steel, BTW, and ditched the new isolators I got. I'd keep the old ones if I were you. Since they're mostly steel, they don't wear out.
Here's a pic of the two styles together:
Attached Thumbnails Coil Spring Isolator Part number?-isolators-close-up.jpg
Old May 30, 2003 | 08:54 AM
CaysE's Avatar
What about aftermarket parts? ES or Prothane make something for these that doesn't raise the car a foot?
Old May 30, 2003 | 03:11 PM
ebmiller88's Avatar
I know ES was making a front isolator but I waited and waited for them to ship them to me, but that didn't happen so I went back to the stockers. I didn't see a listing for a rear one. They may have one by now tho.
Ed
Old Jun 8, 2005 | 07:41 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
Up from the dead ! I am doing the fronts and I think my isolators melted or dissolved or something.. They Arent there. question? If i order the front Isolators will they be thicker than the original, like the picture previous shows. I want the original dimension, so my car sits right.
Old Jun 8, 2005 | 10:39 AM
91formulaSS's Avatar
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
No, the picture shown is of the rears. The fronts are just thin rubber, no steel like the rears, the fronts don't affect ride height.
Old Jun 8, 2005 | 11:12 AM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
THanks, i just went to the pontiac dealer and ordered 2 of them. 10 bucks each, only two left in a city 3 hours from here. Hopefully i get them tomorrow. I hate those people at the dealership, everytime i go there its something, THis time the lady was really crabby..she said they are insulators not isolators ! I liked to have to schlap her.
I guess I'm going to have to rent a spring compressor too, I have the a-arm dropped all the way down and its impossible to get a sportline sping in there indexed right between the holes. but turn the spring 180 and its no problem.
Old Jun 14, 2005 | 10:13 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
wat happens if u dont run those isulator either on the front or rear?
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
355sbcTPI
Aug 19, 2015 04:38 PM
armybyrd
Aug 10, 2015 09:23 PM
